Dual Control Healey
HealeyRick
I find it a unique story with history...but I don't think for a minute it is a rare factory built car. Correct me if I am wrong. I think the seller is trying to paint a picture of it all being done at the factory or dealer prepared but I think it is more of a Hollywood style prop car.
Oh I don't know, I've seen a lot of monkeys driving Austin Healey's, was it a woman or a man monkey?
R Bugeye dual horns Spridgets 16
Ripper01 SOLD-TR6 Dual Port Exhaust Manifold Triumph Classifieds 6
eschneider Spitfire Float height - '64 spitfire w/ dual HS2 Triumph 1
drooartz MGB Swapping to dual SU on later MGB with brake booster MG 7
Merlin63Tr4 TR4/4A Triple to dual exhaust valve spring conversion done wrong? Triumph 7
B For Sale MGA JAeger Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer MG Classifieds 0
B For Sale Austin Healey 100 Smiths Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer Austin Healey Classifieds 0
M Mallory Dual point distributor Austin Healey 0
aero3113 100-4 dual gauge Austin Healey 16
G Front end Alignment - Total Toe vs. Individual Toe Austin Healey 3
B Dual Circuit Brakes Austin Healey 3
B MGB New Dual SU's and Run-On MG 3
S For Sale Triumph Weber DGV dual Carb Set Up - $325 Triumph Classifieds 0
AHS TR2/3/3A Residual brake pressure valve - how much front wheel drag? Triumph 18
B Mallory Dual Point gap Austin Healey 4
apbos Interesting dual cylinder Bugeye setup Spridgets 6
F General MG Help needed with su dual carburetor identification MG 4
A TR4/4A TR4A dual exhaust specs Triumph 3
T TR2/3/3A Dual circuit brakes Triumph 2
longbridgehealey Longbridge built 100-6 dual washer nozzle Austin Healey 6
PeterK TR4/4A Never seen a dual exhaust cobbed this bad before. Triumph 2
B Question about Dual Polarity Electronic Fuel Pump - How to Connect Wiring? Austin Healey 9
andrea Dual Beam LED Head Light Cree Austin Healey 4
steveg Fiat Dual Master Cylinder Austin Healey 7
maxwedge5281 dual circuit braking system Austin Healey 29
B TR6 Anyone know where to get a decent Exhaust Manifold for 72 TR6 [dual] Triumph 2
C Mallory dual point recurve help needed Austin Healey 6
richie TR4/4A Dual circuit brakes in TR4 Triumph 16
M Oil Feed Pipe to Dual Gauge Spridgets 9
D Dual Circuit Brake Bleeding Triumph 7
Lynn Kirkpatrick Bleeding dual system brakes & how do they work? Restoration & Tools 5
CinneaghTR TR4/4A TR4A Dual Exhaust Question Triumph 4
G 1500 dual SU/ DCOE throttle cable question Spridgets 5
memphis Pertronix & Mallory Dual Point [Positive] Austin Healey 11
W Dual Guage restoration Spridgets 10
E BE Dual Brake Line Switch Assembly Spridgets 0
R dual springs for 1500 engine rocker arm upgrade? Spridgets 3
B Dual exhaust for 100-4 Austin Healey 0
hymodyne TR6 TR6 dual chain sprockets Triumph 3
K dual master cylinder Spridgets 3
E BE w/dual line brake master....90 degree fitting? Spridgets 12
M Rebuilding Dual M/C Spridgets 1
letemglow Brake line layout with dual master cylinder MG 6
D DUAL WEBER 45 MCHH TRIUMPH CONVERSION KIT Triumph 2
G 1500 Dual Carbs in, rims lost in space... Spridgets 12
D pertronix for mallory dual point Triumph 5
A Dual SU carbs pacesetter exhaust MG 0
RickB Midget 1500 dual circuit Master Cylinder troubles Spridgets 7
svtmikey Spitfire GT6 and Spitfire Dual brake M/C differences Triumph 9
E Dual Brake Line Fitting Spridgets 4
