Clutch Fork removal/rebush
tld6008
Can anyone explain the proper steps to take in order to remove the clutch fork (in the bell housing)? Starting with removal of the tapered pin and then the removal of the shaft? I have been previously told to use a slide hammer too remove the shaft which makes sense but first the pin needs to be removed and so far it doesn't want to move. Are there any secrets involving reinstalling the bushes?
TIA
tld6008
This forum is amazing. Thank you Randy for the detailed pictures. I just spent a fair amount of time last night beating on that pin before coming in to search this forum.
D Clutch Fork Pin Removal Austin Healey 4
AHS TR2/3/3A TR3 transmission clutch fork & shifter removal? Triumph 5
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
T Spitfire Clutch fork and hydraulic cylinders Triumph 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
D TR2/3/3A Clutch through out fork misaligned Triumph 17
M Clutch fork lever Austin Healey 11
KVH General Tech Clutch Fork and Broken Pin Triumph 8
Lukens TR2/3/3A Clutch fork pin. Triumph 9
J Clutch fork free play on BJ8 How Much? Austin Healey 13
S TR2/3/3A remove a clutch fork Triumph 1
B Clutch release arm / fork gaiter ; Toyota 5 speed conversion Austin Healey 2
K Clutch fork fix Re: the 1/4" bolt repair. Triumph 10
KVH Clutch Fork Lock Wire Triumph 1
J TR6 TR-6 Clutch Fork Cross-Bolting ? Triumph 2
J TR6 TR-6 Clutch Fork Taper Pin-Torque ? Triumph 5
KVH TR4/4A TR4A Clutch Fork and Shaft Triumph 37
dondel Clutch Fork movement & Master Cylinder Austin Healey 13
hondo402000 TR6 New TR6 Clutch shaft, fork and beefy pin Triumph 3
Banjo The dreaded broken clutch fork pin! Triumph 9
J Clutch Fork Clearance Info Request Spridgets 2
CCURTISS T-Series Extra MGTD/TF Clutch Actuating Fork???? MG 2
GT6_Mark T-Series MGC Clutch Fork Question MG 1
CCURTISS TR4/4A TR3/TR4 Clutch Fork Install Question Triumph 8
heliguy TR5/TR250 TR250 clutch fork "pins" Triumph 2
heliguy The dreaded clutch fork pin again..... Triumph 9
tomshobby clutch shaft/fork pin Triumph 8
B Clutch Fork Austin Healey 3
B Clutch fork shaft rebuild. Austin Healey 9
I Broken clutch fork taper pin Triumph 6
M Clutch Fork Pin Triumph 4
martx-5 Gearbox Clutch Release Fork Triumph 2
R Midget Mark III clutch push rod lengths Spridgets 0
mctriumph TR2/3/3A The worst clutch noise ever heard Triumph 4
Ariddick TR2/3/3A Squeaking Clutch when hot Triumph 82
F TR2/3/3A Clutch Slave failure Triumph 5
Lutz Kramer Clutch Disengagement Austin Healey 15
Turbozinke TR2/3/3A Varying clutch engagement Triumph 6
K TR2/3/3A Pushing down the clutch pedal when starting the car? Triumph 22
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
Govtslug TR6 Clutch Problem Triumph 21
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
T General Tech Clutch trouble Triumph 12
