    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
building a single tower Sprite storage lift?
'm trying to figure a hoist to suspend a gutted shell (no bonnet) up to the ceiling in the garage. Can't find anything that will work out of the box."
Easy, a bit of rope and a few pullys, like used on larger sail boats. Yep, did it.
I use some old sailing hardware, a mainsheet cleat along with 3 pulleys to create a pulley setup for lifting Bugsy's BE Bonnet off all by myself. Now not everyone has spare Harken nylon ballbearing sailing hardware along with high tech mainsheet rope in the back of their garage but when attached to some eyebolts placed through the fender mirror mounting holes I can remove the front hinge bolts and remove the bonnet by myself in < 10 minutes. You can duplicate this setup, for nat all that much money, using different pulleys of course from the local hardware store.
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
PAUL161 T-Series Who's still building 5 speed conversions. MG 4
jackq Another building full of cars available. Other Cars 0
R TR2/3/3A Re-building 1954 TR-2 engine Triumph 20
JimLaney New to engine building - gaskets Spridgets 2
T Building a rollbar for a BE Spridgets 1
T Thinking of building an adaptor to allow a torque wrench to tighten the knock-ons Austin Healey 32
69sprite This guy has skills and building a beast of beauty Spridgets 6
5 TR2/3/3A TR3 engine building tips needed Triumph 5
drooartz Suppose this counts as a tool, building a barn Restoration & Tools 38
CZ_Dave Been busy building MG 2
R Building Wooden Steering Wheel Austin Healey 6
G Looks like I'll be building the Midget LE Spridgets 16
B Is building a race replica folly? MG 29
T MGA Recommended order for building MGA front susp MG 1
M Building Bugeye dash Spridgets 28
Tabcon TR4/4A Building a new improved TR4. Triumph 8
Trevor Jessie Rebuilding vs Building Spridgets 8
Webb Building a TR6 Racer Racing 4
S building front spring compressor Triumph 24
MadRiver My building permit has been approved!!!!! Triumph 13
hondo402000 TR6 building a High performance TR6 engine Triumph 20
Steve_S Building a car Racing 10
G building a TR6 OD tranny for vintage Racing 4
T building a NHRA legal cage Racing 6
YankeeTR TS1203LO is in the building... Triumph 35
macino62 Building a new engine.... Triumph 8
kch Building Healey engines in may issue of Retro Cars Austin Healey 3
G Building Engine=Easy Button, Sunvisors=@#%$ Triumph 11
tony barnhill Building BBS Traffic MG 5
Patton Building a Console For My 100-Six Austin Healey 6
C LCB header with 1500 single carb inlet manifold Spridgets 1
pbraun Single HS2 on an 850 Mini Moke acting odd British Motor Corp 10
shadowfever Single SU on Spridget Spridgets 3
idlehands Wanted WTB GT6+ driver (LHD) window glass and a single rostyle wheel cover Triumph Classifieds 1
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
AUSMHLY 65 BJ8 Front Single Lamps Austin Healey 35
steveg Switching multi-wire wideband O2 sensors between single gauge Austin Healey 11
K WTD Single SU Manifold for AH Sprite Spridgets 0
R 1275 engine with SU HIF single carb Spridgets 9
SherpaPilot TR6 Single Spark Plug is Burned Triumph 12
drooartz Single stage vs base/clear Spridgets 29
M TR2/3/3A Single brake light modifcation Triumph 2
W Single Minator wheel available Spridgets 3
N DCOE double vs. single choke theory Spridgets 11
Foura TR4/4A TR4A Exhaust - Twin or single? Triumph 8
Scott_Hower 1500 single rail gearbox rebuild? Triumph 7
T Single Weber Redline carb for stock Midget 1275 Spridgets 12
T Wedge The Wedge Shop Single Turbo TR7V8 build Triumph 3
J Bugeye single piece top frame same as two-piece? Spridgets 4
