MG Fuse Location
Brian1951
I was reinstalling the interior map light on my 1977 MG Midget. While installing the two mounting screws I notice a spark behind the lamp housing and the lamp no longer works. I removed the bulb and attached it to a 12-volt power supply, and it works. I put a voltmeter on the lamp switch and see know voltage. I am assuming that I have blown a fuse, but I don't have a clue where the fuses are on this car. We just bought the car a few weeks ago and clueless in regard to MGs.
Thanks Brian
JPSmit
Open the bonnet (Hood) and they are just beside the left hinge - there are 4.
Make sure you check with a cotinuity tester as the fuse can burn out under the cap.
Also note that British fuses are not the same as American. https://triumphtr6.info/Manuali/fuses.pdf
BTW welcome - you have a great project!
D location of fuel pump fuse on 1967 e-type Jaguar 3
T 1971 Fuse Box and Wiring Triumph 7
W General Tech 2500S starter motor and fuse box questions Triumph 3
B TR4/4A In-Line fuse 25 or 35 Amp? Triumph 21
K TR2/3/3A The USA Panel Light Fuse? Triumph 1
T TR2/3/3A TR3 Fuse Question Triumph 14
K TR2/3/3A Is a 25 AGC fuse equivalent to an original 30 amp fuse? Triumph 10
M TR6 Fuse box wiring mystery Triumph 9
ckeithjordan TR2/3/3A Blowing a Fuse Triumph 30
charleyf TR2/3/3A Under dash fuse Triumph 7
M XK120 fuse problem? Jaguar 5
M TR6 Fuse, She Blows Triumph 13
S Wedge TR7 fuse panel Triumph 8
J TR6 fuse amps Triumph 2
edkap2002 TR6 1972 Blowing fuse fed by white wire Triumph 6
S TR2/3/3A try start it with the key and it blows the fuse Triumph 7
RAC68 Battery Fuse Protection Austin Healey 101
S TR2/3/3A installing a fuse in the red tail lights Triumph 4
K TR2/3/3A The under dash fuse on later TR3's Triumph 7
D New Fuse Block Configuration Austin Healey 21
S License plate light - inline fuse, BJ8 Austin Healey 7
TR3driver TR2/3/3A Late TR3A fuse box mounting Triumph 10
T TR2/3/3A Adding an auxillary fuse box to TR3 Triumph 5
K TR2/3/3A Wiring again: Fuse box Triumph 5
Lin Fuse box - new product in my current project, a 1964 jaguar mark tw Austin Healey 10
rjc157 Fuse box Austin Healey 9
Got_All_4 TR2/3/3A Need pics of fuse box area Triumph 6
jfarris TR2/3/3A Fuse to protect OD solenoid Triumph 9
GTP1960 TR2/3/3A Modern blade fuse box ? Triumph 20
K Popping my mind and a 50amp fuse Austin Healey 10
TRclassic3 TR2/3/3A Help with fuel gauge blowing fuse Triumph 6
Rut Fuse/relay box Spridgets 19
K Preventing fires, to "FUSE or Not to FUSE"? Austin Healey 24
B MGB 79B hazard line fuse MG 1
D TR6 Fuse equivalent Triumph 11
D TR6 Blower fuse Triumph 4
D TR6 Fuse Triumph 3
B 79 Midget,what size fuse do i need in each of the 4 slots? Spridgets 22
vette Fuse Sizes for New Fuse Box Austin Healey 11
rjc157 fuse box Austin Healey 12
S TR2/3/3A TR3A Blown Fuse Triumph 12
T TR2/3/3A On TR3A what gauge wire from fuse box to coil? Triumph 17
B Fuse amperage Spridgets 7
johnrip Wedge TR7 side marker Light issue fuse keeps blowing Triumph 2
B In-line fuse Spridgets 4
doates Fuse Box Problems Triumph 8
D Best Way to Clean Corrosion on Fuse Clips. Jaguar 3
K TR4/4A TR4A Stock AM Transistor Radio Fuse Size? Triumph 14
wkilleffer 1993 Cutlass convertible blowing a fuse Other Cars 7
Brosky Easy add on fuse block Triumph 7
