280I/ TASMIN HEADLIGHTS
G
When I got this car a few months ago the headlight motor wires were unplugged. The lights were at the up position. After several other projects on this car I have gotten to the headlights. The cluster of 3 wires on the passenger side had melted together. I pulled them apart and the wires themselves are still intact. They still do not go up and down on there own. I have not yet pulled the lights out of the car. I am guessing that I am dealing with a electrical problem not a mechanical one. What is the next step? Replace the relays? I think there are 3.
hottvr
If you didn't know the lights can be lowered manually with a ratchet and extention from underneath the car. I forgot what size socket it is. The headlight motor was used from TR7 or 8.
Rick
tr7andtvr
They go up and down manually just fine.
My tr7's get stuck down after long periods of sitting. Once I maually move them up and down a couple of times they work great.
The TVR's have other problems.....
TXCoyote
Sorry, missed your post earlier. On mine, a ratchet is not needed there is a knob to raise or lower them easily reachable. The units are the same as a TR7 so the motor and linkage are interchangeable. The same repair procedures apply although I would guess the TVR will be harder to get at. If you have not yet bought or found a copy of Steve Heath's Wedge Bible, you should do so. It is the single best source for Wedgies. I would geuss you have a short if the wires are melted, likely in the motor. Luckily TR7 units are fairly plentiful.
R For Sale Nice TVR 280i For Sale Other British Classifieds 6
J 1985 TVR 280i Speedometer Cable TVR 4
H 280i oil filter TVR 2
G Triple Weber DCNFs on 280i V6? TVR 1
S 280I parts? TVR 0
Feathers 280I radiator TVR 5
H 280i Tires TVR 7
M FOR SALE: 280i 2.8 v6 engine and 4 speed transmission for sale TVR 2
A 1985 280i - stalls when warm TVR 6
J Just purchased an 84 280i from the UK TVR 15
tr7andtvr 280i Rear End 4.20? TVR 0
tr7andtvr 280I weather strip source TVR 1
tr7andtvr carpet pad? 280i TVR 3
tr7andtvr headlight upgrade 280i TVR 4
tr7andtvr 280i seat swap? TVR 8
GT6_Mark 280i Manual to Power Steering Conversion TVR 17
tr7andtvr 280i Ford 302 Conversion TVR 22
Sparkie New 5 speed conversion for 280i guys TVR 32
tr7andtvr 280i engine conversion? TVR 1
tr7andtvr 280i For Sale [before I put it on ebay] $6500.00 TVR 1
tr7andtvr who knows anything about this 280i on ebay? TVR 2
T 280i auction sale Other British Cars 8
H Hey Hayfever, 280i in Austin on EBAY Other British Cars 1
T 1985 TVR 280i Other British Cars 14
H TVR 280i Other British Cars 14
JPSmit TVR Tasmin Spotted 0
tr7andtvr Tasmin VS Dragon TVR 9
GT6_Mark '84 Tasmin Advice Wanted TVR 5
tr7andtvr Tasmin Breaks TVR 3
T TVR Tasmin parts interchange Other British Cars 2
tr7andtvr TVR Tasmin will not go over 4250 rpm? Other British Cars 32
tr7andtvr need some tvr tasmin help!!!! Other British Cars 7
W TR6 Headlights Triumph 5
PAUL161 T-Series MGT 7 inch LED Headlights MG 4
B TR4/4A Headlights Blink Off Triumph 15
7 polishing headlights Restoration & Tools 5
K TR2/3/3A Headlights and their extreme current draw? Triumph 4
K 68 midget. No horn, headlights, turn signals Spridgets 9
Rob Glasgow Halogen Headlights Austin Healey 30
S TR2/3/3A Triumph TR3 Tail Light Issue when Headlights and Brakes are On Triumph 15
rgfrey 1959 Low Beam Headlights Not Working Austin Healey 5
K TR2/3/3A High beams seem to be stuck on when the headlights are turned on? Triumph 3
B TR6 LED Headlights Thouights? Triumph 20
T Ignition warning light remains on and headlights come on Austin Healey 8
JPSmit Green Mini - with halo headlights Spotted 0
P TR6 New headlights Triumph 24
Martinld123 Just installed LED headlights in BN2 Austin Healey 15
R TR2/3/3A Sealed-beam headlights Triumph 15
R Sealed-beam headlights Austin Healey 13
KVH TR4/4A No Headlights Triumph 4
