rick_ingram
OK...
Went to fire up the 1968 MGC last week..reconnected the battery ground...tried to fire it up....it was dead. (No surprise....so is/was the Nissan 300zx, the '69 MGC, and the '78 MGB!)
I disconnected the alternator and put the charger on it.
Yes...Negative to negative and positive to positive.
Battery appeared to re-charge on trickle...
Went to reconnect alternator and ...SPARK!
"This ain't right, I say!"
Pulled the one wire off of the alternator that I had connected (brown).
Then...
I disconnected battery at ground (negative terminal).
Reconnected alternator.
Went to reconnect ground....SPARK at battery terminal.
Any clue as to what's going on here?
Thanks in advance
Then...
Thanks in advance
