Anti-Rattle Spring and Plunger
jerrybny
A few months ago I had to put in a anti-rattle spring and plunger. I'm not sure where the one that should have been in there went. Well it looks like I need to put another one in again. I haven't pulled it apart yet but the gearshift is rattling again just like before. Any ideas on why the spring and plunger might be popping out. I was thinking the little recess where it sits might be worn and the added slop is allowing the spring to pop out. If this is the case what would be the best way to remedy this. Thanks
You think a little longer spring might increase the tension on the plunger and encourage it to stay in place ?
I think a longer/stronger spring will just make the problem worse. Either the lever or the cups it engages with are worn out, most likely the lever.
A longer and/or larger diameter plunger might help it stay in place, but I have no idea where to buy one and fabricating one might be tricky. It's pretty hard, I think.
Scrounging up a used lever in good condition would probably be easier.
Dave at TRF scrounged up a brand-spankin-new shift lever for me a few years back, still had the Cosmolene on it.
just recalling a similar stick shift rattling issue i had after replacing my clutch..
i was ready to order the spring/plunger assembly when someone suggested that the shifter knob might need a good tightening. long story short... i put new nut, flat and lock washers on the stick, twisted on the knob far as it would go. then brought the nut up tight to the knob (as tight as i could go without stripping the nut). noise has not returned.
apologies if this was already obvious to you.
K TR2/3/3A TR3 Gear Shift Anti Rattle Spring ##%&*rikerfrats Triumph 8
K No luck.. Gear Lever Anti-rattle Spring Install? Triumph 1
S TR2/3/3A shifter anti rattle spring tr3 Triumph 4
K TR2/3/3A TR3 Gearlever Anti-rattle spring&plunger Install? Triumph 6
jerrybny Anti-Rattle Spring Triumph 1
zimmy anti rattle spring and plunger Spridgets 21
K TR2/3/3A Problem with the gear lever "anti rattle fix"..... Triumph 10
K TR4/4A The 4A gearbox anti rattle contraption? Triumph 5
Got_All_4 TR2/3/3A anti rattle pin Triumph 6
D TR4/4A shifter anti rattle pin Triumph 2
I Bugeye anti-rattle plunger questions Spridgets 6
B Wedge TR8 front brake anti-rattle clips Triumph 1
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
af3683 TR2/3/3A TR3B Anti-Freeze Change Triumph 23
K For Sale Triumph TR4 & 4A Gearbox anti vibration attachment Triumph Classifieds 0
T Need an Anti-Tramp Bar? Austin Healey 6
S TR6 Anti Run-On Valve question. Triumph 4
FlyingCat Spitfire Anti-Roll Bar Triumph 6
AngliaGT Avanti II Spotted 0
Bob_Spidell Healey Anti-Theft Device Austin Healey 0
PC Avanti II Spotted 7
steveg Anti-run on solution Austin Healey 10
JimLaney Anti-seize or Thread locker ? Spridgets 2
55modified Rear anti-roll bar. Is it worth installing on a BN1? Austin Healey 22
J Healey BJ8 anti roll bar bushes Austin Healey 2
F Fitting anti-squeal kit to front calipers on BT7? Austin Healey 7
L Sway Bar / Anti Roll bar bush replacement 100/6 Austin Healey 7
B Anti-sway bar for a earlier BJ7 Austin Healey 3
bugedd Front anti roll bar Spridgets 11
Steve P. Info: removing anti-theft column lock on later cars Spridgets 0
J Bypassing battery cutoff switch, using is as anti-theft only? Austin Healey 20
tomshobby Have you checked your anti-freeze? Spridgets 1
tahoe healey disc brake anti squel pads Austin Healey 5
D TR6 Anti run-on valve Triumph 3
R TR4/4A Tr4a new anti sway bar, maybe almost perfect! Triumph 5
S Spitfire Question on anti run on valve 73 spitfire Triumph 5
Ed_K Installing new anti-sway arm bushings Austin Healey 3
H Anti-Frezze expandtion thru overflow @ Shutdown Austin Healey 35
Darrell_Walker Ratco anti-sway bars and coil-over rear shock Triumph 6
H Anti run on valve MG 6
J Anti corrosion strips - Worth it? Austin Healey 8
ecurie_ecosse T-Series Anti run on switch. MG 11
G Anti-sway bar question Spridgets 1
HAN8L1965 CounterAct electronic anti rust system? Spridgets 22
Got_All_4 TR5/TR250 ADCO Anti sway bar installation on the Tr250 Triumph 4
roofman Spitfire Anti run on valve ? spitfire 1500 Triumph 3
Hairyone Anti-roll bar Spridgets 13
M Teves Anti-Lock Brakes, All Models up to year 1992 Jaguar 4
tahoe healey Anti-freeze Austin Healey 10
