First restoration
r67cat
I am glad to see the addition of this forum to the sight. My first restoration was a 71 Midget, three years ago, given to me by a friend. After one year and what amounted to a nearly complete reshell. this is what I ended up with. Honed my welding and paint skills and had to buy lots of neet stuff like a new compressor,blast cabinet, hvlp paint gun ect.
Before:
After:
Through that first part of the restoration my wife and friends would come out to see how much more or the car had disappeared. I had the last laugh in the end. Keep them an the road. Rick
Looks very nice. Do you have a web site with other pictures of the process?
now thats Pretty~~!!
NW_SpriteGuy
r67cat,
Was that your first restoration job ever, or just your first spridget restoration, because from the pictures it looks like a fantastic job! What part of the restoration did you find most rewarding? What part did you learn the most about? What were a couple of the lessons you learned that you wouldn't mind passing on to others here on the forum? What part of the restoration are you most proud of? I'm just curious because I'm in the middle of my first complete ground up restoration.
-Don
R
r67cat
NW Spriteguy, This was my first restoration. Read lots of books on welding, paint and body work. This cor is to be my daughter's when she is old enough to drive. A word of advice: keep and label everything you remove from the car.(Ziplock baggies and a sharpy marker are essential) Take lots of pictures and make drawings. These shells will bow when a lot of rotten metal is removed, so be sure to support the shell before welding in new pannels. I was able to do all of the work myself except the machining of the engine, and I haad the gear box rebuilt by University Motors in Ada Michigan.Additional pictures are on my websight. sight.https://home.comcast.net/~r67cat/wsb
I looked at the pictures on your web site. Looks like there is alot of new metal in the car. I've been working on a rolling "refurbishment". Nothing this extensive. However, I hope to do a full blown restoration later when I find a more suitable car. I may do another Midget, but the wife realy wants a big Healey. She may have to settle for an MGA or such.
R
r67cat
There is a lot of new metal in this Midget. Replaced:Rt&LT inner and outer rockers,both lower door hinges and lower A post,Rt&LT rear outer wheel wells, Rt&Lt rear lower fenders, rear valance, reskinned both doors, new Left front fender, drivers floor and forward foot well and part of the trunk floor. What ever was rusted I replaced. Time consuming but wanted to learn to gas mig weld, with a little practice even a Dentist can become a pretty good welder. A lot of satisfaction to see the car come togeather. Hopefully it will be something my daughter will appreciate.
NW_SpriteGuy
r67cat,
I just finished looking at the pictures on your web page. Very nice! Now that you've completed the project and it's been awhile, was it worth it?
You obviously spent more time, effort and money on the rebuild of a car that's doesn't generally command high a value. I've got to think that no matter what, its got to feel good and rewarding to look at your accomplishment and the knowledge you learned from your endeavor. It's a great accomplishment - congratulations! Would you do it again?
-Don
Bugeye58
r67, now that you're all practiced up, I've got a few sitting around that you can practice some more on!
Seriously, it looks like you did a thoroughly fine job. I'm not all that far from Grand Ledge, so when the weather regains its sanity, in about eight months, maybe I'll motor over.
Jeff
R
r67cat
Bugeye and NW, Interesting question as to weather I would attempt such an extensive reshell. The fun was working with my then 12 year old daughter, showing her how things go togeather( and come apart) She was the polisher and the bagger of the parts. These cars are quite simple to work on and that also made it fun. This could not be the type of project one could undertake with the idea of getting their money out of. Out of all my cars (all of which get driven often) the Midget gets more thumbs ups than any of the other cars. People remember these little cars and are amazed to look in or under the hood and see a brand new 1971 car. Would love to have anyone who is in the area stop by. Rick
tony barnhill
Great Pumpkin - R.I.P
r67....tell me how you reconditioned those early Midget rostyles...I've a set I want to put on my '74 round wheel arch...did you chrome part of them or is that just real nice chrome paint?
R
r67cat
Tony, First bead blasted the wheels, shot them in silver, then using fine line tape, taped off the silver highlights, shot them in black then cleared them. Used Dupont chroma color base/clear. added the polished rings. Probably over kill but they should remain nice for a long time. Rick
I'm considering buying a set of Minlite "lookalike" rims for my '70 RWA midget (don't ask
) but after seeing how nice the early rostyles look on your car, I may just refinish mine.
tony barnhill
It took me too long to come up with 5 good early Rostyles...thanks, I'm going that route on my RWA Midget!
Winston
Beautiful job!
Getting ready to do inner and outer rockers myself next season. You're sure right about the thumbs up.
