Alternator went bad! Bummer.
PAUL161
Such a beautiful day so we decided to uncover the "B" and take it out for a spin. Well, it never happened. I think a diode went bad in the alternator as there was a static discharge in the system, thus draining the battery. The alt. wouldn't charge unless I excited it by unplugging it and replugging it in while the engine was running. I'm not fooling with it as I emailed Tony about a new or rebuilt replacement. Such is life! When we uncovered it, it looked like it was pleading with us to take it for a drive. It was all shiny and we even had the top down. Bummer!
tony barnhill
Great Pumpkin - R.I.P
I got your email....why not just pull yours & have it rebuilt?
I can get one rebuilt for you or provide a new one...email later today.
PAUL161
PAUL161
I'll wait for your email Tony. What ever is the best/fastest way to get one. Does the later models have the same plug on the back as the earlier models. What's the difference, if any?
tony barnhill
Plugs & in my email I weas gonna ask you which plug you have...were it me, I'd pull it today, drop it off at a place that rebuilds them Monday & install it Wednesday....I'll have to get one rebuilt...or, if yours repairs easily, I can send you a good, used one that you can have as a spare on the shelf.
PAUL161
PAUL161
Tony, there's a place in Myrtle Beach that advertises they rebuild ALL makes. I'll check them out tomorrow. If they don't have the parts to rebuild this Lucas, I'll get a rebuilt one or new one from you. The rectangular hole in the back of the unit has three spade lugs, two large and one smaller. The plug on the wires is rectangular in shape with matching female receptors. I can't find any numbers on the case to match it with another unit. If it comes to that, I'll send a photo of the back cover. PJ
tony barnhill
They'll be able to fix it if its just normal stuff....if not, I've got lots of them.
PAUL161
PAUL161
Thanks Tony, I'll be in touch. PJ
PAUL161
PAUL161
Got my alternator back. Looks and works like new! 60 bucks, half the price of a rebuild from Moss. Thanks Tony for the advise. You saved me money.
tony barnhill
Anytime - that's part of what theAutoist.com is all about!!
T TR6 Alternator wiring Triumph 6
I MGB Alternator help MG 0
P Alternator Installation Pic Austin Healey 4
P Generator to Alternator Swap Austin Healey 2
W Generator or Alternator? Austin Healey 18
Writer2022 GT6 GT6 MK3 Alternator Problem Triumph 4
K TR2/3/3A Is it time for a new alternator??? Triumph 8
M Smog pump and alternator brackets Spridgets 0
V MGB Never occurred to me that my '66 would be positive ground. Does the presence of an alternator show that it's been converted? MG 22
A General MG 78 MG MIDGET ALTERNATOR SMOKES MG 5
E MGB external alternator regulator MG 2
DrEntropy MGB Generator to alternator swap MG 1
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
K TR2/3/3A Overtightening the alternator belt? Triumph 14
B TR6 Swapped Lucas to GM alternator Triumph 9
M TR6 Alternator Issue for 72 TR6 Triumph 7
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
G Spitfire Alternator troubles Triumph 2
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
TheRealDestrux MGB Unknown connector on alternator MG 6
R TR2/3/3A Amp Gauge-erratic reading after alternator conversion Triumph 39
lilifer_13 Spitfire New alternator doesn't fit - '78 Spit Triumph 2
AUSMHLY Generator to Alternator Swap Austin Healey 20
J TR6 1975 TR6 Alternator Advance/Retard spring(s) Triumph 1
Lin Fan belt for 1275 with alternator Spridgets 4
PAUL161 T-Series Dynamator Alternator conversion. MG 23
P '58 XK150 Dynalite Alternator swap question Jaguar 5
B Delayed charging Lucas alternator Triumph 1
Merlin63Tr4 TR4/4A Alternator or alternator in a generator case? Triumph 4
Walter74 Dynamo to alternator Austin Healey 2
S Stag Lucas 18ACR alternator conversion Triumph 5
Got_All_4 TR5/TR250 Rebuilt Bosch Alternator stops charging Triumph 0
donbmw TR2/3/3A Converted to alternator Triumph 14
90dog A H Spares Alternator Bracket Austin Healey 53
R TR2/3/3A generator to alternator Triumph 5
JPSmit Alternator help - please. Spridgets 21
I Bugeye generator/alternator conversion question Spridgets 7
Ripper01 TR6 110A Alternator Triumph 7
F TR2/3/3A I'm stuck... alternator/wiring/starting/? Triumph 2
Sopwith_Camel alternator eater Spridgets 20
longbridgehealey Alternator conversion and tach Austin Healey 9
S TR2/3/3A Alternator Triumph 7
apbos Positive Ground Alternator wiring. Spridgets 9
BoyRacer Wiring question for alternator conversion Austin Healey 3
RAC68 How does a 12 Volt Alternator charge a battery to read 18+ Volts Austin Healey 8
M TR2/3/3A Water Pump Belt After Alternator Conversion Triumph 6
J MGC Lucas alternator/regulator MG 3
