Cold Plug site shutdown!
nomad
So is there anywhere that Berkeley folks hang out?? Maybe here???
Looking for a Berkeley bonnet or parts of one.
Kurt.
Thanks for the link. I don't own a Berkeley, but they fascinate me for their use of motorcycle engines. I used to race micro midgets, and I once owned a Vespa 400. nomad, have you posted pics of your Berkeley?
Dale, I don't own a Berkeley, but know of the site I mentioned. I was just a kid, (17), when I saw a new one at a dealer in KC Missouri back in 1957. I came close to buying one. I think it had a 3 cylinder engine, not sure though, too many years have gone by. It was just too small for me, but it was interesting. :laugh: PJ
try an email to bob santoro at alfacars aatt live ddoott com (trying to defeat the ever present spambots) while he is a daimler collector, i'm pretty sure he has some berkeleys too.
Thanks much guys, my Berk was originally baby blue and I think always in the midwest. I bought it in Wichita and it was a 3 cylinder but the engine has been gone for many moons. I just gave up sourceing an original engine since they would have required some mods to be reliable anyway and the last one I could have bought would have cost me 2K. That and it was in boxes which always makes things interesting.
So just bought a honda 400 4 that I will fit. No reverse but I can live with that.
No pics worth seeing at this time since restoration is about to begin.( have to figure out how to post them anyway)
Kurt.
Rig an electric motor for reverse.
I was considering setting up a starter motor to give me a reverse. We will see how cumbersome no reverse will be first. Car only weighs around 6oo lb.
Kurt.
There are motor cycle engine/transmissions with reverse. I could be wrong but, I believe Honda makes one. Don't know if their air cooled or not. PJ
Hi Kurt
I have a Berkeley that the PO put a Honda 360 motorcycle engine in. He did keep the original 2 stroke twin engine and gave it to me when I bought the car. Can you post a photo of yours? I have heard that a guy put a Honda 400 4 cylinder in his Berkeley but had overheating problems as well as other issues. I think I am going to fix a few small problems on mine and sell it if you know anyone looking for one. I have too many projects! Good luck, Eric
Eric: Don't scare me about overheating! Thats what I"ve been afraid of! Have the Honda 400 home and will get it running when I have time which is'nt right now. The Berk is currently in a corner with a ton of stuff piled on top of it. When I got it it had been modified to run a honda 305 super hawk engine that was junk. Owner had cut a big hole in the bonnet to fit it and did some sloppy fiberglass work to cover it. 400cb engine will fit under stock bonnet where most twins won't so that was my reason for choosing this engine. Might have to fit a fan.
Paul161: the big Honda cruiser (Gold wing) has a reverse on some models but is to big for this car. Plus that it is shaft drive and I need chain drive. Would be a neat engine for a custom though. The trick would be to completely modify the car and go to rear wheel drive with say a rear end out of a spridget. Stock Berks are front drive.
Kurt.
EricG said:
Hi Kurt
Is that engine a 2 or four cylinder?? What model? From your picture it appears to fit under the bonnet OK.
Kurt.
It is a twin cylinder 4 stroke engine from a Honda 360 motorcycle made in the late 70's. It fits well but the hood had to have a small "power bulge" molded into the leading edge to clear the top of the head.
"Power bulge's" seem to be necessary with any of the twins I have measured. Was considering a 500 Kaw "Ninja" twin cause they made a zillion and they are water cooled with fans but just too tall.
Kurt.
BMW flat twin?
BMW flat twin might fit JP, never checked for that.
Kelleys guy, I brought the car home in the back of a Dodge pickup. It fit nicely. Weigh's about 600lb.
Kurt.
Momentarily forgot BMW's are shaft drive.
I looked long and hard at 2 wheel drive ATV's and I think the main problem with that swap would be coming up with the correct gearing for hiway use.
Kurt.
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
sim oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi Spridgets 21
craigshealey3000 Carb Tuning for Cold Starts Austin Healey 2
F TR6 Pegged out hot while cold Triumph 7
B Cold Start Problems BN7 Austin Healey 21
RAC68 Cold Air Bilge Blower update Austin Healey 13
M TR2/3/3A TR-3A Compresson check hot vs cold Triumph 5
N Running Cold Austin Healey 12
M Cold start problems Austin Healey 33
D it's cold and i'm bored... waiting for parts... Austin Healey 11
M Starting from cold Austin Healey 2
F TR2/3/3A Starts Cold, Not Hot Triumph 12
P Healey 100M Cold Air Box Hose Fitting Austin Healey 20
R Very Difficult cold weather starting problems! Austin Healey 21
Michael Oritt Replacing Cold Air Box with Velocity Stacks Austin Healey 10
M BN1 - Question about cold air box Austin Healey 6
K Hard Start, runs poorly when cold Spridgets 10
C Brakes pull to left - especially when cold. Where to start??? Austin Healey 11
S Hard starting on Webers from cold Austin Healey 12
Lutz Kramer Problem starting the cold engine Austin Healey 16
TRMark TR4/4A Cold air intake system Triumph 1
K TR2/3/3A Anyone running a cold air duct to the carbs? Triumph 15
drooartz MGB Must be the cold -- MGB will have a nice Xmas MG 7
M running cold Triumph 8
J Cold Starting on a Series II Jaguar 5
Morris Cold Air Intake Spridgets 2
S Cold galvanizing zinc spray Restoration & Tools 5
tahoe healey How cold would you drive? Austin Healey 16
V hard start when cold Austin Healey 7
aeronca65t TR2/3/3A TR3-cold tires Triumph 2
H Cold blooded animal Triumph 21
nevets OD sluggish when cold Austin Healey 15
S Cold Start issue MG 4
tweety Cold Start thoughts Spridgets 6
D cold air duct 100 Austin Healey 3
C Cold air box for Tri Carb 3000 BT7 ??? Austin Healey 9
drooartz A great [cold] drive today Spridgets 5
PAUL161 Just Brought "B" Out Of Cold Storage! MG 14
Morris Cold Start reality check Spridgets 10
theleisure Cold Weather, Oil Pressure Spridgets 10
T 100M Cold Airbox Filter Austin Healey 29
Thor Suggestions for hard starting 1500 when cold Spridgets 5
S Jag barely runs in cold weather Jaguar 7
T 1098 valve clearance - .012 cold? Spridgets 1
J 1985 Jaguar XJS - Cold start problem, help needed Jaguar 24
D Oil burning at cold start Austin Healey 17
zimmy quicker cold starts Spridgets 5
AH100M 100m/100 Le Mans Cold Air Box grommets Austin Healey 5
kodanja Cold starts? Triumph 24
RickB Cold weather and oil viscosity? Spridgets 8
