MGB-GT Easy come, easy go -- my GT is sold
drooartz
Been a bit of an odd week. I had an opportunity come up early last week that required some extra cash on hand, so after some discussion with my wife I contacted a friend in my local car club that had shown some interest in the GT. Even though I ultimately passed on that opportunity I decided to follow through with the potential sale.
The folks came by today to look at the car and his daughter bought it -- her '70 GT is truly rusty and mine was in much better shape. It goes to a great new home and I've got all the resources needed for finishing up Penny Bugeye. Couldn't be happier with the new home for the car.
A short tenure for sure. With the motorcycle gone and now the GT as well, I've got all this space and time now. Ultimately, that's worth a lot to me.
Congrats (dubiously) Only because it means you won't have a driver this summer - other than that, good news!
Thanks. I actually got out on my bicycle this week, so maybe I'll use that lack of a driver to get back into shape. We can dream...
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Basil Easy way to clean fuel injectors (out of car) Other British Cars 2
T General Tech Once again, check the easy stuff Triumph 2
Basil Easy[er] way to get frozen brake rotors off Restoration & Tools 13
hondo402000 TR6 TR6 Fuel Injection made easy Triumph 12
H Typical Easy Project takes me 2 hours. Spridgets 5
H Steering Wheel Removal after being attached for 58 years. Nothing is easy. Spridgets 6
maxwedge5281 easy to get side-tracked! Austin Healey 5
steveg Wanted - easy install tool or technique for directional/stop light lenses Austin Healey 9
Jim_Gruber Need help to figure out an easy solution for this one. Spridgets 13
4tecdog Headlight relays the easy way Austin Healey 13
CZ_Dave MGB Easy off Oven Cleaner!?!?!?!? Yuppppp! MG 9
Joe Reed MGB Another easy fix....upper radiator bracket MG 5
tomshobby General TR making it easy to lube door hinges Triumph 0
J Nothing is ever easy! Austin Healey 12
max71 MGB The easy way to get the oil pressure relief cap nut back on MG 8
T Post-War Other Nothing's easy Triumph 6
andrea PROP ROD BONNET RATTLE easy solved Austin Healey 9
J Poly Lower A-Arm Bushings - One easy question as I am confused Austin Healey 1
RAC68 EASY Sunday Morning Austin Healey 1
M Tie rod end came apart easy - too easy? Spridgets 6
H two easy questions Austin Healey 14
Boggsy64 MGB Rear end washers easy MG 1
T It's not easy being Green Triumph 7
Cottontop Don't we WISH it was this easy Restoration & Tools 5
HealeyRick 1500 Engine Rebuild Made Easy Spridgets 5
58Custom Is it easy to convert a '69 US dash to a pre-67? Spridgets 21
Brosky Easy add on fuse block Triumph 7
HealeyRick Restoring a Healey is Easy Austin Healey 7
glemon Quick Easy Removeable Cupholder Triumph 4
Trevor Jessie Easy overview of rocker geometry Spridgets 11
Morris If only it were this easy...[ a bit OT ] Spridgets 5
JPSmit Light hit, easy fix Other Cars 4
58Custom Iinstall pre-pillow dash in pillow-dash car? Easy? Spridgets 2
dklawson Solvent Pop - Is There an Easy Fix? Triumph 10
T Why couldn't it be this easy? Triumph 6
H JACK MODIFICATION FOR EASY REAR END LIFTING Triumph 9
A Easy way to remove Cylinder head? Triumph 13
Jim_Gruber Starter goes Click-Oh how easy this car is to fix Spridgets 1
steveg Easy simple product helps eliminate gas gauge flu Austin Healey 0
germanmichel Easy way to move the 3litre engine out of the car? Austin Healey 7
N T-Series Is there an easy way to remove clutch M/C? MG 4
drooartz Bugeye engine removal is easy! Spridgets 8
B MGB 72 mgb speedo drive seized.....easy fix? MG 11
T TR6 Fry a TR6 electrical system in these easy steps Triumph 16
6 Please say it's easy...Dash pad removal Austin Healey 4
Jayrz Oh that was TOO dang easy! Spridgets 8
S Here's an Easy One - Inner Tube Question Triumph 14
T TR4/4A TR4A floor pan removal - easy or hard? Triumph 7
SCguy TR6 Easy way to install rear gaiter on TR6? Triumph 5
