TR2/3/3A AE Pistons ?
karls59tr
Bronze
I saw a New set of AE pistons for sale. (just the top part not the rods} for $200. Are these the old school pistons that used to be sold for TR3's back in the day. Just speculating here but can liners be machined to fit these piston tops? Aren't piston and liners normally sold as a set? Would using these even doable or practical?
Sarastro
My TR4A came with oversized (0.030") AE pistons and bored liners. Victoria British also used to sell pistons and liners separately. I think it's like any other car: you can buy new pistons and bore the liners for them. Seems pretty silly to me, though; by time you do that, you've probably spent about as much as a piston and liner set would cost.
mctriumph
British Parts NW sells several sizes of liner sets. There is even an 89mm set. A good friend
is using these in his Tr4 and loves the extra torque. This is considered to be the max over bore.
But requires a special head gasket. Some where I have the part # for Vanolia 87mm pistons.
Also worth mentioning is the fact that forged steel rods are now very affordable, not like a few
years back. For a whole bunch of reasons these are the only way to go.
Mad dog
Rick_Thompson
When I did my first rebuild, my machine shop honed the liners to give me a .040 overbore....which meant 87mm pistons would fit it if I recall correctly. Yes, liners can be bored or honed.
dougie Pistons - Old vs New Austin Healey 12
S TR2/3/3A 87mm Venulia aluminum pistons , Triumph 2
KVH General Tech Fitting the Pistons and Sleeves Triumph 2
Got_All_4 TR6 Non Adjustable Stromberg Pistons Triumph 8
M TR6 WANTED....Nural pistons for TR6 Triumph 1
K TR2/3/3A Installing Brake Caliper pistons into the bore? Triumph 21
TomMull Using my press to remove stuck Girling caliper pistons Restoration & Tools 13
Got_All_4 For Sale Brake caliper pistons Ceramic Coated and more Triumph Classifieds 0
K TR2/3/3A S U Carb Chambers and Pistons Triumph 1
doc50 Met front brake pistons Other British Cars 4
Got_All_4 TR6 Ballancing the connecting rods and pistons. Am I lucky? Triumph 4
A TR2/3/3A TR3 Gods were good to me, got pistons out of calipers today Triumph 1
KVH General Tech Installing the Pistons and Rings Triumph 7
Bob_Spidell Pistons Austin Healey 10
J MGB Need help identifying pistons for 18V motor! MG 0
Marvin Gruber 4 ring vs 5 ring pistons Austin Healey 6
Rut TR4/4A 89mm pistons and liners Triumph 6
KVH General Tech Direction of Pistons for new County Brand Pistons from Moss Triumph 5
KVH General Tech Fitting the Pistons and Sleeves--Any TR Triumph 10
J General Tech Stainless-steel caliper pistons Triumph 8
2billydavies TR2/3/3A just removed the pistons/sleeves... can't believe she ran as well as she did! Triumph 6
2billydavies TR2/3/3A Replacing the pistons and wet sleeves Triumph 15
C Any tips on how to remove frozen pistons from drum brake Wheel Cylinders??? Austin Healey 11
J JE Pistons Austin Healey 1
S TR2/3/3A pistons have 4 rings Triumph 28
T Fitting New Pistons........... Austin Healey 2
5 TR2/3/3A TR3 pistons/liners? Triumph 10
J 89 mm pistons and liners Triumph 13
G Plasma Nitrated cali vs stainless caliper pistons Triumph 1
RCarr Pistons for '54 BN1 Austin Healey 7
martx-5 Caliper Pistons Triumph 2
D lookin for pistons bj8 Austin Healey 1
T pistons wrong way round Austin Healey 22
tinman58 TR2/3/3A 89mm pistons TR3 Triumph 7
S Crank and pistons needed near Minneapolis? British Motor Corp 5
af3683 Carb Pistons on SU H6 Triumph 7
S Jahn's Pistons Spridgets 11
Got_All_4 TR2/3/3A SU pistons sticking in TR3 Triumph 11
aeronca65t A&E pistons--front/back? Racing 2
Morris 9:1 flat top 1500 pistons Spridgets 0
Aggudabbu Regarding pistons 21253 Spridgets 5
wangdango New pistons for vintage racing 100M? Austin Healey 17
Randy Forbes Polymer coated pistons... Austin Healey 9
hymodyne MK III pistons and rings Triumph 3
martx-5 TR2/3/3A SU Pistons - TR3 Triumph 10
deadair TR2/3/3A TR3A -- Removing front brake pistons Triumph 19
Tr4dude Are Repco pistons any good? Triumph 3
T Regular vs stainless steel pistons for calipers Triumph 13
W Wanting to upgrade my 1500 to 1622 - need pistons MG 12
