1st oil change on rebuilt motor
prb51
Ok, got 500 miles (almost) on newly rebuilt motor.
Is it too early to go to a syn oil (amsoil 10-40, good flat tappet stuff) or should I wait a bit for more 'wear-in'...
Suggestions?
Unless you have noticed problems with excessive oil burning, should be no problem with synthetic.
Then the rings are seated as well as they will ever need to be; and there is no reason not to switch to synthetic if you please.
I run Valvoline 20W50 full synthetic in all my Triumphs; it seems to work well. No experience with Amsoil, though.
Never used it either but it was recommended to me by a friend...they make it specifically for flat T motors as it has the old levels of ZDDP in it.
Thanks Randall for the info btw.
B Oil pressure on the 4 cylinder cars? [1st post!] Austin Healey 4
Hamish Racing Personal best time and 1st on handicap Harewood Hill Climb Racing 1
AUSMHLY BJ8 1st into 2nd Austin Healey 0
AUSMHLY 1st Motion Shaft Bearing Austin Healey 7
tr6nitjulius General Tech Visual/audible Fix no 1st/2nd gear Triumph 0
tr6nitjulius General TR Final solution to no 1st/2nd gear issues Triumph 2
tr6nitjulius TR6 TR6 No 1st/2nd problem/solution Triumph 4
M T-Series MG TD 1st/2nd sliding hub end play MG 1
AUSMHLY Remanufactured Laygear with welded 1st gear Austin Healey 20
AUSMHLY Bad 1st Motion Shaft or Mainshaft Symptoms Austin Healey 13
AUSMHLY 1st Motion Shaft Play Austin Healey 3
Hamish Racing 1st sprint of the season Racing 10
TomMull TR2/3/3A 1st gear again Triumph 3
R TR2/3/3A Starting car for 1st time after rebuild. Triumph 13
KVH General Tech Grinding Gears in Shift From 1st to 2nd Triumph 13
P TR2/3/3A Help needed. TR3A transmission popping out of 1st gear Triumph 13
JPSmit 1st Gen Acura NSX - spotted Other Cars 1
Tom74TR6 Off Topic British Cars and Coffee in North Salem NY Nov 1st MG 0
Tom74TR6 Off Topic British Cars and Coffee in North Salem NY Nov 1st Triumph 9
Tom74TR6 British Cars and Coffee in North Salem NY Nov 1st Jaguar 0
Tom74TR6 British Cars and Coffee in North Salem NY Nov 1st Austin Healey 0
C Looking for 1st British sports car TVR 6
R bj7 hard shifting into 1st & 2nd gear Austin Healey 6
J BN2 Tranny Jumping Out of 1st Gear Austin Healey 1
H 1st and 2nd gear problems Austin Healey 5
Jer Another Co-Pilot, New Parts & 1st Ride Spridgets 10
6 It's snowing, 1st real one here! Spridgets 5
Jer Wife's 1st drive alone in Bridget Spridgets 7
Randy Harris Congrats AUSMHLY on another 1st Place! Austin Healey 7
hilsideser Rochester Hills, Michigan on June 1st Spotted 0
J Buying a Sprite as 1st time classic car buyer Austin Healey 10
doates 1st Real Drive Triumph 7
kodanja 1st Drive of 2011' Triumph 4
robdmau 1st things to look for before driving... Spridgets 10
JPSmit 1st time - 1500 engine on ebay. Spridgets 13
rikiwho123 starting rebuilt 1300 for 1st time Triumph 7
RickB MGB-GT 1970 MGB GT restored by Chris Longo - 1st in show! MG 10
Tr4dude TR4/4A anybody want 1st crack on tr4 bitsbefore fleabay Triumph 2
R lost 1st and 2nd! Spridgets 10
NardisCNC 1st Time Overhaul / Performance questions?? - 1275 Spridgets 17
NardisCNC Gearbox Noise in 1st!! - Is this normal?? Spridgets 13
Westfield_XI 1st Drive in 11 replica !! Lotus 16
Westfield_XI 1275 firing order- help needed for 1st start! Spridgets 9
Got_All_4 Used my Color Tune for the 1st time. Sweet! Triumph 10
T New member, 1st question MG 19
theleisure Stuck in 1st Gear Spridgets 11
toysrrus My sons 1st. Classic Car: `87 Alfa-Romeo Milano Other Cars 44
jngeorge Our 1st Rd Trip in our new Daily Driver MG 6
N 1947 Norton Fired up for 1st time British Motorbikes 8
George Zeck She now has a pedigree [1st Place] ...... Spridgets 8
