Louis 52MGTD
I just bought a 1952 mgtd, it has a charging prob. slightly below normal, when I looked under the hood I noticed the batt. Plus cable is going to the starter switch and the batt. neg cable goes from the batt. to a ground on the gen. case. the wiring chart says the car is a positive ground ? it has been driven like this for a while. should I switch the cables like the book says or will that cause a prob. with blown fuses ? I am weak on elect. thanks for any help. Louis
