TR2/3/3A boot drain troughs 59 tr3
K
Kevork Erer
has anyone fabricated and installed boot drain troughs that the lid sits on mine are rusted and would love to make new strips and replace, any picks and tips would really be appreciated thanks. Kevork
Hi John thanks for reply TS36996L looks like there is two troughs side by side one for seal to sit in and a trough for the water to drain and previous owner has done shabby repairs in pieces full of holes and rust. I have body off on cart doing some ripairs and learning along the way I may be too anel for this kind of work
You have the early seal. The good news is that it is simpler than the later seal. The there is no kit or replacement part for the seal channel, though. Do you have minimal proficiency with a welder? It is a matter of removing the rusted out portion and fabricating the new rails from 18 gage steel, and welding them back in.
well I am getting better at gas meg welding, new 18g is no problem cleaning the paint and seam seal and who knows what else off existing metal is the challenge if its not perfectly clean seems to leave dark burn spots around my welds hard to clean off. so drill out the spot welds from tub miter cut at corners and remove make new out of 18g and spot weld back on with slight arch same as the tub anything else you can think of I would appreciate thank you?
Can you salvage a small section to use as a pattern and have some of the channel made up with a nipple for the water drain. The pieces should be only a couple of inches wide, but the channel would be a challenge to fab up at home because of the small bends. it would probably cost a couple of hours at a sheet metal shop, but i think it would be worth it
steve
steve
Only the side channels need replacing top and rear with drain holes are still rust free and in good shape channel is made of two pieces I have a 36" break should be able to manufacture in my shop the 2 main challenges will be to maintain the slight arch as I drill out the spot welds and arch the new piece. I think I will make a template of arch out of mdf first. Thanks for the idea on doing it in pieces at a sheet metal shop Steve, I may be going there yet but I have to try first.
Kevork
G Wanted Tr4a boot lid Triumph Classifieds 4
mctriumph General TR Spring boot sale Umpteenth Annual Triumph 5
5 BJ7 Boot Rust-Through Austin Healey 13
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
JohnGone Wanted Q: Small Boot, Small Spare Tire? And, Jack needed. MG Classifieds 2
AUSMHLY Boot Lid Identification Austin Healey 2
J Restoration Progress - Boot Installed Austin Healey 1
B BJ7 Boot Trim Austin Healey 7
B Fitting the Boot Lid Seal Austin Healey 8
Rob Glasgow Boot Liner Edge Finish Austin Healey 11
chicken Boot Lid Badge Austin Healey 8
F TR2/3/3A Boot floor Triumph 50
steveg TR6 Dealing with Rack Boot Triumph 3
steveg TR6 Steering boot clamp wire - why? Triumph 2
T How do you cover your battery in the boot? Austin Healey 5
S Securing the jack with strap in BJ8 boot Austin Healey 11
Michael Oritt Boot floorboard? Austin Healey 9
S Boot Liner - BJ8 Austin Healey 19
C Under boot and under bonnet paint? Austin Healey 7
tahoe healey Leak into boot Austin Healey 17
B TR6 Boot lid thread plates loose in stiffener Triumph 1
G For Sale TR6 Matador Red Interior and Boot Triumph Classifieds 0
B Soft Top Boot Cover - BJ7 Austin Healey 5
A BN2 Boot Lid Austin Healey 4
W Gear Lever Boot for BN2 Austin Healey 5
ckeithjordan TR2/3/3A Boot Trim Triumph 3
1 Wedge Breaking Into a Trunk Boot Triumph 3
R TR2/3/3A Boot/trunk floor Triumph 5
B Dynamat in Boot? Austin Healey 7
S TR4/4A Fascia support and shift rod boot Triumph 0
S TR4/4A Handbrake cable rubber boot at clevis pin end Triumph 1
B Wanted I'm looking for a boot [trunk] lid and drivers rear fender for a 100/6 or 3000 Austin Healey Classifieds 0
H Wanted Braket that connects the boot lid to the boot lid stay strut on a Herald. Triumph Classifieds 0
Rhodyspit75 Replacing boot floor need bracing? Spridgets 2
CJD TR2/3/3A Boot Seal Pics Triumph 17
J BJ8 boot rubber strip Austin Healey 9
CJD TR2/3/3A TR2 Boot Strip Triumph 22
K TR4/4A TR4A vinyl top boot cover factory markings??? Triumph 0
K TR4/4A Black marks on a TR4A/TR6 vinyl top boot cover? Triumph 4
Rut TR4/4A Boot and bonnet bodywork. Triumph 4
D boot rubber ??? Austin Healey 2
Rut TR4/4A Parts in boot Triumph 11
SASSAMON TR2/3/3A TR3 Boot Construction Info Wanted Triumph 2
toysrrus TR6 "how to un-lock a boot lid"??? Triumph 11
R Boot hinge support brackets for BJ8 MKIII Austin Healey 4
T TR2/3/3A Rubber gear shift boot tearing Triumph 14
Tinkerman TR2/3/3A 1960 TR3A Boot rubber seal installation? Triumph 7
Popeye TR4/4A Trunk [boot] lock removal Triumph 12
Rut Top frame and boot panels Spridgets 2
dklawson General Tech Brake Maser Cylinder Pushrod Boot Installation Tricks? Triumph 2
