    BCF is a resource offered at no cost to the Little British Car community. We do not require you to pay to play here. However, if you find BCF a useful resource, appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please support the forum with an "optional" low-cost (less than many car club dues) annual upgrade. There are some benefits to upgrading!
Charging system?
VelodromeRacer
Hey guys...
At Gingerman...Well I managed to qualify 2nd in group 2 and then led the first 8 laps until the gearbox went away...Well we figured out that the nut on the mainshaft came loose..lost second and fourth...but I have a question.
I want to install a small, yet durable charging system. The car currently does not have one, so I don't have the slightest on where to begin. I have the brackets..but what should I but and how does one wire one up? Is it worth it to then install a voltmeter?
Thanks...now getting ready for Blackhawk and Mid-Ohio. Larger 7/16" wheel studs over the 3/8" ones and rebuilt race lever arm shocks on the front.
Michael Oritt
Velo--
I have a Nippondenso alternator--I think it puts out about 35 amps--hung on the MGA engine of the Elva. It weighs approximately five pounds and mounts with one bolt on top and an adjustable arm. I picked it up used for $95.00 and though they are sold on the race sites for a lot more they are very common to small Japanese cars.
The one I have uses a three-wire modular plug which means the regulator senses system versus battery voltage plus it runs an idiot charging light but I don't think this is very important for racing applications and if you see a one-wire unit it would be fine.
Hookup is easy in either case--with the one wire just carry a heavy wire to a hot terminal that is downstream of your master switch. With a three wire plug you will also bring one small wire from a 12 volt source to "excite" the alternator, another TO a 12 volt source (can be the same one) to sense voltage and the third to the idiot charging light and then to ground to run the light.
M TR4/4A Charging system question? Triumph 6
angelfj1 Charging System Failure Triumph 28
I Help on charging system please Spridgets 3
MGTF1250Dave Battery & Charging System Question Triumph 3
6 Charging System Question Spridgets 3
eschneider Charging system possessed...... Other Cars 4
VelodromeRacer Running without a charging system Racing 22
mgb4tim Wedge TR7 Fuel Injection/Charging system help. Triumph 2
T MGB Multiple charging system issues: 67 MGB MG 11
ronzet MGA MGA Charging system MG 7
M Newbie question about charging system Spridgets 9
Coleman Charging System Triumph 0
H Charging System Problems with Sprite Spridgets 8
S TR4/4A TR4A Charging system Triumph 6
C Charging system-stupid newbie question Spridgets 63
rick_ingram MGC Charging system woes - MGC MG 11
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
I Bugeye charging issues Spridgets 8
B Delayed charging Lucas alternator Triumph 1
Got_All_4 TR5/TR250 Rebuilt Bosch Alternator stops charging Triumph 0
F Dynamo not charging [BT7] - replace brushes or buy new? Austin Healey 24
S TR2/3/3A no leaks, but the generator is not charging Triumph 45
N Charging warning light LED conversion Austin Healey 29
K TR2/3/3A Alternator not charging? Triumph 2
M Alternator not charging Austin Healey 0
D BJ 8 not charging !! Austin Healey 6
L Ignition / Charging light wiring Austin Healey 3
D Charging issue on mk1 British Motor Corp 1
F TR2/3/3A Voltage Regulator and Charging issues Triumph 11
dklawson Spitfire Supositions Wanted - '72 Spitfire Charging/Not-Charging Issue Triumph 5
M Charging Optima Batteries Jaguar 5
David_DuBois Off Topic How about terbo charging? MG 7
doates Spitfire Spitfire Charging Issues Triumph 9
6 stumped...engine charging...or not Triumph 12
F Over-charging Austin Healey 15
O TR2/3/3A TR3 Generator Not Charging Triumph 3
T TR4/4A TR4a charging issue Triumph 15
D Charging Issue....still Triumph 14
vping Not charging MG 7
GBRandy Wedge TR8 Charging Voltage at 15.9 Triumph 68
C charging problem at 3500 rpm Spridgets 6
P BATTERY CHARGING MG 3
athenssprite not charging Spridgets 3
jvandyke how to read a volt meter charging? Spridgets 27
Dave Richards Generator not Charging? Austin Healey 14
bmurphy7369 XJ6C charging issue, where to start on Diagnosis Jaguar 5
B MGA charging voltage for mga generator MG 7
AUSMHLY Is my Generator charging? Austin Healey 5
S Battery charging Triumph 7
B Charging/Battery died + Tach & Idle questions Spridgets 9
