Atrus
So, I decided that while I have the rear axle out of the car, I would take the time to wirebrush/sand it as it was cruddy as all get out and prime/paint it.
Axle housing is sitting loose in my driveway. I decide that I finally have no choice but to take the hubs off so I can remove the brake backing plate and paint the housing (I've been dreading this). Side #1 comes off with no effort. Side #2 moves a little and hangs up. I fight with it for a while, then say screw it and start cutting the nut off with my dremel. About 6 cutoff wheels and 30 mins later, the nut is in half, and I manage to fab a simple way to pull the hub off using an old brake drum.
I pull out the Moss catalog (you probably all know where this is going) to get the P/N for a new nut and I see that there are TWO parts numbers. Why, do you ask, are there two? Because one is a left hand thread! Yeah, didn't even occur to me.
I feel a little better about coming up with my method of removing the hub. I took the brake drum (which will be replaced) and ground down the lip on the inside near two of the bolt holes. Put the drum onto the hub backwards and threaded on two lug nuts. Used an 11/16" open end wrench and put it between the threads of the housing and the drum. Tighten the two lugs, and viola, the hub popped right off.
