Cleaning...New Mini
dptom
Member
I am a brand new mini owner. Year 2000 built by Rover. And, just received it from UK into Ventura... The vehicle was packed in Wax Oil which has left a crusty looking resedue on the finish. I need some suggestions as to what compound to use to clean this off and get the vinish back to new looking. Any thoughts and suggestions would be really welcome...
Administrator
Boss
Hi dptom, I would suggest first wash completely in Dawn dishwahing detergent. (Not any other brand). Dawn will do a real good job of taking all the oils and waxes off the car. Then, I would recommend doing a complete Zaino treatment. Zaino is a multi-step process, but once you do the initial steps, then you just add polish whenever you need to. But once the car is washed with Dawn, you would use "Clay Bar" on the entire car. You can get this from Zaino also. It looks like silly putty and you rub it all over the entire car, small sections at a time -- keeping the area being worked wet with a spray bottle of water. Once you have clay bared the car (this takes out all the microscopic impurities), then you use Z1 "Polish lock" followed by either Z2 or Z5 show car polish.
Visit https://www.zainobros.com for further details and info where you can buy it (I know there are lots of dealers in California). I use Zaino all the time and love the stuff, but the initial steps should help with your particular problem. Good luck and again, welcomet to the forum! Hope we see lots of your around and be sure to post pictures of your new Mini, it sounds cool!
1967 Jaguar E-Type OTS
1E13333, Silver Blue
dptom
Member
Thanks. As soon as I get it cleaned up I'll be sure and post a few snaps.
The car is in great shape and real fun to drive.
dptom
Member
Oops...
Sorry for the additional post. but, what are the proportions for using the Dove? Do I mix with water like any car wash? Or, should this be more concentrate?
Thanks.
Administrator
Boss
Oops...
Thanks.
NOT DOVE!! No no no! Must use Dawn Dishwashing Detergent. That will take any old waxes or polished and oils off the car and leave just bare paint. As for proportions, I never really measure it out, I just give a couple of good squirts in a plastic bucket of warm water - enought to get a good head of suds.
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
S TR2/3/3A Parts cleaning. Triumph 4
P TR2/3/3A Block treatment post cleaning Triumph 17
B Electrochemical cleaning of stainless steel welds Restoration & Tools 7
B Car care/cleaning? Lotus 5
Basil Cleaning fuel injectors Restoration & Tools 4
K TR2/3/3A Cleaning the Solenoid contacts? Does pressing the small chrome "button" release the bake light fixture to access the contacts for cleaning? Triumph 7
L TR2/3/3A Stupid Engine cleaning question Triumph 9
F Undercarriage Cleaning Austin Healey 13
S For Sale Big Barn Cleaning Triumph Classifieds 0
T TR2/3/3A Instructions for cleaning & re-lubricating speedometer? Triumph 5
TRMark TR4/4A Cleaning Striker and Restraint Assemblies Triumph 2
H Machined Engine Block - Cleaning before assembly and paint. Not sure what to do? Spridgets 5
NutmegCT Fuel tank cleaning/restoration Restoration & Tools 47
H Third Member - Differential - Carrier Housing - Center Section - Gear Set Cleaning Spridgets 4
SASSAMON TR2/3/3A Help Wanted In Cleaning Corrosion Off SU Carbs Triumph 20
K TR2/3/3A Cleaning the gas tank...what have I done now? Triumph 19
B TR2/3/3A Control column turn signal cleaning Triumph 8
K TR2/3/3A Cleaning a gas tank with muriatic acid.... Triumph 7
PKPoole TR2/3/3A Spring Cleaning Done Triumph 2
E TR4/4A Cleaning of alloy parts Triumph 4
GTP1960 TR2/3/3A Cleaning/degreasing timing chain Triumph 11
S TR2/3/3A cleaning wire wheels Triumph 6
R TR4/4A Question about cleaning instrument faces Triumph 8
G What's Your Best Car Cleaning Tip? Restoration & Tools 0
K TR2/3/3A Speedometer cleaning ? Triumph 3
Gliderman8 General Tech Cleaning sludge/varnish from a gas tank Triumph 6
cologero_100 Cleaning the satin chrome grille on a 100/4 Austin Healey 2
M Cleaning up under the hood - just how much needs to be painted? Spridgets 2
drooartz Cleaning out the parts: gauges, lights, console Spridgets 4
drooartz Cleaning up wiring Spridgets 17
H TR4/4A 4A grille cleaning Triumph 10
simon1966 Parts cleaning? Austin Healey 6
D Finally done cleaning!!! Spridgets 2
Jim_Gruber Spring Cleaning Special - Lower Valance for Spridget off of a '68 Sprite Spridgets 10
M_and_P Spring Cleaning Spridgets 0
JPSmit Cleaning Tip Restoration & Tools 0
T Cleaning a White Interior Triumph 0
drambuie Strip cleaning frames engines and bodys Austin Healey 5
W What size taps and dies for thread cleaning ? Austin Healey 7
Tr3aguy Chemical dipping vs media cleaning? Triumph 4
K Cleaning up exterior surface of SU's? Triumph 8
M Cleaning regulator and cutout contacts Triumph 4
R Lens Cleaning/Polishing Triumph 5
dklawson Gauge Face Coating after Cleaning? Spridgets 1
dklawson Gauge Face Coating after Cleaning? Triumph 2
L Advice for cleaning/painting 1980 rubber bumpers MG 8
S cleaning old plastic Triumph 6
JPSmit Cleaning parts tonight Spridgets 6
regularman Spent the day yesterday cleaning and painting Spridgets 9
