Different Cross Members
vping
Bronze
I thought I read somewhere the the earlier MGB's had a different cross member. There was a hook welded to the front for towing. Later cars had the hook attached under the bumper. Is this true and if so does anyone have a pic of a '67?
Steve_S
Early cars do have an eye wended to the front of the cross member. It was deleted from later Mark Is.
I can send you a photo of a '67 cross member but it won't look any different than the early ones, except for no eye welded on.
tony barnhill
Great Pumpkin - R.I.P
& I've got several in a stack of cross members.
vping
vping
Bronze
Does anyone know about what Vin # they were deleted?
No worry on the pic. I wanted to compare to the one I have which I might send out to have powdercoated. It's going to be for one of my 67's.
twigworker
The eyelets on the later cars were not for towing. They are on the front and the rear and were there as something to tie to when the cars were on the tractor trailer carriers.
Jack
C TR2/3/3A Three completely different questions from a TR3B newbie - thanks for any input! Triumph 6
T TR4/4A Why are distributor base plates different, is this a problem? Triumph 7
tr6nitjulius General TR Different Times Same Glory! Triumph 3
JPSmit and now for something completely different Spridgets 8
K TR2/3/3A Gas tanks...two different types? Triumph 5
AngliaGT Something Different Spotted 3
H Is there any difference in using the 1275 Float Bowl that have a different casting? Spridgets 6
J Exhaust pressure extremely different between pipes? Austin Healey 20
R TR2/3/3A different hub collars Triumph 7
M SU H-1 Carbs: Are These Just Different? Spridgets 2
Got_All_4 General Tech Different style synchros which is better Triumph 4
Joe Reed MGB A little different DGV installation... MG 12
jmayzer different part, same situation Spridgets 11
bugedd Got her leveled out, now with different wheels Spridgets 11
David Townsend TR2/3/3A And now for something completely different Triumph 2
aeronca65t This is a different Spridget Spridgets 6
M Clutch problem, a little different than usual Spridgets 8
C Wiper arms different lengths? - BJ8 Austin Healey 6
V TR2/3/3A Something Different Triumph 20
Lukens TR2/3/3A Are there different lengths for stator tubes? Triumph 3
T General Tech How different is NPT thread from BSP thread? Triumph 2
aeronca65t "Different" Swap Sunbeam (Rootes) 3
zedvictor1 Spitfire different diff for Spit 1500 with overdrive? Triumph 1
KVH TR4/4A Two 4As--why so different? Triumph 4
J Different Shifters? Spridgets 3
Xte Two different springs in distributor ignition ? Austin Healey 4
CZ_Dave Well, That was different! MG 4
aeronca65t A "different" E-Type Jaguar 4
M exhaust sound different. brith/jap Spridgets 14
Sherlock Something a little, ahem, different... Other Cars 3
rlich8 TR4/4A How is the TR3 different from a TR4A Triumph 7
BugeyeNJ58 Different lengths of wiper motor cables? Spridgets 9
glemon TR6 TR250/early TR6 v. late TR6 Different Speedo Ratio Triumph 4
Trevor Jessie Different type of forward tilt. Spridgets 5
AngliaGT A Few Different Ones... Spotted 0
H Car's personality different based on paint color? Austin Healey 7
S And now for something COMPLETELY different...... Other Cars 7
lbc_newbie Things are different in SC! Spridgets 3
T Spitfire A different Spitfire gas cap question Triumph 3
Trevor Jessie Siblings can be so different. Spridgets 1
BugeyeNJ58 PCV Valve - can I use a different type? GULP VALVE Spridgets 5
T OT - saw the hanger from a different POV today Triumph 13
Sherlock A rather different motorbike... Other Cars 6
glemon Angle Drive Speedo Cable Different Size Ends Triumph 12
G A horse of a different color Spridgets 26
theleisure 1098 & 1275 Oil Pans-- Same or Different? Spridgets 4
Hap Waldrop A different approach Spridgets 12
Rob Glasgow Wow, now that feels different... Austin Healey 20
T different vacuum timing thread. Triumph 13
C Different springs for different years??? Spridgets 16
