I looked into AAW. Thats the way I thought I might go until i found out they don't make a TR7 kit.
Sorry, somehow I missed that you were working on a TR7.
Doing it right is a lot of work, IMO. If you just want to make it run, that's not so hard
First step in building your own is to come up with a detailed wiring diagram. You'll probably start with one of the available factory diagrams, but then you'll have to at least make sure it matches your car. I don't have any experience with a TR7, but I know that for a TR2-3 there are at least 6 or 7 factory wiring variations that are not particularly well documented. Most references only give one; and if you follow that one with most cars, the fuse pops as soon as you turn the key on. The Stag is somewhat better, at least more of the variations are documented; but still the most common one is not in any of the books (as far as I know).
You may also want to add some features like relays for high current loads, more fuses, maybe a fusible link here or there. Maybe a headlight reminder? Cruise control?
Now you create that wiring, with (hopefully) suitable color-coded wires, and check it all out. Again I don't know about a TR7, but on my TR3 & Stag there are a lot of permanent connections to be made (for example the bulb holder for the high beam indicator is soldered directly to the harness). The Stag also has several harness connectors that, while they may not be absolutely required, sure make it easier to do things like remove the center console, instrument panel or steering column.
Once that is done, you can take it back apart to wrap it or (better yet IMO) install sleeving. There are of course sleeving designs that don't require removing the wire from the car, but they look incredibly cheesy to me.
