3 point seat belts options / location
drooartz
Bugeye would be tough, Tom. I'm just running lap belts in mine. Unless you have a roll bar you're not going to get a great angle for the shoulder mount. Others may have a better idea.
drooartz
I got a set from Moss that use the eye bolt through the floor (belts have hooks on them). They come with huge fender washers to reenforce the area around the eye bolt -- I used one washer on each side of the floor. My sprite already had holes drilled in the floor, one in each corner of the floor behind the seats.
twas_brillig
Gerard - thanks!
We've got lap belts, but I'd prefer to have 3 pointers. We've almost got the BE fully road worthy and I want to check into a roll bar (not for rolling - a bit of protection against getting t-boned by a Hummer in an intersetion).
Suggestons (anyone?) for a 3 point seat belt to be installed in a BE with the upper point hung off a rollbar?
Thanks,
Doug
PS: Gerard - you sure this is original British? Nary a 'twixt' nor 'whilst'? Thanks for providing the info!
Gerard
I have dual shoulder belts in my Bugeye race car. There is a horizontal bar that runs behind the driver's seat (part of the roll bar) to secure the belts. I think it's the only other alternative (or something similar)
The_architect
I have 3 point lap and shoulder belts in my Bugeye. These are the ones that VB sells 3 point lap/shoulder seat belt in the right column and center of the catalog page I have linked to.
I have a rollbar and simply removed one of its bolts to install the hardware for the shoulder anchor bracket. Sorry I don't have a photo, but it is located near the top of the rear fender well.
The secret to making these belts functional is getting them adjusted right. What you want is for the buckle to be low on your waist, down near the transmission tunnel. If the buckle isn't "low and tight across your waist" then the belt going to your shoulder is going keep slipping off.
It is a real pain to get these particular belts adjusted so they fit though, I must say, especially when a person who isn't ordinarily riding around with you becomes a passenger. And, the belts have a tendency to twist and get in the way, and the buckle is forever falling into the gap between the seat and the tunnel.
Retractable belts would be much easier to use for these reasons. I hesitated to buy the generic ones because I was not sure that I could get the geometry right. There is no way to adjust the distance between the floor and buckle on the ones that VB offers (upper left hand corner of that page).
Another option I might consider for the future is drilling the rollbar and bolting the hardware that anchors the shoulder belt so that it is above the shoulder, similar to what you have in a modern automobile. I haven't driven around enough with them installed to decide whether that is necessary.
The main thing, as I noted above, is to take your time before you leave and adjust the belts so they fit right. And, of course, ALWAYS drive very carefully.
Good luck!
CL
ichthos
I have three point belts in my Bugeye. The issue for me was getting the attachment as high as possible for the third point, especially since I am a little on the tall side. I was going to attach it to the wheel well (like what came from the factory for my TR6) but then I noticed there is bracing that comes down behind the seat over the rear wheel well. First I welded a nut to the back of a steel plate. Next I welded the plate behind the brace so that I could just screw in the bolt without having to get my fingers behind the brace. If I get a chance, I will post a pic tonight when I get home. I am by no means and expert, but it was the best I could do to get the angles correct.
Kevin
tr6nitjulius For Sale 4$ale: 3 Point Seat Belts Red Triumph Classifieds 0
T Three-Point Seat Belts Austin Healey 8
M For Sale vintage 3-point retractable seat belts MG Classifieds 0
R 3-point seat belts on late production BT7 MKII Austin Healey 7
T Looking for two part, three point seat belts Austin Healey 6
69MGC MGC 3-point Seat Belts MG 3
RAC68 Are 3-Point Seat Belts Safe in a Healey? Austin Healey 38
T TR4/4A Tr4a - 3 point seat belts with Miata seats Triumph 8
T TR4/4A Retractible 3-point seat belts for TR4a Triumph 6
ronzet 3 point Seat Belts - Installation Austin Healey 4
tinman58 3 point seat belts Triumph 7
TR4A_IRS TR4/4A 3 point seat belts on a TR4? Triumph 10
T 3 point seat belt options in a Bugeye Spridgets 5
I 3 point seat belt installation help Spridgets 3
tinman58 3 point seat bealts Triumph 2
LastDeadLast Needed three point seat belt pics Triumph 7
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
Rut 3 point belts in a Bugeye? Spridgets 9
T Clutch Pedal Engagement Point Austin Healey 1
M Mallory Dual point distributor Austin Healey 0
Michael Oritt Retractable two-point seatbelts Austin Healey 12
wangdango '67 XKE Mallory dulal point to Pertronix Jaguar 0
Joe_Healey 3 point belts Jaguar 6
bfitz TR6 72 TR6 clutch high engagement point Triumph 16
Lotus Club SoCal Ballast Point Long Beach Social Lotus 2
Joe Reed General MG MG logo ball point pens... MG 0
D Experience with Mallory twin point distributor. Austin Healey 5
B Mallory Dual Point gap Austin Healey 4
K TR2/3/3A Point gap and dwell..... Triumph 12
Popeye TR4/4A TR4A rear engine lift point - photos? Triumph 14
Lotuswins BJ8 Water Pump Flow - point of reference Austin Healey 3
aeronca65t General TR Kas Kastner Race - Summit Point Triumph 0
K TR2/3/3A Point Gap? Triumph 3
T Spitfire Need help placing date and point of origin Triumph 5
Tinkerman TR2/3/3A 1960 TR3 A Hood stick mounting point? Triumph 11
Michael Oritt Saturday feature: VRG Turkey Bowl at Summit Point Racing 10
TR4A_IRS TR4/4A Well, it had to happen at some point, I suppose... Triumph 23
aeronca65t MG Focus Event -May 17-19 at Summit Point MG 0
B BJ8 door seal attachement point. Austin Healey 4
skippymga Sears Point [Sonoma Raceway] Swap Meet Racing 3
C Mallory dual point recurve help needed Austin Healey 6
AngliaGT FREE!! - 4 Tickets to Sears Point WTC Racing 3
T TR2/3/3A TR3 floor / frame mounting point question Triumph 13
J Can anyone point me to... Spridgets 7
aeronca65t Summit Point-1974 Racing 1
F Using 12 point ARP style rod and main bolts Spridgets 9
M jacking point rocker debris Spridgets 3
L BJ8 three point belt anchor Austin Healey 2
G Which way to point a "Wanna-be"? Triumph 15
dougie Small Bore at Summit Point - Michael Oritt Racing 5
