MGB Full strip for paint
Boggsy64
I agonized for a long time over stripping ALL the trim/windscreen/ badges/handles etc. prior to painting. Was trying to figure out a way to do it nicely with all the bits and bobs still on the car. After removing some trim, I have now just started taking everything off the car. It actually feels better to know that I can now get at all the surfaces and do a much better job. Only issue is my garage is getting full and now I have overflowed into the house to store all the parts! Good thing my girlfriend does not live with me!
drooartz
If you're going in, best to go in all the way. Or at least that's what I tell myself!
It is surprising how much room even a small car takes once it is disassembled. I picked up a couple cheap plastic shelves and some banker's boxes for the strip down of my Bugeye -- managed to fill both shelves even with the simpler Sprite. I think ideally you want a 3-car garage to do a 1-car restoration. :grin:
Platinum
To do it "one time, right" you should do just what you are doing. Good decision!
Sarastro
.....It is surprising how much room even a small car takes once it is disassembled..... I think ideally you want a 3-car garage to do a 1-car restoration.
Ain't THAT the truth!
One thing I hadn't counted on, when I started my TD restoration, was the amount of space I'd need for storage. My home office, which is behind the garage, has been filled with TD parts since I started--and it's driving me nuts! I used up all the space on my shelves in the garage, and put some stuff in our small basement, too. But by now, most of it is back on the car, so things are sorting themselves out.
I wish I had spent a few bucks on some boxes as you did--I tried to get by with old cardboard boxes, but they can't be stacked easily so they take up more space. But, now I know, for the next project....
Tim Tucker TR4/4A Phoenix Stainless Steel Sports Full Exhaust System Inc Manifold experience Triumph 3
L MGB 1977 MGB will only run on full choke MG 53
BJ8Healeys For Sale BJ8 blue full tonneau cover Austin Healey Classifieds 2
W For Sale 1961 TR3a - Full Off Frame Restoration Triumph Classifieds 0
Editor_Reid 2011 Aston Martin V8 Vantage N420 Goes Full Lockdown Other British Cars 54
jackq Another building full of cars available. Other Cars 0
warwick-steve Fuel Gauge always shows 1/4 full Austin Healey 27
Popeye Post-War Other Mayflower for sale...needs full restoration Triumph 0
jackq General MG Got a room full of MGs MG 11
T TR2/3/3A About to strat a full restoration TR2 / TR3 ? Triumph 66
warwick-steve Fuel Gauge always indicates 1/4 full. Austin Healey 13
M For Sale Aston Martin wheels for Sale - $1600 - Full set in the original boxes Other British Classifieds 1
sim fuel tank sender reading full all the time Spridgets 9
J HD8 carbs, what is minimum fuel rate to keep bowls full, car is dying. Austin Healey 18
H What are the pros and cons for full synthetic oil in a 948cc engine Spridgets 5
NullReturned Full Service Advise for '68 Sprite MKIV Spridgets 7
C Full tank but no fuel!!!!! Austin Healey 15
TRMark TR4/4A Leaking Drain Tap before I could even get the radiator full Triumph 1
Parker MGB Headlights won't work after full repaint/restoration... what am I missing? MG 6
drambuie Old British car film..... The Fast and Furious 1955 full movie Austin Healey 17
Jim_Gruber Castrol GTLMA - Full Synthetic Spridgets 4
P fuel gauge always full Austin Healey 2
NikolausConrad Spitfire Spitfire full syncro gearbox build Triumph 3
N BJ8 out of fuel at 1/4 full tank Austin Healey 4
B Restore a rusty uni body car vs a full frame car? Restoration & Tools 4
T Bought a full sized electric oven for .99c on eBay Spridgets 7
PeterK Castrol Edge full synthetic Triumph 2
S TR2/3/3A Full spats for a TR3? Triumph 11
GBRandy TR2/3/3A Is this TR3 Rocker Panel Full of Putty? Triumph 11
livinginthepast 62 Sprite Fuel Gauge always on Full - Spridgets 9
novashawn Swap my full sun roof for Austin S wheels ? British Motor Corp 0
H Storage unit full of Spridget parts Spridgets 35
jbowlby Missing at full temp Spridgets 11
M Full of [3] Questions Spridgets 9
BobbyD Warehouse Full of NOS Parts Triumph 6
R TR2/3/3A TR3 full circle Triumph 12
Brosky Cam bearings, full disclosure with pictures Triumph 10
StagByTriumph STTAG Restoration Team pulls the FULL MONTY! Triumph 7
T How to tell if you need bearings or full rebuild Triumph 19
T TR2/3/3A TR3A gas gauge stuck in "Full" Triumph 26
YankeeTR British Car Field Day, Sussex, WI...A full report Triumph 5
jhorton3 Full Interior Kits Spridgets 2
Randy Harris Fuel sender gasket - replace w/full Tank? Austin Healey 8
Randy Harris Brake fluid canister - how full? Austin Healey 5
G Any suggestions for draining a full gas tank.... Triumph 24
Baz Full day of work Spridgets 35
boxofparts MGB 79 MGB tach needle swings about full scale at 3500 MG 5
T How full to refill transmission oil? Spridgets 4
jlaird Life is just full of little joys Spridgets 7
