newmexTR3
so... left this evening from brooklyn, made it half way to Buzzard's Bay doing 70-75 when suddenly the exhaust note changes and I lose a little power. I pull over to the next gas station thinking maybe one of my plug connectors had come loose. I change out the wire just to make sure, still no change in sound. Then I take off valve cover and lo and behold the #7 intake valve pushrod is sitting 3 inches below the rocker arm!
I jiggle it and it dissappears into the head. Luckily, in my emergency parts kit i have some chicken wire, and after removing rocker shaft I am miraculously able to remove both halves of the rod. Tonight I'm staying at a motel and hope to drive the remaining 90 miles early early, get a new rod overnighted and then install on Friday.
Is driving without the rod for that long extremely inadvisable? Since it's on the intake I don't think I will damage the head with it overheating as i could if it were the exhaust valve.
Also, what could have caused this? I changed my valve clearance to .014" a few weeks ago and had a great drive out to PA and back- a few hundred miles, no problems. Should I put the valves back to .010"? I have a nonstandard cam in it, but it was installed years ago and I'm not sure of the specs on it. Would having the valve clearance too loose cause this sort of stress at high speed?
Thirdly, do I just order one pushrod? or should i get new ones all around? Anything else I should do?
thanks! Another chapter in the love/hate relationship of me and my car. Could have been much much much worse i suppose.
Cheers,
Gavin
Cheers,
Gavin
