1964 Starter
sprite
I need to replace the starter on my 64 B and have one of those lightweight starters but am not sure if they are compatible. My car is negative ground, having been converted many years ago. Am I better off getting a conventional starter? Since the car is now negative ground will a stock starter need to be wired differently to work properly?
The stock starter does not care about ground polarity, since it uses a wound field. Since both armature and field change polarity, the motor runs the same way regardless of supplied polarity.
I didn't take it apart to see why, but the lightweight gear-drive starter I bought for my TR3 works just fine with the conversion to negative ground. Works great for me, and eliminates that annoying condition where the Bendix kicks out but the engine doesn't start.
I seem to remember that when I was first looking into converting my old Bugeye from positive to negative ground, that there wasn't anything to do with the stock starter (just polarize the generator and of you go).
I'd probably keep the lightweight-style starter.
On an unrelated note, where in RI are you? I grew up in North Scituate, and my parents are still in Smithfield.
I was raised in Woonsocket, later lived in Nevada for 20 years and now have retired back in RI in South County.
Thanks. That is exactly what is happening with the starter in the car now which I believe is the original one so I am not surprised it at the way it kicks out but no starting.
Likely the ring gear is worn in one area. The original Bendix gear and the proclivity of the engine to STOP in the same orientation cause a pattern wear in the ring gear that will tend to kick the Bendix out at the same position in the rotation, whether the engine lights or not.
A gear reduction starter might be the trick for you. It engages from the other side of the flywheel than your original so flywheel wear won't matter and it fires off much better than stock. I get them for MGA for $179 and for 1968-80 MGB for the same price but I'm unsure if either has the correct spacing for the 3 main MGB. If you're interested, let me know and I'll check with the manufacturer. Thanks. Basil (not the Basil that graciously runs this site)
Thanks. I purchased one of those lightweight starters many years ago but now I see there are two models and I am not certain if the on I have is compatible with the ring gear on my 64 B.
P Wanted WTB - Cockpit Molding 1964 BJ8 Austin Healey Classifieds 0
George Zeck SOLD!! 1964 AH Sprite MKII Spridgets Classified 0
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
BJ8Healeys Location of VIN tag, 1964 Sprite HAN8L43421 (I know it's stamped on the frame. Looking for the tag.) Spridgets 8
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
J BJ8 Rear Seat Changes, 1964 to Later Austin Healey 9
S 1964 BJ8 Project Valuation Austin Healey 21
Hamish Racing General TR 1964 period racing uk Triumph 1
L For Sale 1964 Austin FX4 London Taxi Other British Classifieds 1
C Wanted WANTED Heater fan motor and housing for 1964 MK3 Sprite Spridgets Classified 2
S For Sale Sunbeam Tiger Factory Workshop Manuals – 260 and 289 Models - 1964 - 1967 Other British Classifieds 0
L For Sale 1964 Austin FX4 Black Cab Other British Classifieds 0
Mick2me For Sale Various MG Midget/Austin Healy Sprite parts for sale [approx 1964] UK only Spridgets Classified 4
Mick2me For Sale Various MG Midget/Austin Healy Sprite parts for sale [approx 1964] UK only MG Classifieds 0
N For Sale 1964 Triumph TR4 street racer Triumph Classifieds 0
FredApplerot For Sale Pace Setter muffler for 1964-74 Spridget - Brand New Spridgets Classified 5
crya For Sale 1964 Austin Healey 3000 Austin Healey Classifieds 2
T Rebuild kit for fuel pumps 1955 to 1964 Spridgets 1
H trunk floor pan replacement 1964 BJ8 Austin Healey 2
Marla TR4/4A Just bought a 1964 Triumph 23
4tecdog Fleet of new Morris Minor Vans 1964 Other British Cars 4
Lin Fuse box - new product in my current project, a 1964 jaguar mark tw Austin Healey 10
R New to Forum and Excited to start restoration on my New AH 1964 Sprite Austin Healey 6
AUSMHLY Any 1964 1/2 mustang fans here? Austin Healey 4
J 1964 AH 3000 operating temperature Austin Healey 10
Elva164 Mike's 1964 Elva Courier MkIV Build Thread! Racing 56
H AH 3000 SCCA race photos, Austin 1964 Austin Healey 12
apbos TR4/4A 1964 TR4 on BAT Triumph 1
L 1964 BJ 8 Grille Austin Healey 6
J Finding a correct 1964 BJ8 steering wheel Austin Healey 1
JBann Spitfire Do you think it's worth it? - 1964 Spitfire MK1 Triumph 33
J Is the Tach lit on a 1964 BJ8 Austin Healey 3
M 1964 3000 MkII Austin Healey 11
I 1964 Sprite for Parts or Restore Spridgets 1
walshja $10k for a 1964 sprite Spridgets 5
Tabcon TR4/4A Automotive Review - 1964 TR4...WOW! Triumph 5
thechileman TR4/4A My 1964 TR4 Triumph 23
N Clutch Wanted 1098 motor 1964 Sprite Mkll Spridgets 4
N 1964 sprite engine paint color Spridgets 3
Exotexs 1964 MK-X LHD 4-speed maual Jaguar 6
tony barnhill 1964 MkII Midget Spridgets 41
R 1964 Austin-Healey Austin Healey 5
RickB 1964 Midget on eBay -closing today, nearly 10K nfi Spridgets 10
kurts100 MGB Can you help verify this is a 1964 MGB MG 12
Shinsen774 Painting 1964 MBG Heater MG 2
tiga2 SLO c. 1964 Spridgets 6
Keoke 1964 AH BJ8 Austin Healey 2
D MGB Hi, Restoring a 1964 MGB MG 18
R Rack & Pinion Conversion Healey 3000 1964 Austin Healey 11
G Lotus super seven 1964 Extra car to buy Lotus 1
