adding aluminum to alloy boot lid?
wangdango
I have an alloy/aluminum boot lid for my vintage racing AH 100LeMans, it needs to have some aluminum "added" to the two bottom corners. How should I go about doing this? TIG welding, then filling it to fit? Ideas, thoughts, etc??
thanks
Ed
D TR2/3/3A tr3a occasional seat padding Triumph 10
Frameman 1949 Adding an Ammeter Austin Healey 67
KLUTZ Wedge Adding Blue Devil head gasket sealer Triumph 4
D Adding hardener to Rusroleum Restoration & Tools 5
G Adding a Brake Booster / Brake Calipers Austin Healey 3
K TR2/3/3A Adding STP to Castrol 20W50 oil? Triumph 6
steveg TR6 Adding a PCV valve Triumph 5
T BJ8 Carpet Padding Austin Healey 4
M TR6 Adding Some Power Triumph 8
R Adding attachments to your Post FORUM Navigation Questions 1
banjojambo TR2/3/3A TR3A adding weight to improve handling Triumph 5
T Adding a third brake-light Spridgets 5
Jim_Gruber Pedal Box - Reassembly - Any issue with adding a spacer in the middle of the pedals Spridgets 5
simon1966 Does taking a stock BN1 and adding M bits increase its value? Austin Healey 10
T TR2/3/3A Adding an auxillary fuse box to TR3 Triumph 5
CJD TR2/3/3A Source for Horsehair Padding? Triumph 10
bugedd Carpet glue and roll bar padding Spridgets 4
B TR2/3/3A New Seat Springs and Padding Triumph 14
I adding a second fuel pump Austin Healey 16
J TR2/3/3A Seat kit padding installation Triumph 1
T Heritage Carpet and padding for 100 Austin Healey 10
jfarris TR2/3/3A Adding Seatbelts to a TR3 Triumph 4
Jim_Gruber Adding another BE to the family - Bugsy III Spridgets 5
drambuie Adding a backup fuel pump Anyone have pictures? Austin Healey 6
bash TR6 Adding Miata Seat Speakers to TR6 Triumph 2
K TR2/3/3A Adding a Voltmeter to a TR3? Triumph 8
RAC68 Adding a Leaf to my Spring Leafs this Fall Austin Healey 15
B TR4/4A Adding OD to Standard TR4 Gearbox Triumph 18
drooartz Padding under carpet -- necessary? MG 18
M_Pied_Lourd TR2/3/3A TR3A Resto/Adding Metal Question Triumph 8
W Carpet padding? Triumph 8
W Carpet Padding? Restoration & Tools 1
W Panel padding?? Spridgets 3
wkilleffer MGB Adding E-Code headlights to a '74 MGB MG 0
JodyFKerr MGB Adding "modern" A/C to an MGB MG 10
JodyFKerr TR6 Adding "modern" A/C to a TR6 Triumph 12
vping T-Series Adding a battery cut off switch. MG 16
Geo Hahn Adding Diode to OD Wiring Triumph 2
NutmegCT jute padding Restoration & Tools 5
M Adding Picture FORUM Navigation Questions 2
W Adhesive for seat padding Spridgets 1
M Adding Disc Brakes to a BN2 Austin Healey 7
wkilleffer Adding relays to the low and high-beam circuits MG 10
D Adding electrical relays, to save old stuff Triumph 16
jvandyke thoughts on adding vacuum ports to carb spacers Spridgets 2
A TR2/3/3A TR-3 Fuel Tank padding Triumph 6
theleisure Wiring Question, Adding Reverse Spotlight Spridgets 9
T TR6 Adding lightness to a TR6 Triumph 26
Dave Russell Adding PCV valve to four cylinder Austin Healey 3
