DIfferent heaters---under dash or front of battery
fordtrucks4ever
I have noticed Jacks and newer Sprites have the standard heater core in box front of battery. My heater is located under dash and has a radial core. I have seen other Healeys use this one, but dont find any info on them.
Looks foreign to a Bugeye. Wonder why anyone would have done that modification other that the fact that the original Smiths heaters are only marginally effect in very cold weather?
Was prob done to keep warm. Bugeye heaters out of the box are not much good. Mostly need a stronger motor.
Re: DIfferent heaters---under dash or front of bat
Morris Minor or some other heater. Could be TR but I don't know what they look like.
I do know that there were 4, yes FOUR different heater configurations for the Sprites and Midgets over the years.
What gets me is the there is a block off plate, with gasket, where other heater would go. All duct work was plumbed in as factory would have done. Stock blower switch is plugged in with original connectors. It isnt installed like an after thought. The hole in firewall for both hoses is oval in shape with gromet. All mounting holes thru vinyl covered interior panel look to be punched thru and fitted. No hack work. This is a right hand drive car that wasnt imported to US until 1962.
My vote is a TR3. Looks like the one in the Moss TR3 catalogue to me.
Also MG T Series Option! /ubbthreads/images/graemlins/rolleyes.gif
Got 2 of them sitting here! /ubbthreads/images/graemlins/crazyeyes.gif
Ed
Early Land Rovers used a similar item. The Early Morris Minor unit is similar in that it also has a round matrix, but the rest of the housing is totally different.
The round Smiths units can be very effecient if the matrix is properly flushed out, and the operating valve is not crudded up.
Check out this ebay listing. Same unit?
Factory Triumph TR2 TR3 Genuine Smiths Heater Assembly Item number: 250048043602
Similar but different model, plus uses a mounting bracket not needed on BE. This might not be factory installed in my BE, but if fits too well to be someones home brewed adaptation. There are no provisions for any parts of the stock heater assembly. All cables and switches are routed and fitted correctly to this unit. Maybe an available bolt in unit if car didnt came with a stock heater. What I do like is no large air intake hose or routing of parts around motor. Its clean and plenty of clearance.
I just noticed how much that rattlecan painted heater sold for. Thats more than I have in my whole car. Do a nice resto on mine, sell it and then buy all of the sheetmetal I need to finish the body. Oh wait, that wont work, I planned to reproduce all the floorpans and ribbed panels myself. Already started making the dies to form the reinforcing ribs on floorpans.
C TR2/3/3A Three completely different questions from a TR3B newbie - thanks for any input! Triumph 6
T TR4/4A Why are distributor base plates different, is this a problem? Triumph 7
tr6nitjulius General TR Different Times Same Glory! Triumph 3
JPSmit and now for something completely different Spridgets 8
K TR2/3/3A Gas tanks...two different types? Triumph 5
AngliaGT Something Different Spotted 3
H Is there any difference in using the 1275 Float Bowl that have a different casting? Spridgets 6
J Exhaust pressure extremely different between pipes? Austin Healey 20
R TR2/3/3A different hub collars Triumph 7
M SU H-1 Carbs: Are These Just Different? Spridgets 2
Got_All_4 General Tech Different style synchros which is better Triumph 4
Joe Reed MGB A little different DGV installation... MG 12
jmayzer different part, same situation Spridgets 11
bugedd Got her leveled out, now with different wheels Spridgets 11
David Townsend TR2/3/3A And now for something completely different Triumph 2
aeronca65t This is a different Spridget Spridgets 6
M Clutch problem, a little different than usual Spridgets 8
C Wiper arms different lengths? - BJ8 Austin Healey 6
V TR2/3/3A Something Different Triumph 20
Lukens TR2/3/3A Are there different lengths for stator tubes? Triumph 3
T General Tech How different is NPT thread from BSP thread? Triumph 2
aeronca65t "Different" Swap Sunbeam (Rootes) 3
zedvictor1 Spitfire different diff for Spit 1500 with overdrive? Triumph 1
KVH TR4/4A Two 4As--why so different? Triumph 4
J Different Shifters? Spridgets 3
Xte Two different springs in distributor ignition ? Austin Healey 4
CZ_Dave Well, That was different! MG 4
aeronca65t A "different" E-Type Jaguar 4
M exhaust sound different. brith/jap Spridgets 14
Sherlock Something a little, ahem, different... Other Cars 3
rlich8 TR4/4A How is the TR3 different from a TR4A Triumph 7
BugeyeNJ58 Different lengths of wiper motor cables? Spridgets 9
glemon TR6 TR250/early TR6 v. late TR6 Different Speedo Ratio Triumph 4
Trevor Jessie Different type of forward tilt. Spridgets 5
AngliaGT A Few Different Ones... Spotted 0
H Car's personality different based on paint color? Austin Healey 7
S And now for something COMPLETELY different...... Other Cars 7
lbc_newbie Things are different in SC! Spridgets 3
T Spitfire A different Spitfire gas cap question Triumph 3
Trevor Jessie Siblings can be so different. Spridgets 1
BugeyeNJ58 PCV Valve - can I use a different type? GULP VALVE Spridgets 5
T OT - saw the hanger from a different POV today Triumph 13
Sherlock A rather different motorbike... Other Cars 6
glemon Angle Drive Speedo Cable Different Size Ends Triumph 12
G A horse of a different color Spridgets 26
theleisure 1098 & 1275 Oil Pans-- Same or Different? Spridgets 4
Hap Waldrop A different approach Spridgets 12
Rob Glasgow Wow, now that feels different... Austin Healey 20
T different vacuum timing thread. Triumph 13
C Different springs for different years??? Spridgets 16
