Anti-sway bar for a earlier BJ7
BG 62AH
Guys, Does anyone know the correct diameter of a stock anti-sway bar for a BJ7. When I bought my BJ7 as a project it had a .875" dia. front sway bar that was very poorly installed. I replaced it with a used .625" dia. bar (that I thought was the stock size) and bought bushings and mounting brackets from Moss. Fitment of the .625 bar and bushing/brackets is good.....but now that I have the car on the road, I am wondering what the correct size is?
Any info is appreciated.
Thank you.
You now have the stock size anti-sway bar installed. However, your car will handle much better with a larger bar and BJ8 springs.
L Sway Bar / Anti Roll bar bush replacement 100/6 Austin Healey 7
R TR4/4A Tr4a new anti sway bar, maybe almost perfect! Triumph 5
G Anti-sway bar question Spridgets 1
Got_All_4 TR5/TR250 ADCO Anti sway bar installation on the Tr250 Triumph 4
bigjones Sway bar [anti-roll bar] question Spridgets 8
S TR4/4A TR4A Anti-sway bar Triumph 1
Lin Anti-sway bar frame mounting plates Austin Healey 3
X Anti sway bar MG 6
beachbumbarry T-Series MGTD anti-sway bar MG 4
B Spitfire Spitfire Mk1 Rear Anti Roll Bar / Sway Bar Triumph 3
M MGB-GT front GT anti-sway bar on an MGB MG 15
S E-type IRS Anti-Roll [or sway] Bar Jaguar 0
Ed_K Installing new anti-sway arm bushings Austin Healey 3
Darrell_Walker Ratco anti-sway bars and coil-over rear shock Triumph 6
Got_All_4 Matching front and rear Anti sway bars Triumph 2
tony barnhill MGB MOTORSPORTS - MGB Anti-Sway Bars MG 21
Nunyas Rear Anti-sway/Anti-roll bars... MG 6
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
K TR2/3/3A Problem with the gear lever "anti rattle fix"..... Triumph 10
af3683 TR2/3/3A TR3B Anti-Freeze Change Triumph 23
K For Sale Triumph TR4 & 4A Gearbox anti vibration attachment Triumph Classifieds 0
K TR4/4A The 4A gearbox anti rattle contraption? Triumph 5
T Need an Anti-Tramp Bar? Austin Healey 6
S TR6 Anti Run-On Valve question. Triumph 4
FlyingCat Spitfire Anti-Roll Bar Triumph 6
AngliaGT Avanti II Spotted 0
Bob_Spidell Healey Anti-Theft Device Austin Healey 0
PC Avanti II Spotted 7
steveg Anti-run on solution Austin Healey 10
JimLaney Anti-seize or Thread locker ? Spridgets 2
55modified Rear anti-roll bar. Is it worth installing on a BN1? Austin Healey 22
J Healey BJ8 anti roll bar bushes Austin Healey 2
F Fitting anti-squeal kit to front calipers on BT7? Austin Healey 7
Got_All_4 TR2/3/3A anti rattle pin Triumph 6
D TR4/4A shifter anti rattle pin Triumph 2
bugedd Front anti roll bar Spridgets 11
Steve P. Info: removing anti-theft column lock on later cars Spridgets 0
J Bypassing battery cutoff switch, using is as anti-theft only? Austin Healey 20
tomshobby Have you checked your anti-freeze? Spridgets 1
tahoe healey disc brake anti squel pads Austin Healey 5
D TR6 Anti run-on valve Triumph 3
S Spitfire Question on anti run on valve 73 spitfire Triumph 5
K TR2/3/3A TR3 Gear Shift Anti Rattle Spring ##%&*rikerfrats Triumph 8
K No luck.. Gear Lever Anti-rattle Spring Install? Triumph 1
H Anti-Frezze expandtion thru overflow @ Shutdown Austin Healey 35
S TR2/3/3A shifter anti rattle spring tr3 Triumph 4
K TR2/3/3A TR3 Gearlever Anti-rattle spring&plunger Install? Triumph 6
I Bugeye anti-rattle plunger questions Spridgets 6
H Anti run on valve MG 6
