T
Tinster
Our dizzy thread got accidentally deleted.
I lost much of the info. that was posted.
I need the tail end posts again to attempt
to start the Crypt car.
Current Crypt car status:
Installed as on Sunday:New dizzy, new electronic ignition
(new points as spare)new cap, new plug wires, new plugs,
new battery, all new Dan Masters Power bloc wiring harness,
new ignition switch.
Piston No.1 is for sure TDC now.
I bought those feeler thickness fingers and set the
spark plug gaps and with Bentley gave it my best shot
at adjusting the 12 valves. I Ordered two new valve cover gaskets and a new fuel pump.
I got two new dizzy mounting bolts and torqued down the
unit ay No.1 TDC. I noticed the bolts went thru slots which
allowed some movement in position. Are these timing
adjustment screws?
Bill- What was that gasket goop you told me to use?
I had already figured I would use clothes pins to hold
it in place.
Now a curiosity of sorts.
The Crypt car ran for maybe ten to 15 minutes total
before it died. I had just managed to get the new carbs
to a flucuating rough idle at between around 900 to 1200,
if I recall.
Yesterday when I gapped the plugs: No1, 2 and 3 were nice
light tan. No 4, 5 and 6 were carbon black and greasy to
the point I cleaned them with 600 grit emory paper.
The new carbs are not yet tuned, I was first trying to
get a constant idle when the car died. Any suggestions what
I might do to the carbs before I try to crank up the Crypt car in a week or so?
Sorry for the long post, much to relate today.
thanks as always,
dale /ubbthreads/images/graemlins/grouphug.gif /ubbthreads/images/graemlins/grouphug.gif
adjustment screws?
it in place.
if I recall.
thanks as always,
