T
TRDejaVu
This Winter I had a couple of posts asking specific rear suspension questions; thank you to those that offered advice.
This post is a bit about the leaf spring clean up, but mainly about the tube shock conversion that I decided to try.
The following is not intended to be used instead of workshop manual or vendor instructions. If in doubt have a professional do it with the proper tools and equipment; does that cover me for liability legalese?
Following the advice of others here, I dismantled my leaf springs to find the expected rust and some pitting.
I cleaned these up with wire wheel, careful use of an angle grinder and coarse abrasive discs. I primed them with Eastwood Rust Encapsulator then top coated with Rustoleum Pro.
Then following the advice of TeriAnn Wakeman and Randall I applied 2 inch UHMW tape to the upper surface of the spring leaves.
Next step was to replace the front spring hanger bushing with a Moss replacement (no pic). I then fitted the Joe Alexander rear spring hanger bushes. Really nice fit that required them to be pulled into place.
On to the tube shock conversion. Firstly, full disclosure. I came to an arrangement with Moss where I would review their Tube Shock Conversion kit (good or bad comments), but I did not get the kit for free.
Moss says that my kit is for cars up to CT23382.
A close up of the upper and lower shock supports. Notice that the lower one has a tie-down fitting for use when trailering.
You replace the original lower lever shock attachment fitting with their replacement. I had all my springs apart, but if you are doing it without going that far then use all the appropriate safety procedures when dealing with a loaded spring.
The Moss kit requires you to drill 2 new holes in the shock mount support structure of the car frame. They say to bolt up the upper shock mount using the 2 existing lever shock mount holes and then drill through with a 3/8 drill. I felt more comfortable drilling a pilot hole using a pilot bush. I then opened that up to just below 3/8 and used a reamer to reach the final size. Overkill, probably, but I had the tools from my aircraft days and I knew that I wouldn't have any problems with it. The holes were then painted for protection. Pilot bush in bottom right hole.
I did notice that the new holes came close to an unused blanked off hole. There are 2 stiffening pieces on the backside of the tower.
Everything else was a simple bolt-on job.
Upper shock mount setup
Lower shock mount setup
Complete assembly
I took the car for a short drive this evening; first of the season - yippee.
Not having driven it since last Fall, coupled with the leaf spring cleanup, UHMW tape and the new hard racing bushes makes an instant comparison difficult. That said I think that the overall effect is a more comfortable ride (for a leaf spring). I was babying it, but I tried a couple of quick tight corners on a country road and the car tucked right in nicely. I look forward to driving it harder and reporting back once I have let it settle in and rechecked all the bolts as necessary.
Comments on the kit. Time will tell if the design causes problems due to the different geometry and loads on the frame. The pieces appear to be very solid, but I have to say that the finish could be better (given the list price) as it was painted and not powder coated. People who want to do this conversion will have to judge for themselves whether the price is right as it is quite a bit more than the IRS tube shock conversion kit. That said, I am looking forward to driving it this Summer.
Complete assembly
