Brake Servo Question 62 BT7 Tricarb
BobBridgeman
I am restoring a 1962 BT7 with Tri carbs. The car had a brake servo unit, which I believe was a factory option for the BT7. The servo unit is a Girling 5 inch servo, with a 3/4 piston, which seems a bit unusual for Healey models most others are 7 inch. Moss and Victoria British do not carry the correct parts for this model. Are there any other Healey owners with this model servo?
Also, I am not sure where the servo unit should be mounted. Is it the same location as later model Healeys (between the right hand foot well and the inner fender)? When I disassembled the car, my servo was mounted above the inner fender aft of the heater blower.
Thanks for any help on this!
--Hi Bob, Usually the servo is mounted on a pair of supports that attach to studs on the engine side of the passengers foot well.
If repair kits are not available I would suggest getting one of the new PBR units from OZ and installing it as defined above. The PBR units may be available here in the US but I do not know who the distributor is.--Fwiw---Keoke
I bought mine from Tom's Import, looks like he still carries it. Tom's Import
BobHaskell MGB 1980 MGB harness question - brake servo/master cylinder MG 1
John_Mc Brake question. Servo? Triumph 7
M Brake Servo Austin Healey 8
M Brake Servo Austin Healey 2
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
Walter74 Brake Servo Location Austin Healey 6
R Brake Servo Rebuilder Austin Healey 14
Jeepster BJ8 Servo/ brake booster test Austin Healey 1
H BJ8 Exhaust System and Brake Servo Austin Healey 16
C TR6 Brake servo leaking Triumph 3
B Power Brake Servo for a 100 Austin Healey 3
M Orientation of Lockheed brake servo Austin Healey 2
R Healey Marque Brake Servo story Austin Healey 6
N Spitfire brake servo in a spitfire Triumph 3
S Brake Servo Installation Austin Healey 13
D TR6 Brake servo and rear tire rubbing Triumph 4
R BJ8 with servo...Brake travel issue Austin Healey 30
R Installing an aftermarket brake servo kit Austin Healey 6
S brake servo Austin Healey 3
L BJ8 Brake servo Austin Healey 6
D TR6 76 TR6 Brake Servo Triumph 2
W brake servo install? Triumph 1
W brake servo Triumph 3
W Brake fluid in Servo/booster Triumph 5
D Brake servo Austin Healey 1
Frank C. Brake Servo Replacement Austin Healey 6
T 77 with twon SU's- need to remove brake servo MG 2
John_Mc Brake/Servo issues Triumph 7
T XKE Series 2 Brake Servo Jaguar 2
B Brake Servo Parts... Triumph 1
B brake servo plumbing for BJ7 Austin Healey 8
J hints on rebuilding brake servo? Triumph 9
Basil Brake Servo Cylinder Stop Pin needed Jaguar 17
D brake servo Austin Healey 6
wangdango TR6 TR6 brake servo rebuild kit? Triumph 2
J Is my brake servo working? Austin Healey 5
chicken Brake servo pipe routing Austin Healey 1
RomanH Brake Servo Triumph 2
N Brake servo air filter Austin Healey 2
A brake servo booster help Triumph 3
J Brake servo Austin Healey 4
C BJ8 brake servo options Austin Healey 5
A brake servo change out Triumph 1
N Brake Servo Lockheed Austin Healey 0
B TR6 TR6 Fuel Odor in the Brake Servo Triumph 7
J Repair of brake servo's Austin Healey 19
S BJ8 Brake Servo Replacement Installation? Austin Healey 9
J Brake Servo mounting measurements Austin Healey 3
V NEW old brake servo Jaguar 14
