Brake line layout with dual master cylinder
letemglow
Hi MG enthusiasts,
I am working on an MG B where all of its break lines had been taken out previously. This car is equipped with a dual master cylinder but without servo. I am at a loss which is supposed the front and rear connection at the master cylinder for the corresponding brake lines. My shop manual doesn't show those details.
Does anyone know?
Thanks Dieter
Like this?
Yes, this is the same master cylinder I have. Is the brake line taken off the banjo going to the rear cylinders or front calipers?
Thsnks,
Dieter
In North America, our brake system has a pressure failure switch. The pipes from the master cylinder go to this brass fitting with switch.
The attached photo (not mine, but borrowed somewhere) illustrates the piping. The photo is low resolution, but should provide the routing.
Here's another (borrowed) shot of an engine bay.
This MGB has unconventional routing from the brake pressure switch to the front calipres.
I am aware that US models have a brake pressure switch, but there is none for Europe. The brake lines go directly from the master cylinder to the respective wheels. Nevertheless, how is the routing to and from the pressure switch then?
I.e. the banjo connection at the master going first to the "two" or the "three way" union of the pressure switch? I assume that the pressure switches "two" way union would continue to the rear brakes whereas the pressure switches "three" way union would split the brakes lines for connecting to the two front calipers.
B MGA Axle Brake line MG 0
J TR2/3/3A Brake Line Flares Triumph 8
S TR2/3/3A brass fitting from a steel brake line Triumph 2
D Fuel Line Clip vs Brake Line Clip Austin Healey 2
B Brake Line Pictures Austin Healey 1
KVH General Tech Brake Failure--The Line Split Triumph 19
Lin Brake hard line question Austin Healey 4
M TR2/3/3A Brake Line Removal From the Left Frame Rail Triumph 14
R TR2/3/3A Brake Line Triumph 4
B TR2/3/3A Caliper brake line Triumph 10
Lin Brake line fittings Austin Healey 2
John Turney TR6 Brake Line to Front Calipers Triumph 4
Gliderman8 TR6 Removing Left Rear brake line... help! Triumph 9
FlyingCat Spitfire Brake line Triumph 8
RAC68 Hard Brake Line Compound Opinion/Recomendation Austin Healey 8
Vineyarder Austin Healey 100-4 brake line fittings Austin Healey 10
R Help with BJ7 front brake line routing Austin Healey 6
Rut Brake line routing Spridgets 21
AngliaGT '74 Midget - Best way to Replace Brake Line? Spridgets 1
M TR4/4A 67 TR4A, need brake line fitting specs Triumph 6
M Brake Line Lengths Austin Healey 1
J TR2/3/3A Spring loaded valve in the top of the 4 way brake line fitting? Triumph 3
Rut MGB Need some brake line clips? MG 9
J Brake line material Austin Healey 24
J Brake line pipe Other British Cars 5
DornTRoriginal TR2/3/3A Installation of Brake Line Clamps on Real Axel Triumph 1
PatGalvin TR2/3/3A Hard Brake Line Flaring Question Triumph 11
AHS TR2/3/3A Disc brake line routing Triumph 0
T TR2/3/3A brake line replacement Triumph 11
DornTRoriginal TR2/3/3A Hydraulic Brake Line Clips Installation Triumph 2
C Vacuum line routing for brake booster Austin Healey 5
M Brake line kits Spridgets 28
D TR6 76 TR6 Rear Right Brake Line Triumph 8
mgedit TR2/3/3A Brake Line Master to Banjo Connection LHD 56 TR3 Triumph 4
R Brake line nipple size Triumph 4
Tugboat TR2/3/3A TR3A Brake Line Triumph 2
J TR2/3/3A Brake line advice for my TR3 Triumph 5
luke44 Clip - Brake Line to Firewall Triumph 3
M TR6 Where does this TR6 brake line go?[pic] Triumph 3
W Off to the local shop... brake line bleeding Spridgets 2
W Problems!! Brake line bleeding and leaks Spridgets 5
D Brake line flush Austin Healey 13
T Wiring Harnress and Brake Line Routes Austin Healey 11
E BE Dual Brake Line Switch Assembly Spridgets 0
E BE w/dual line brake master....90 degree fitting? Spridgets 12
K brake line flares Spridgets 9
T TR2/3/3A TR3 front brake line routing Triumph 3
B Brake Line Spridgets 5
I brake line fastener source? Spridgets 12
