    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
Fuse Box connections
Jack_Long
In an effort to resolve some of my Midget's electrical issues I installed a new fuse box. I connected all the wiring the same as the original fusebox but I am not sure it is really correct. Here is the way it is connected at present but I want to make sure it is right before reconnecting the battery (lowest numbers are to the front of the car with even numbers closer to the fender). This is a 1973 US-spec car.
#1 - Empty
#3 - Red/Green on bottom connector
#5 - Double white on top connector
#7 - Single brown on bottom connector
#2 - Double red on bottom connector
#4 - Double red on bottom connector
#6 - Double green on bottom connector
#8 - Single purple on top lug; double purple on bottom connector
Can anyone let me know if this looks right? Thanks!
Put a 20 amp fuse on the battery hot lead to the wireing, not the starter. Then test.
T 1971 Fuse Box and Wiring Triumph 7
W General Tech 2500S starter motor and fuse box questions Triumph 3
M TR6 Fuse box wiring mystery Triumph 9
TR3driver TR2/3/3A Late TR3A fuse box mounting Triumph 10
T TR2/3/3A Adding an auxillary fuse box to TR3 Triumph 5
K TR2/3/3A Wiring again: Fuse box Triumph 5
Lin Fuse box - new product in my current project, a 1964 jaguar mark tw Austin Healey 10
rjc157 Fuse box Austin Healey 9
Got_All_4 TR2/3/3A Need pics of fuse box area Triumph 6
GTP1960 TR2/3/3A Modern blade fuse box ? Triumph 20
Rut Fuse/relay box Spridgets 19
vette Fuse Sizes for New Fuse Box Austin Healey 11
rjc157 fuse box Austin Healey 12
T TR2/3/3A On TR3A what gauge wire from fuse box to coil? Triumph 17
doates Fuse Box Problems Triumph 8
Jims71TR Put a new fuse box in now I have troubles Triumph 15
I T-Series WTD: lucas 54382845 fuse box cover [smooth finish] MG 0
I WTD: lucas 54382845 fuse box cover [smooth finish] Austin Healey 2
K TR2/3/3A Modern Fuse Box on a Tr3? Triumph 7
C Fuse Box Spridgets 5
P Fuse Box Wiring Triumph 2
T lucas SF4 Fuse box Triumph 2
BoneIdle MGB-GT 1974 GT fuse box layout MG 8
T Fuse Box terminals 1973 Spridgets 1
tahoe healey extra fuse box Austin Healey 1
JPSmit fuse box question Spridgets 5
RickB To clean old tarnish off replacement fuse box? Spridgets 10
JPSmit Fuse box question Spridgets 4
C MGB 1977 MGB Electrical Problems - fuse box MG 4
P GT6 GT6 fuse box replacement Triumph 2
P GT6 GT6 fuse box replacement Triumph 0
WidespreadPanic TR6 '74 TR6 Fuse Box [UPDATE] SOLVED! Triumph 27
I 2nd fuse box? MG 13
wkilleffer MGB MGB 4-way fuse box question- 1974 MGB MG 8
J TR 4 Auxillary Fuse Box Triumph 4
msoylemez Aftermarket Fuse Box [58' Bugeye] Recs?? Spridgets 8
B TR4/4A In-Line fuse 25 or 35 Amp? Triumph 21
B MG Fuse Location Spridgets 2
K TR2/3/3A The USA Panel Light Fuse? Triumph 1
T TR2/3/3A TR3 Fuse Question Triumph 14
K TR2/3/3A Is a 25 AGC fuse equivalent to an original 30 amp fuse? Triumph 10
ckeithjordan TR2/3/3A Blowing a Fuse Triumph 30
charleyf TR2/3/3A Under dash fuse Triumph 7
M XK120 fuse problem? Jaguar 5
M TR6 Fuse, She Blows Triumph 13
S Wedge TR7 fuse panel Triumph 8
J TR6 fuse amps Triumph 2
edkap2002 TR6 1972 Blowing fuse fed by white wire Triumph 6
S TR2/3/3A try start it with the key and it blows the fuse Triumph 7
RAC68 Battery Fuse Protection Austin Healey 101
