BUGEYE DOOR POCKETS
paulsherman
Does anyone know how much of a curve is along the top of the door pockets? Maybe measure the distance from the door skin to the widest point in the center. I was thinking of making a mold and laying up a couple. Should be easy
Thank you
Mine are out. I'd be happy to trace one on craft paper and mail it to you.
Ray;
If you would e-mail me, I will send you my address.I would greatly appreciate a pattern. Seems like a nice winter project among several thousand more.
Thank you
W Bugeye Door Pockets Spridgets 2
B Which is the correct door knob for a 59 bugeye? Spridgets 3
Rut Bugeye door striker Spridgets 14
Rut Bugeye door panel glue Spridgets 13
DanLewis Bugeye Door Latch - How to keep it from flopping around? Spridgets 20
L Bugeye door pocket metal trim Spridgets 0
I Bugeye door latch question Spridgets 4
I Source for ribbed material for inside bugeye door? Spridgets 5
I Help with Bugeye door seals Spridgets 7
I Bugeye door seal help please Spridgets 8
I Bugeye door gaps/fit Spridgets 13
I Bugeye door allignment help please Spridgets 9
livinginthepast Bugeye door latch and striker help Spridgets 10
histerical Bugeye door panels Spridgets 7
John Moore LH Bugeye Door Spridgets 5
TexasSprite Door liner idea for Bugeye Spridgets 5
W Bugeye Door Latches Spridgets 1
B Looking for a BE [BugEye] drivers door? Anyone? Spridgets 20
B Is the rear edge of the Bugeye bonnet sheet metal supposed to be bent inward? Spridgets 2
Todd78d Normal Bugeye Running Temperature Austin Healey 1
Ohiobugeye Can a Bugeye ignition switch be replaced with a universal ignition switch ? If so how would the wires be attached ? Spridgets 15
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 A-H Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
drooartz Replacing Bugeye windshield rubber Spridgets 6
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
drooartz Restoring Penny the Bugeye Spridgets 22
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
SNClocks Bugeye axle limit straps Spridgets 5
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
R Bugeye Starter Switch Spridgets 7
Lin Bugeye Axle Hub & Bearings Austin Healey 1
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
Lou E Finally a Bugeye of my very own Spridgets 41
