Any tips for a [potential] first time Alpine owner
tdskip
Hi folks. I have a chance to buy a very nice Sunbeam at a good price, and am wondering if anyone here has first hand experience with them?
More of a cruiser by reputation, but any feedback or coaching for me?
MikeP
Check for rust as it can be expensive to repair. Common locations are,
1 Rockers, which are made up of 3 sections running the length of the lower body.
2 Wheelwells where the fender and the wheelwell meet, particularly at the top of the front wheel well and where the rocker ends are.
3 Ends of the X frame under the center body where it meets the inner rocker.
4 Front mounts for rear springs.
5 Rear spring mount itself usually stands up but the integral chassis leg can rust out on either side causing loss of integrity.
6 Front and rear floorpans where they're spotwelded to the x frame and around the edges. Dirt and water can get trapped underneath.
7 Windshield frame lower corners on series 3 to 5 will rust but you can't really tell unless you remove the glass and weatherstrip or it's really bad.
8 Lower front and rear fenders rust.
That about covers the most likely rust area. You can find it in other places but usually not as bad. Of course if your find is from the south or west where rust is unknown then so much the better.
Now as for mechanicals, blocks can crack near the generator/alternator mounting holes if proper coolants have been neglected. Rear ends will whine and if it's never been apart it should be disassembled to have thr ring gear bolts replaced. The lock tabs on them compress over time and the ring can loosen potentially causing a failure. Wire wheel hubs, if it has them, wear out, particularly if they haven't been greased. transmissions last fairly well although you find some that pop put of gear during deceleration due to worn gear hubs. Nothing really to be done about that right now.
Weatherstrip dries out and should be replaced. The windshield seal particularly becomes porous and lets water through.
Check to see that the wiring harness doesn't appear to have been messed with. Rewiring isn't difficult but will cost 250 - 300 dollars for a new harness.
Interior, with the exception of original floor mats can all be replaced if needed.
That's about it off the top of my head. If you have any questions I'll see what I can come up with.
Super 7
As to it being more of a cruiser, I'm not so sure. I like to Autocross my '68 4 door Cortina. At the local ABFM in Portland, I have never been beaten by a streetable MG or Triumph, except for once a Rotary powered Spit. There is a clean looking pale yellow Alpine which has beaten me twice.
S TR2/3/3A tips for mig plug welding vertically? Triumph 11
J Tips for quarter elliiptic spring install Spridgets 3
W TR6 Anyone add Exhaust tips to standard exhaust Triumph 4
PC DIY tips from Bo his self Other Cars 0
BoyRacer Need Tips on getting wiring harness through firewall Austin Healey 4
BoyRacer Tips on gluing new fabric to dash on my BT7 Austin Healey 10
HighAltitudeTR3 TR2/3/3A Leaky Carb Tips? Triumph 11
HighAltitudeTR3 TR2/3/3A Choke setting tips? Triumph 7
drooartz Installing front hubs, tips? Spridgets 15
bugedd Bench bleed tips Spridgets 14
S TR4/4A Electrical wiring tips Triumph 2
I Tips for installing intake manifold plugs in a stock Bugeye? Spridgets 6
TEM666666 Sprite MK1 Door liner rubber mat installation.. Need tips and recommendations. Spridgets 22
F Buying a 100.... tips Austin Healey 18
drooartz MGB Changing clutch hose - tips? MG 13
T Tips for Searching FORUM Navigation Questions 2
T TR4/4A Any tips on re-torquing TR4a head now that 500 are on the rebuild Triumph 7
T TR4/4A Tips on controlling heat coming up through shifter opening? Triumph 14
M tips please on removing starter motor on 100-6 Austin Healey 6
gbtr6 TR6 Rebuilding TR6 Engine, Tips? Triumph 7
bugedd Su adjustment tips Spridgets 7
B Seam Sealer/Caulking - Any Tips on When, Where, and What to Apply? Austin Healey 45
C Any tips on how to remove frozen pistons from drum brake Wheel Cylinders??? Austin Healey 11
PatGalvin TR2/3/3A Carpet Install Tips Triumph 12
Bob_Spidell Tips Austin Healey 6
Tinkerman TR2/3/3A Front Fender Installation Tips Triumph 3
Tinkerman TR2/3/3A Windscreen mounting tips 1960 TR3A Triumph 2
W Looking for tips: BJ8 roll up windows Austin Healey 10
I TR6 Any tips on removing flasher switch Triumph 3
M Radiator Hose tips? Spridgets 0
T TR4/4A Any tips on running the overdrive switch wiring down the steering column? Triumph 11
T TR4/4A Making an OD pressure gauge - any tips? Triumph 7
bugedd About to rebuild front end...any tips? Spridgets 5
B Spitfire Changing leaf spring bushing - any tips? Triumph 6
RedTR3 TR2/3/3A Tips for Breaking in a Rebuilt TR3 Engine Triumph 6
apbos Two Restoration Tips Spridgets 11
J Tips on Re-Assembling Lenses/Gaskets? Austin Healey 5
TulsaFred Rear Hub bearing and oil seal tips Spridgets 0
5 TR2/3/3A TR3 engine building tips needed Triumph 5
TulsaFred Bugeye rear wheel cylinder replacement tips Spridgets 10
Lbp Install l-t-d fasteners on new tonneau - Tips? Triumph 8
T Wheel cylinder fitting kit - any tips? Triumph 4
D Spitfire '65 Spit window regulator installation tips needed Triumph 0
J 67 IRS Exhaust Tips Triumph 2
RickB Painting tips anyone? Spridgets 13
RJS Water Pump Replacement Tips Triumph 8
Russ Austin TR2/3/3A TR3 Transmission Installation Hints / Tips Please! Triumph 14
aeronca65t Kasnter tips Triumph 8
Xte TIPS : Home made tool for the thermal sensor Austin Healey 7
JodyFKerr Tips & tricks on installing upright air compressor Restoration & Tools 15
