TR2/3/3A driver side on the trans-cover?
Funny thing is, that hole is present even on earlier cars with no fill plug (only the dipstick hole, which has its own hole in the trans cover).
Many (including me) have added a hole about there for that purpose -- but to be practical it will probably need to be larger. I made mine to use the same rubber plug above the U-joint, others made it even larger and use a jack-hole plug.
Could it be for the OD wiring? It would have contained a rubber grommet to protect the wires. I agree it is probably too small for a trans. fill plug access.
Berry
Bonus points for Berry I believe. Pretty sure that was the factory location for routing overdrive wiring.
Berry
Lots of folks think so, but I don't know of any evidence that the factory did it that way.
TS39781LO came to me with a solid plug in that hole and what appeared to be original OD wiring routed through one of the grommets in the firewall. Of course one of the previous owners could have re-routed the wiring, so that doesn't prove much.
Also, if you look closely at the photo of the OD relay in the workshop manual (in the section about adding OD), the wires appear to run forward from the relay towards the firewall instead of off to the side towards that hole in the tunnel.
Yeah, you can go really crazy trying to make sense out of the Moss website. For example, that page lists 680-630 as a "plug", but there are some 50 other pages where it is listed as a "grommet".
Also, that page shows no part number for the "non-overdrive" condition, but an older PDF catalog lists 682-510 as plug, non-overdrive. And 682-510 is still listed as available on roughly a dozen other Moss web pages.
My guess is that they tried to remove the listing for the grommet (after learning it wasn't used for OD wiring), and didn't do a very good job.
As a counterpoint, the factory parts catalog gives a very detailed listing for the overdrive kit (used to add OD to non-OD cars), including the wiring harness, clips, etc. No mention of a grommet.
That hole is for the OD wiring, and it does have a grommet to protect the wiring as it passes thru the tunnel. My 1957 TR3 came with OD and the OD wire went thru that hole (with a grommet). There are connectors on the OD wire that you can disconnect if you have to remove the tunnel.
Chuck
Chuck
Mine too. 57 TS19909 LO
F Wanted wanted new old stock driver side door latch Triumph Classifieds 2
S TR2/3/3A foot well driver side carpet Triumph 3
J BJ8 Phase 1 left turn signal [driver side] Austin Healey 16
55modified Should I remove driver's side fender to work on footbox on my BN1? Austin Healey 14
Tinkerman TR2/3/3A 19960 TR3A driver side rubber shield Triumph 6
C Driver's side defroster vent FORUM Navigation Questions 1
O Need front driver's side fender 65 Midget Spridgets 0
af3683 TR2/3/3A TR-3 Defroster Hose on Driver's Side Triumph 4
davidb AH 3000 BJ series driver's side mirror Austin Healey 23
mgnewbie need driver-side door mirror MG 3
TonyPanchot Driver side, rear spring Triumph 6
Newkie Driver side is lower? MG 13
tosoutherncars Driver's side CB fender needed Spridgets 3
theleisure Trouble Refilling Driver's Side Shock Spridgets 3
T Wedge TR8 driver side floor pics - not for the squeamish Triumph 7
bighealeysource Replacing driver side floor Triumph 10
19_again driver's side lower MG 1
AngliaGT Wanted Two inside window handles & Regulator for Driver's Door - '67 GT MG Classifieds 6
AngliaGT MGB-GT WANTED: Driver's Door Regulator + Two (2) interior handles. MG 1
Got_All_4 For Sale 1969 TR6 Driver Seat Triumph Classifieds 0
E For Sale Driver quality 1963 Healey 3000 mark 2 Austin Healey Classifieds 1
LAW75 Driver's and Passenger's Floor Carpets Austin Healey 7
idlehands Wanted WTB GT6+ driver (LHD) window glass and a single rostyle wheel cover Triumph Classifieds 1
K TR2/3/3A Optimum Tire pressure for a TR3 daily driver? Triumph 5
J Wanted Driver Seat Frame For a 1976 Triumph TR6 Triumph Classifieds 0
F Driver's Handbook AKD 1102, AKD 1102A Austin Healey 26
69MGC MGB MGB Driver Magazines FREE MG 4
60TR3A Driver's Door Won't Stay Open Austin Healey 1
S TR2/3/3A driver door problem Triumph 12
Joe Reed General MG MG Driver back issues....FREE! Anyone want them? MG 4
GTP1960 Nice driver VW Transporter T2. 1970? Other Cars 0
GTP1960 1956 MG Magnette ZA daily driver Spotted 6
glemon General TR Daily Driver Triumph 18
L What is your daily driver? Austin Healey 66
CanberraBJ8 Hundred M - for sale on Classic Driver Austin Healey 7
TRspitfirefan Spitfire LeMans racing driver with good taste in cars. Triumph 0
RJS Driver's door lock cylinder Triumph 3
Gerard MSD Tach driver w/ Spridget tach Spridgets 15
dougie Canadian Grand Prix - Driver's Parade Austin Healey 2
G Sad ending for this Triumph & driver Triumph 31
M Driver seat adjuster spring? Spridgets 3
G Driver's door hinges. MG 2
jlaird What an F! driver sees Spridgets 2
D daily driver value Austin Healey 21
J Driver's Seat Hinge for Back Rest Jaguar 5
Darrell_Walker Wedge Thought exercise - a wedge as a daily driver? Triumph 86
D Anyone use their B as a daily driver? MG 29
D Finally!!!! A Driver Triumph 12
jlaird Screw driver Spridgets 5
G longbride driver handle hardware & key lock needed Austin Healey 2
