Electronic Conversion on an SU Fuel Pump?
Russ_S
I want to switch my AH 3000 to an electronic pump since it sometimes sits for months and I don't want to deal with sticking points anymore. My pump is relatively new so I was wondering about one of the SU electronic conversion kits, anyone use one and how well do they work? Thanks!
I attempted to install a coupe of Burlen's kits a few years ago. One worked, one didn't. Dave DuBois, who is no longer with us, developed and fitted his own design. I think he said his return rate was about 5%. Electronics seem to work until they don't. There's no banging on the pump to make it work long enough to get home.
Folks would ask why I had a lump of a granite rock on the rear floorboard of my MGB. I always told 'em it was for a wheel chock... that rock got me to the end of Alligator Alley once when the points in the fuel pump acted th' goat half-way across. No amount of whackin' the bulkhead would have done that with a transistor powered pump.
MGBGT_noob SU Fuel Pump, Electronic Conversion? Restoration & Tools 1
T MGB Vacuum advance and Electronic ignition conversion MG 5
S TR6 TR6 speedo to electronic conversion anyone? Triumph 15
rosalind electronic ignition conversion - advice please? British Motor Corp 3
Brosky Gauge calibration and Electronic Tach conversion Triumph 12
TheAssociate Spitfire Spitfire Electronic Tach Conversion Triumph 11
ObiRichKanobi Electronic Ignition Conversion Triumph 3
B TR6 TR6 Electronic Ignition Conversion Triumph 10
G Crane XR700 Electronic Ignition / BT7 Austin Healey 6
PAUL161 T-Series Points Triggering Electronic Ignition MG 5
TRickster6 MGB electronic ignition on '73 MGB MG 1
algot1901 Electronic Ignition for 1950 Prefect 1172cc Eng Other British Cars 10
Lin Crane or Fast XR700 Electronic Ignition Austin Healey 4
Basil Electronic Clutch [Deleted] Other British Cars 9
Magyar Rebuild Speedometer & Tachometer - mechanical or electronic? Spridgets 17
Lin Installation Notes for 1-2-3 Electronic Ignition Austin Healey 1
vette Just a note to Bill Young about his work with the electronic tachometer. Austin Healey 2
O Sprite Petronix Electronic Ignition Spridgets 10
S General Tech Electronic store for quality connectors. Triumph 9
S Fried electronic ignition? Austin Healey 22
F TR2/3/3A Timing with Electronic Ignition Triumph 14
B Crane Cams Electronic Ingnition Austin Healey 9
S Wiring connections for electronic ignition BJ8? Austin Healey 3
rjc157 bn7 electronic choke Austin Healey 0
matmire Crane XR700 electronic ignition, now FAST XR700. Spridgets 12
S TR2/3/3A Tr3/4 electronic distributor Triumph 2
Marvin Gruber TR5/TR250 Pertronix vs Crane electronic ign Triumph 1
T TR2/3/3A electronic distributor problem Triumph 3
B Question about Dual Polarity Electronic Fuel Pump - How to Connect Wiring? Austin Healey 9
F Swapping out original 1098 distributor to electronic Spridgets 13
L Electronic ignition? British Motor Corp 4
S TR4/4A Electronic Ignition Recommendations? Triumph 14
PAUL161 General MG Crane Electronic Ignition MG 9
S will old style distributer cap work with electronic ignition on AH Austin Healey 8
Keith_M SU Electronic Fuel Pump Spridgets 3
DanLewis Electronic tachometer for Bugeye Spridgets 18
R Electronic Ignition Distributor Spridgets 14
JPSmit Electronic Rust Inhibitors: works? - or snake oil? Restoration & Tools 8
D Electronic Ignition for 25D distributors Spridgets 15
D Timing with an electronic distributor? Triumph 14
Scotsman Pertronix Flame Thrower Electronic Distributor Triumph 7
bighealeysource LED bulbs and electronic flasher module issues Austin Healey 26
M Fuel Flow problem with new Electronic SU Pump Austin Healey 2
drambuie Anyone using flame thrower Electronic distributor Austin Healey 6
sundown TR6 TR6 electronic ignition Triumph 10
mountainman pertronix electronic ignition hepl please Triumph 10
D TR6 TR6 Electronic Ignition Triumph 16
PATR8 Wedge More TR 8 electronic questions Triumph 2
T Electronic Ignition Issue Austin Healey 6
wkilleffer Anyone familiar with GM Electronic Climate Control Other Cars 11
