For reasons too ridiculous to mention, I am thinking about redoing the skin, rubber and leather of this bright red beauty ( Series 11, UG2J52210) which I have owned since 1980. BUT, there are two running problems that keep popping up which raise my doubts.
1) the Stromberg-Zenith 175CD-2 Carbs which flood only when restarting up when the engine is hot. ( Typically, I go out for a cup of coffee, park for ten minutes ( minimum) and low and behold...flooded! Several experienced British mechanics have struggled with me on this with no real solution....
2) I have previously posted a description of "sudden death syndrome" ( these threads have been lost unfortunately), but it seems there is a coil-condensor-distributor problem that occasionally simply causes a loss of electrical current to the engine. I have frequently been stranded in embarrassing places ( middle of a bridge in rush hour for example!) with this problem, which seems to be entirely random.
Perhaps some genius in the crowd has gone through these issues and can help.
So far the only solution worth noting is simply replacing the engine with a Chevy block. But then I wouldn't have a Jaguar!
Thanks
Thanks
