TR2/3/3A Cleaning the Solenoid contacts? Does pressing the small chrome "button" release the bake light fixture to access the contacts for cleaning?
karls59tr
Bronze
Dunno for sure, but I doubt it. The case looks to me like it is swaged over the bakelite insert. It's just a $20 part (from BP Northwest), so I'd suggest replacing it.
The reason I was thinking of opening the solenoid for cleaning is that I just read on the Triumph Experience forum newsletter that the new aftermarket solenoids offered by some suppliers are definitely faulty. Several complaints of contacts sticking resulting in the starter not shutting off and the person scrambling to disconnect the battery!
IIRC, that pin has a twist to it and is sort of screwed in. The pot-metal case edge is bent over the bakelite base like Steve says, and is not intended for disassembly. I think the pin is there to keep the base from rotating of getting loose under the solenoid action. You may be able to carefully remove the lip thats around the base and remove the parts for cleaning. You could epoxy the base back in and add a few stakes.
I got as far as removing the brass stake and wiggling the base. I shot some CRC contact cleaner inside, pushed the button many times, and got the resistance down to almost 0.
Jeff
That pin just keeps the bakelite from spinning inside the outer steel casing. You won't get any access from removing it.
I cleaned mine by removing the rubber cover from the button and dowsed the opening around the button with carb cleaner, aired it out with a compressor, then used contact cleaner, followed by a final blow out. Once you start using the solenoid, they tend to be self cleaning. The little spark from each engagement burns off any accumulated dirt. The worst thing for a contact is to let it sit for years, so the brass and copper corrodes over...but even then, if you can get it to engage it will start to clean itself off. What kills the contacts is when a combustible, like oil, gets inside and fries the surfaces of the contacts.
New parts having low quality? Oh no, say it isn't so!!!!
Yeah, I get it. If it were me, I'd follow John's suggestion and see how it works out. If not, you can use any generic starting solenoid. There's nothing special about them.
You are right about the aftermarket solenoids sticking on, if you can save the original you will be far better off. I have taken them apart using a small screwdriver to bend the casing away from the center part doing a small section at a time. The outside can be polished with a wire buff and you can buy a new rubber boot for the button and it will look like new.
Graham
GrahamView attachment 73749
Oh my
what a pretty engine compartment. Dont show this to MY TR3, she will never start again just for shame lol
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
S TR2/3/3A Parts cleaning. Triumph 4
P TR2/3/3A Block treatment post cleaning Triumph 17
B Electrochemical cleaning of stainless steel welds Restoration & Tools 7
B Car care/cleaning? Lotus 5
Basil Cleaning fuel injectors Restoration & Tools 4
L TR2/3/3A Stupid Engine cleaning question Triumph 9
F Undercarriage Cleaning Austin Healey 13
S For Sale Big Barn Cleaning Triumph Classifieds 0
T TR2/3/3A Instructions for cleaning & re-lubricating speedometer? Triumph 5
TRMark TR4/4A Cleaning Striker and Restraint Assemblies Triumph 2
H Machined Engine Block - Cleaning before assembly and paint. Not sure what to do? Spridgets 5
NutmegCT Fuel tank cleaning/restoration Restoration & Tools 47
H Third Member - Differential - Carrier Housing - Center Section - Gear Set Cleaning Spridgets 4
SASSAMON TR2/3/3A Help Wanted In Cleaning Corrosion Off SU Carbs Triumph 20
K TR2/3/3A Cleaning the gas tank...what have I done now? Triumph 19
B TR2/3/3A Control column turn signal cleaning Triumph 8
K TR2/3/3A Cleaning a gas tank with muriatic acid.... Triumph 7
PKPoole TR2/3/3A Spring Cleaning Done Triumph 2
E TR4/4A Cleaning of alloy parts Triumph 4
GTP1960 TR2/3/3A Cleaning/degreasing timing chain Triumph 11
S TR2/3/3A cleaning wire wheels Triumph 6
R TR4/4A Question about cleaning instrument faces Triumph 8
G What's Your Best Car Cleaning Tip? Restoration & Tools 0
K TR2/3/3A Speedometer cleaning ? Triumph 3
Gliderman8 General Tech Cleaning sludge/varnish from a gas tank Triumph 6
cologero_100 Cleaning the satin chrome grille on a 100/4 Austin Healey 2
M Cleaning up under the hood - just how much needs to be painted? Spridgets 2
drooartz Cleaning out the parts: gauges, lights, console Spridgets 4
drooartz Cleaning up wiring Spridgets 17
H TR4/4A 4A grille cleaning Triumph 10
simon1966 Parts cleaning? Austin Healey 6
D Finally done cleaning!!! Spridgets 2
Jim_Gruber Spring Cleaning Special - Lower Valance for Spridget off of a '68 Sprite Spridgets 10
M_and_P Spring Cleaning Spridgets 0
JPSmit Cleaning Tip Restoration & Tools 0
T Cleaning a White Interior Triumph 0
drambuie Strip cleaning frames engines and bodys Austin Healey 5
W What size taps and dies for thread cleaning ? Austin Healey 7
Tr3aguy Chemical dipping vs media cleaning? Triumph 4
K Cleaning up exterior surface of SU's? Triumph 8
M Cleaning regulator and cutout contacts Triumph 4
R Lens Cleaning/Polishing Triumph 5
dklawson Gauge Face Coating after Cleaning? Spridgets 1
dklawson Gauge Face Coating after Cleaning? Triumph 2
L Advice for cleaning/painting 1980 rubber bumpers MG 8
S cleaning old plastic Triumph 6
JPSmit Cleaning parts tonight Spridgets 6
regularman Spent the day yesterday cleaning and painting Spridgets 9
Darrell_Walker Head cleaning Triumph 16
