BN1 Boot Lid Bracket
JRued
All,
Looking to fabricate the bracket that links the boot lid support strut to the boot lid. (Image attached.) I require dimensions...
Also, does anyone have information to identify the proper style rivets that secure the rear shroud lower flanges?
Thank you very much,
John
Pretty sad that out of 57 viewers, I am the one to reply to my query...
So I will modify said request:
Can anyone fire me an image of the attachment bracket/hardware that links the support strut to the boot?
John
JRued said:
All,
John
I believe they are 5/32" inch shaft dia., with a flat head. I looked in a lot of places--including aviation supply houses--and the only people that had the (nearly) correct ones were British Car Specialist. They were a bit too long so you'll need a rivet cutter.
Thanks, all. Will hit up BCS for the rivets--as well as ability to source the not-available "stay" bracket that is enticingly depicted in the Moss catalog.
Best,
John
Best,
John
John, Kilmartin (kas@ncable.com.au) is trying to get in touch with you.
Bob_Spidell said:
JRued said:
All,
John
I purchased my flathead rivits from BCS and a friend told me that they are supposed to be a round head instead of a flathead. My car is due to go to the Body shop on Aug. 13th so I hope I get this sorted before then.
From the Anderson/Moment Restoration Guide, p90:
"... The shroud was fastened to the rear superstructure assembly with aluminum rivets along the bottom edge of the trunk opening and on the bottom flange that attached to the trunk floor lip. These rivets were solid with flat heads ..."
My BJ8 was all original--with 64K miles--when I bought it and the rivet heads were flat, as were the ones I got from BCS.
The lower lip of the shroud where it attaches to the boot floor was hand-painted (with a brush) flat black at the factory.
B Wanted Early BN1 Right Hand Sidescreen Austin Healey Classifieds 0
B BN1 Overdrive Austin Healey 5
S Wanted Windscreen Wiper Arm for BN1 wanted Austin Healey Classifieds 2
J For Sale BN1 project car (price reduction) Austin Healey Classifieds 0
W BN1 Steering Box Removal Austin Healey 11
W BN1 Steering Box Austin Healey 3
I Wanted BN1 with H6 carbs : bodies of TR3 Austin Healey Classifieds 1
S BN1 Wheel-Tyre Combination Austin Healey 10
AUSMHLY Laygear End Float BN1-BJ8 Austin Healey 2
W Healey BN1 Ignition Light Austin Healey 8
T Wanted: Early BN1 Sidescreens Austin Healey 2
Guido36 BN1 with Triumph TR 4 engine Austin Healey 1
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
W BN1 Gearbox First Motion Shaft Austin Healey 0
I Austin-Healey BN1 Parts List Austin Healey 4
BoyRacer BN4 Front Wings on a BN1 Austin Healey 9
BoyRacer Engine Swap: 3000 Engine Into a BN1 Austin Healey 25
BoyRacer Replace BN1 steering box with later version? Austin Healey 0
red57 Interesting BN1 for sale in Bellingham, WA Austin Healey 4
D BN1 Parts to Trade Austin Healey Classifieds 0
S WANTED: Healey BN1 "Smiths" Fuel Gauge (Dead or Alive) Austin Healey Classifieds 3
A BN1 Mechanical Brake Switch Austin Healey 23
P Wanted BN1 can shaft Austin Healey Classifieds 0
C BN1 Clutch Pedal Rattle Austin Healey 2
CharlesBN1 Uprated or 'umbrella' valve stem oil seals for BN1 Austin Healey 2
Guido36 BN1/BN2 Sidescreens Austin Healey 0
M BN1 Loss of Power Austin Healey 21
L Seat position for a BN1 Austin Healey 0
CharlesBN1 Wanted WTB Shelley Jack [6 INCH DL] for Early BN1 Austin Healey Classifieds 0
M BN1 with H6 carbs : what setting ? Austin Healey 56
I Ball Bearing cup for old style BN1 steering box Austin Healey 0
M Heat-related carb issue on BN1 Austin Healey 7
RCarr 1954 BN1 Wiper Wheelbox and Rack Austin Healey 3
CharlesBN1 Wanted wanted to buy - sidescreen trim/strips for early BN1 Austin Healey Classifieds 5
CharlesBN1 BN1 Soft Top installation - need advice! Austin Healey 3
Michael Oritt Optimal lighting for a BN1 Austin Healey 5
D Wanted BN1 LH Seat Cushion [Bottom] Austin Healey Classifieds 0
J 100 bn1/bn2 id Austin Healey 26
HealeyRick Wilwood Discs on a BN1 Austin Healey 1
CharlesBN1 need some advice fitting the bonnet on a 54 BN1 Austin Healey 4
Z For Sale 1954 Austin Healey 100-4 BN1 Beautiful Restoration Austin Healey Classifieds 0
Z For Sale 1955 Autsin Healey 100-4 BN1 and 1956 100-4 Race car Austin Healey Classifieds 0
D Wanted BN1 or BN2 Donor/Parts Car Austin Healey Classifieds 1
GeorgeC Rear spring disassembly - BN1 Austin Healey 1
Jake BN1 Front Shroud Badge - What is original? Austin Healey 4
Jake For Sale FS: BN1/BN2 Kilmartin Chassis Repair Parts, New Austin Healey Classifieds 2
55modified Need photoshop help for side vent options on my BN1 Austin Healey 6
55modified Nardi hub for a BN1? Austin Healey 10
L BN1 Transmission rebuild Austin Healey 1
simon1966 Replacing the witches nose in-situ. BN1 Austin Healey 14
