good heat insulation product
bighealeysource
Bronze
Came across this heat insulation product after my source
for reasonably priced Dynamat could not ship due to supply
issues. It's a closed cell product only 3/16 thick and
very easy to install and work with. Also very inexpensive
compared to Dynamat. Not trying to go on the cheap for my
BN6 but this really has worked out well. Take a look
at their website - www.harboursupply.net - and go to
the automotive products. Don't have any connection to these
folks but know many of us are always looking for ways to
defeat the Healey heat monster.
Regards,
Mike
Mike,
I'd recommend using Dynamat or some similar product under the Low-e insulation. The low-e will not water proof the metal nor act as a sound deadening product.
I used it in place of Jute. Jute absorbs water and will mold.
Low-e insulates and is does not absorb water.
I used the Low-e over Dynamat.
Together, they have made a BIG difference in keeping the heat down.
T TR6 TR6 heat insulation recommendations Triumph 12
NutmegCT heat insulation - interior Triumph 22
A Sound/heat insulation with foil---which way?? Triumph 7
jerrybny Heat & Sound Insulation question Triumph 2
H Need heat shield insulation MG 4
C Heat insulation washers Austin Healey 6
W Exterior Heat Insulation?? Austin Healey 20
HealeyPassion Reducing Muffler Heat Austin Healey 2
steveg Heat Shields Austin Healey 17
K TR2/3/3A Can heat from exhaust downpipe ..... Triumph 2
V heat shield Triumph Classifieds 7
EWD TR6 Sound/Heat Mat installation - 74 TR6 Triumph 14
M Heat-related carb issue on BN1 Austin Healey 7
EWD TR6 ā€˜74 TR6 Interior - Padded dash and heat/sound material Triumph 4
AH67 Heat Shield finish 66 Type Jaguar 5
J Bj8 intake manifold to heat shield to carb gaskets Austin Healey 4
BLong63AH Moss Supplemental Heat Shield Austin Healey 2
E BJ8 Seats, Exhaust Hanger, Heat Shield Locations in Floor Austin Healey 7
K TR2/3/3A Revington alternator heat shield. Triumph 0
60TR3A Is It Safe to Heat My Garage All Winter While I Am In Florida? Austin Healey 34
K TR2/3/3A DIY Alternator heat shield>>> Triumph 2
L 100/ Moss Heat Shield Austin Healey 2
wangdango Keeping the heat out? Austin Healey 11
DornTRoriginal TR2/3/3A Heat Shield Issues Triumph 6
T TR4/4A Tips on controlling heat coming up through shifter opening? Triumph 14
GTP1960 TR2/3/3A Carb. Heat shield location? Triumph 11
C Correct color of carb heat shield, starter, and generator? Austin Healey 12
T TR2/3/3A Fuel line heat shield Triumph 39
NutmegCT heat valve control cable Other Cars 0
MikeAH100M FYI - Hardie Board for Heat Shields not Recommended Austin Healey 9
H The heat shield for the Longbridge between the exhaust manifold and carbs Austin Healey 1
69mgbgt No cabin heat in my 1997 jaguar xj-6 Jaguar 1
I Spitfire If you can't stand the heat.... Triumph 7
J Side exhaust heat shield Austin Healey 23
M Making a manifold/carb heat shield - any suggestions? Spridgets 14
T TR4/4A Heat shield for tranny cover Triumph 4
R Heat Shield Detail Austin Healey 3
KVH TR4/4A Carburetor Heat Shield for HS6 SUs Triumph 4
T General TR heat proofing floor boards Triumph 10
R Heat shields and other hot topics Austin Healey 36
tahoe healey Dynamat heat shield Austin Healey 8
R securing heat shields Austin Healey 11
KVH Carb Heat Shield Installation Triumph 2
D Carb Heat Shield Spridgets 12
HealeyDave Intake manifold heat shield fitting issue Austin Healey 2
NutmegCT heat barrier Restoration & Tools 3
NutmegCT TR2/3/3A TR3 cockpit - summer heat! Triumph 12
M Supercharge Heat Sheild Question [pics] Triumph 3
Russ Austin Heat ah at least warmth. Triumph 11
R TR4/4A Tr4a, alternator heat shield Triumph 9
