Bad news from the machine shop
eejay56
My machinist called yesterday afternoon and my block is cracked :cryin: So instead of 2 engines I have a broken engine and a pile of parts. Now I have to take the other engine apart and get it to the shop. Hopefully I can get it in there Saturday.
I'm not too familiar with the Spitfire blocks cracking, unless you consider a thrown rod through the block a crack. They do like to do that.
Agree with FoxTrapper.
Find a machine shop that does Heavy Duty stuff, construction equipment, semis, etc. Or an old timer welder. They can usually weld up these blocks no problem.
A while back MoPar had problems with their little dohc 2.4 engine with the head being eroded away by a gasket failure. Mopar dealers want to automatically replace the head. But there is a machine shop locally that welded these heads back up and machined them down for a lot less than a new head.
Research a good machine/welding shop. It'll save you money and hassle.
I've read mixed opinions on welding blocks. I'll keep this one and look into it for my next rebuild. Fortunately I happen to have another one ...hahndeee.
Good luck on the rebuild. Always a bummer when something like that happens! Good that you had a spare.
Tinkerman
YEP,He's right my Plymouth Horizon TC3 blew an(its)aluminum head on the way to Cleveland in 1978,hooked it to RollingAcres Dodge in Akron they welded it & machined it backed to specs we were good to go Chrysler paid.
I remember that,good thing it was summer.It was a German VW engine,their after Chrysler started producing there own 2.2L engines,instead of depending on Rabbit engines.
Bugeye58 said:
Just where and how is it cracked, Eric?
Jeff
I haven't seen it yet. I will when I take the other block down hopefully Monday.
I will say that I experienced with my 1978 MG Midget (Spit 1500 engine) that the block cracked completely in half. When I pulled it apart only an end plate, the oil pan and the head held the two halves together. It was driving but leaked a lot of oil and had a tapping noise.
K TR2/3/3A Bad news...blown head gasket??? Triumph 15
S TR2/3/3A Now the bad news. BRAKES Triumph 7
Alfred E. Neuman TR4/4A Bad news on my TR4 Triumph 8
roscoe Good news/bad news Austin Healey 11
C TR6 Frame Pics, some bad news Triumph 9
gbtr6 TR6 Good news, Bad news Triumph 10
J Bad News 1098 Spridgets 14
regularman New midget good news and bad news Spridgets 16
M bad compression news Triumph 10
DNK Wedge Bad News Wedge Info Triumph 0
VelodromeRacer VSCDA Grattan bad news Racing 4
JPSmit I've got some good news and some bad news Spridgets 7
zimmy good news, bad news Spridgets 19
T TR4/4A Some good news and some bad news on the TR4 Triumph 5
healeyboz bad news Spridgets 70
Z Front suspension - good and bad news..mostly good. Spridgets 12
Taz d news bad news Spridgets 29
T Wedge Bad news on the TR8 Triumph 16
G Good News and Bad News Triumph 10
zimmy hey guys, im back w bad news Spridgets 11
tahoe healey Bad news Austin Healey 16
Steve Bad news for TVR Other British Cars 15
C bad news for MG 2006 MG 8
L good news, bad news? MG 25
Guinn Bad news. Not the donut. MG 5
TypeRboy Bad news on the BDA.. Lotus 8
bighly Very bad news [2 die in Healey rollover] Austin Healey 11
AUSMHLY Bad 1st Motion Shaft or Mainshaft Symptoms Austin Healey 13
P TR6 Bad Luck? Triumph 51
jlaird MGB Follow up to my bad post on prewar MGs MG 4
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
T TR2/3/3A bad napa points Triumph 9
S TR2/3/3A How bad is this? Vertical link Triumph 12
D TR2/3/3A Bad parts. Triumph 16
charleyf TR4/4A Symptoms with bad condenser Triumph 14
AUSMHLY How to tell if a starter is going bad? Austin Healey 10
W TR2/3/3A Overheating Bad Triumph 12
Rut Help a bad memory out... Spridgets 6
Jim_Gruber Strange noises - Bad U Joint perhaps? Spridgets 10
M TR6 Fresh rebuild gone bad!!!!!!! Triumph 13
T TR5/TR250 Is it good or bad idea to grease an overdrive angle drive? Triumph 2
TR3TR6 TR2/3/3A Anybody else having a bad day! Triumph 31
S Is it a bad idea to buy a higher pressure radiator cap? Austin Healey 47
drooartz MGB Good people go to heaven, bad people replace MGB clutch hydraulics MG 2
JFS TR2/3/3A Bad Water Pump Triumph 11
P TR2/3/3A "MaXpeedingRods" con rods good or bad? Triumph 3
T TR4/4A Seems like a bad cylinder head or head gasket but what do you think? Triumph 19
D Removing servo . Good or Bad Austin Healey 12
PeterK TR4/4A Never seen a dual exhaust cobbed this bad before. Triumph 2
