Cockpit Floor Heat Shield
mjobrien
I looked at many of the prior posts and could not find the answer to the following.
Is the under floor insullation (above the exhust) on a BN1 correct? I can't seem to find any indication that BN1's had this installed....
Suggestions or opinions are always welcomed.
Michael.
Michael,
My BN1 is nov 29 '53 body 860, had no insulation at all!, long time ago I lagged downpipe with asbestos lagging, but nothing under seats or underneath, and no attachment holes to support it having ever been there,and this a direct to Australia car, my seats had the choice of 3 bolt down positions short, shorter or even shorter legs!
No slide adjustment, just the very thin pine packers, and bolted direct to the floorpan
There is now a cement type sheeting which you can fit
to firewall and to underside of floor, not a believer its an original concept tho
Mike:
When I bought my 55 (halfway done to concourse specs) he had the black "tar paper" under the front seat, which I believe is correct.I added insulation to this(aluminum backed roll from Moss and cut it to the carpets dimension. I am not going to go for gold etc. and wanted coolness and noise reduction.. I have only driven the car 100 miles since it is winter but I am very pleased with the quietness of the car. All my previous Healeys have been 3000 or Bugeyes...this is my first 100 and I REALLY like it better than nay other Healey I have owned.
There is NO asbestos sheeting UNDER the floopans above the exhaust like on a 3000..hence my decision to insulate ABOVE the floorpans.
Hope this helps..
Pete
Hi Michael,
Moss lists the heat shield here as item #81, not original on the Fours.
https://www.mossmotors.com/Shop/ViewProducts.aspx?PlateIndexID=28963
It has small cutouts for seat mounts, exhaust hangers etc. & fits perfectly. Makes a very worthwhile reduction of floor temperature. I would accept a small reduction of Concours points any day for the increased comfort.
With the shield painted the same color as the floor, body color, it's barely noticeable.
Thanks to all of you on the replies, I'm going to leave it off for now, vut keep it handy in case the foil insullation in the cockpit is not enough.
Pete, great to hear you opinion on the 100, I really went back and forth on a 100 vs a 3000 and so far I'm glad i started on this model.
Cables and a battery is all that's needed to get to a point where it can be started and driven as a chassis only....
I'll update all once I get to that point for sure!
Michael.
5 Wanted Looking for a Rear Cockpit Molding for a BN2 Austin Healey Classifieds 0
R Wanted Cockpit surround Spridgets Classified 1
bugedd Wanted: Bugeye cockpit surrounds Spridgets Classified 7
maxwedge5281 Cockpit Surround Molding Austin Healey 4
F Exhaust Fumes in the Cockpit - BT7 Austin Healey 10
K For Sale Front cockpit dash rail...N/A at Moss Triumph Classifieds 0
bighealeysource Wanted Looking for missing BN2 door and cockpit moldings Austin Healey Classifieds 0
K For Sale TR3 rear cockpit center capping Triumph Classifieds 0
K For Sale TR3 Cockpit Trim ...N/A at The Big 3 Triumph Classifieds 0
L 100 ID plate inside cockpit Austin Healey 10
K TR2/3/3A Gluing vinyl to cockpit capping? Triumph 5
B Prince of darkness conquered in the cockpit Austin Healey 17
K TR2/3/3A Cockpit quarter rails? Triumph 11
trotti Aluminum cockpit trim Austin Healey 0
C TR2/3/3A Gas tank cover in cockpit area Triumph 3
Rob Glasgow Re-anodizing cockpit surrounds Austin Healey 3
A TR2/3/3A Cockpit capping Triumph 7
Tinkerman TR2/3/3A Cockpit capping Triumph 11
D Door Cockpit Trim Austin Healey 11
J Aluminum molding in cockpit Austin Healey 9
T TR4/4A Fabricating a metal panel in between the fuel tank and cockpit Triumph 6
PHerder ? about the rear section of the cockpit on a 1966 Sprite MkIII Spridgets 9
S Mk III Sprite cockpit surround - trying to recover Spridgets 9
Griz Cockpit Insulation Austin Healey 13
R Interior cockpit coatings and insulation Triumph 12
Lukens TR2/3/3A TR3 fumes in cockpit. Triumph 4
S TR2/3/3A tr3 leather cockpit capping dog leg Triumph 4
NutmegCT TR2/3/3A TR3 cockpit - summer heat! Triumph 12
S TR2/3/3A leather cockpit tr3 Triumph 2
O TR2/3/3A TR3 Cockpit Cappings Triumph 1
bighealeysource Looking for specific # cockpit surrounds for BN2 Austin Healey 5
R cockpit/underbody paint Spridgets 5
I TR6 TR6 most common source of leaks into cockpit? Triumph 7
sjuengst Cockpit heat discovery Austin Healey 7
Michael Oritt Sheet metal for cockpit Racing 4
60Bugeye Polishing Cockpit Surround and Window Pillars Spridgets 41
bigjones Exhaust stink in cockpit Spridgets 56
ekamm Securing the cockpit side fuel tank closeout Triumph 2
jvandyke vinyl trim on cockpit surround Spridgets 5
G Cheap, quick cockpit cover Spridgets 1
T Rear Cockpit Surround Molding 1973 Spridgets 2
6 Cockpit Trim Q's Austin Healey 3
S Installing 3 pc. cockpit chrome. [b]I need help[/. Triumph 5
RickB Cockpit surround? Spridgets 26
W Polished cockpit trim Spridgets 18
TexasSprite Heat proofing the bugeye cockpit Spridgets 10
M TR2/3/3A Heat in the TR3A cockpit Triumph 9
B New Canvas Cockpit / Cage Cover Spridgets 13
CraigLandrum TR2/3/3A TR3A Fiberglass cockpit capping woes Triumph 3
TR6oldtimer Slowly getting there,cockpit painting nearly done Triumph 11
