Engine/Transmission for midget
Radride
Does anyone have a source to buy a 1275 engine and rib case transmission for my midget? Any help will be appreciated. I currently have a 948/smooth case. The cost to rebuild the 948 would end up being the same as a 1275. I understand the smooth case transmissions are not easily rebuilt and are not as robust as the rib cased. If I am wrong or off base let me know. The 1275/rib case sounds like a lot more fun!
jlaird
I would expect that you can not even find parts for the smooth case.
terriphill
You have a PM /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
D 70 Midget with New Engine & $10 eBay Transmission Spridgets 5
jhorton3 Midget Engine/Transmission Bolts MG 4
R Midget engine transmission question MG 4
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
KVH TR4/4A Assembling Transmission to Engine--Vice/Versa Triumph 4
AngliaGT WANTED - Cheap TD Engine/Transmission MG Classifieds 0
Bob Claffie For Sale Engine/transmission MG Classifieds 4
M MGB Early MGB engine compatible with later transmission MG 2
M For Sale BN-1 with spare engine and transmission Austin Healey Classifieds 1
S MGB early transmission vs od transmission for 3 main engine MG 5
R Remove engine/transmission advice needed Austin Healey 4
P 100M overdrive disengages on hot engine/transmission Austin Healey 9
JamesD For Sale BJ8 engine & transmission parts Austin Healey Classifieds 3
A Wanted MGC 6 cylinder straight in line engine and transmission MG Classifieds 3
R TR2/3/3A Miata Engine and transmission Triumph 12
N MGB Engine & Transmission / Gearbox MG 9
R TR2/3/3A Engine/transmission rotatio Triumph 2
T TR4/4A Remind me on pulling an engine and transmission together or seperate Triumph 11
KVH TR4/4A Dropping the Engine and Transmission Back onto the Mounts Triumph 22
T TR2/3/3A Can I run engine in car with no transmission? Triumph 7
M FOR SALE: 280i 2.8 v6 engine and 4 speed transmission for sale TVR 2
mcmillal TR4/4A Engine / Transmission Rebuild Triumph 1
DanLewis 1275 engine and ribcase transmission $750 [NFI] Spridgets 0
coj Healey numbering system, engine, transmission, body etc. Austin Healey 3
Boggsy64 MGB Transmission engine mounts and front engine mounts MG 0
D Alternative engine/transmission compatibility Spridgets 72
drooartz Plans for my "free" engine and transmission MG 9
Kleykamp Transmission/engine mount removal Triumph 4
L Ribcase transmission with 948 engine Spridgets 8
M Wedge TR7 Engine, transmission and more to go Triumph 0
I Engine/transmission installation help please. Spridgets 20
G Early 100/6 engine, automatic transmission Austin Healey 2
drooartz Bolts for engine -> transmission Spridgets 3
QuickSilver OT: Value Of A 1977 MG B Engine & Transmission MG 2
L 3000 Transmission Removal, alone or with engine? Austin Healey 16
philman Wedge Removing TR8 engine+transmission Triumph 10
R Stag stag engine and transmission Triumph 7
Luke_Healey Transmission leak or overfill? 1098cc engine Spridgets 9
W Weight of engine and transmission Spridgets 8
B Finally - Engine and transmission installed Spridgets 22
A Weight of Engine and Transmission Spridgets 1
Lucas63 TR4/4A TR4 Engine and Transmission Weight Triumph 5
RobSelina Latest on engine vibration and transmission whine Spridgets 2
R TR2/3/3A Engine revs up and down Triumph 3
kodanja TR2/3/3A 1960 TR3A w/TR4 engine, fuel pump replacement Triumph 14
L General Tech Engine id Triumph 9
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