Winston: Triumph TR4A IRS
R
r67cat
Winston, when you are ready to replace the inner and outer rockers, be sure to leave the doors attached to help keep the unibody straight. Support the floor and be sure the gaps remain correct around the door. You may notice the gaps changing as you remove the rockers. I adjusted the gaps by raising or lowering my floor jack that was positioned at the jacking point tube. I placed jack stands at the front of the rear spring, and the engine crossmember. Time consuming but not that hard to do. I borrowed a 120V spot welder to duplicate the factory weld. If I can be of any help let me know. I have lots of pictures. Rick
Gary Lloyd
Nice job!!! If you are like me, when I ws done with my '66 'B, I was wondering why I didn't get a better shell!! You did really well!!!!!
A 100/6 BN4 Restoration Austin Healey 8
S Wanted Used Austin-Healy 100/100-6/3000 Restoration Guide By Gary Anderson And Roger Moment Austin Healey Classifieds 14
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
Greg Chait Wanted Stalled or Abandoned MG Restoration Projects MG Classifieds 3
H General MG MGYB--Semi-- restoration MG 2
D My new restoration tool Restoration & Tools 13
D For Sale 1955 DAIMLER CONQUEST RUNS NEEDS RESTORATION. Other British Classifieds 1
JoeO 72 TVR Vixen hybrid restoration TVR 1
Rob Glasgow Restoration: What Would You Have Done Differently? Austin Healey 37
GeorgeC Rich Chrysler's "Introduction to Austin-Healey Restoration" Austin Healey 3
D Fascia Restoration Austin Healey 14
J Restoration Progress - Boot Installed Austin Healey 1
C For Sale Parts, Factory Manual, Restoration Guide for 1959 100-6 Austin Healey Classifieds 4
BigGreen For Sale Anderson / Moment Restoration Guide for sale Austin Healey Classifieds 0
SteveTheBrewer Spitfire Triumph Spitfire Restoration Blog Triumph 22
R Tr4 restoration books Restoration & Tools 2
F YouTube Healey Restoration Videos Austin Healey 5
R TR2/3/3A Re-start after total restoration Triumph 22
F GT6 Looking to sell - in progress restoration Triumph 19
R TR2/3/3A Restoration of 1954 TR-2 Long Door Triumph 6
Don Riicardo Reliant Scimitar GTE se5a restoration Other British Cars 23
R TR2/3/3A Starting TR-2 for first time after restoration Triumph 58
Josandra 1949 singer nine roadster restoration by ladies Other British Cars 20
C SoCal Restoration Shops Austin Healey 15
HealeyRick Coronet Cream Restoration Austin Healey 1
H Restoration Magazines and Books Spridgets 4
W For Sale 1961 TR3a - Full Off Frame Restoration Triumph Classifieds 0
T BT7 Hardtop Restoration Austin Healey 6
nichola TR6 1973 TR6 Restoration - it’s a roller again! Triumph 4
Got_All_4 TR6 Starting my frame restoration Triumph 32
F General MG Field find restoration question ... MG 5
R TR2/3/3A Restoration of 54 TR-2 Triumph 6
Lin Fairly new YouTube series on AH100 restoration Austin Healey 0
S TR2/3/3A Frame off vs. body on restoration Triumph 21
D For Sale Custom 1972 Triumph Spitfire [Restoration Project] Triumph Classifieds 0
V TR2/3/3A TR3A Chassis restoration Triumph 8
Z For Sale 1954 Austin Healey 100-4 BN1 Beautiful Restoration Austin Healey Classifieds 0
Z For Sale 1954 Austin Healey 100-4 Beautiful Restoration Austin Healey Classifieds 0
J TR2/3/3A Body Restoration - Inner Sill Replacement Triumph 38
Jim_Gruber Pages from Porter Spridget Restoration Manual on Seat Recovering, You Tube Videos Spridgets 4
A TR2/3/3A Restoration work near San Diego CA Triumph 2
JPSmit Restoration on a Budget Restoration & Tools 4
F Restoration Guide Austin Healey 2
D For Sale For Sale: 1972 Triumph Spitfire [Restoration Project] Triumph Classifieds 0
T General TR Ron's Vintage Auto Restoration - Salado TX Triumph 2
C Looking for SoCal restoration shop Austin Healey 4
Popeye Post-War Other Mayflower for sale...needs full restoration Triumph 0
Michael Oritt Anderson/Moment Restoration Guide for sale Austin Healey 8
R TR2/3/3A Restoration of 1954 TR-2 Long Door Triumph 22
J TR2/3/3A Starting my TR3 A restoration Triumph 8
