1964 AH 3000 operating temperature
jsteinberg48
My water gauge is at 190 after 1 hour at 50 mph. What is the factory spec (which I can't find) for the operating water temperature?
Should it be 180? or lower?
Thank you very much.
Jeffrey Steinberg
Jeffrey Steinberg
I don't think there is a factory spec but if my Healey ran at 190 I'd be happy with that. You didn't mention the ambient temp. Don't assume that your temp gauge is accurate.
180. Is that right?
I think 180 is the most common thermostat. That's what I have, and my car runs at 185 to 190 no matter what the outside temperature as long as I'm moving. I think 190 after 1 hour at 50 mph is very normal.
Austin-Healeys are known for running hot. Usually, they'll hold set point (thermostat) temp when cruising--exceptions are pulling up a grade on a hot day and similar stressful conditions--but start to heat up when stuck in traffic. The 'cures' have been discussed at great length, but the best bang for the bucks come with a clean (hot tanked) block, uprated (clean) radiator core, an aftermarket fan (flex or 'Texas Cooler'), a fan shroud and extra baffling around the radiator. Side louvers probably help, though I've never had them (lack of airflow through the engine compartment has been cited as one of the heating causes).
My BJ8 will stay at or below 180deg most of the time. It has an uprated core, flex fan and shroud and the engine was hot-tanked at rebuild about 100K miles ago. Sitting at idle, or in slow-and-go traffic on a warm day the temp will rise to 200deg or more. At 65deg ambient and 50MPH, your temp should be 180 or less with a 180 thermostat; your engine will hardly be working in top O/D. If your car has the original core, the block has not been cleaned, and you have the stock fan that would explain your 190 temp. Also, check your timing--if it's retarded you'll get overheating, and running too lean will contribute (up to a point). The higher running temp won't hurt anything, until you get stuck in traffic on a warm day and you won't have as much margin before boiling.
Mine is standard and runs at between 160-180 depending on Ambient temp and traffic. A jam and hot weather might push it up to 190. The cooling system is standard with a recently re-cored radiator.
Mine ran in the 180-190 range for some time until I discovered that the coolant level was low. I topped up only to discover that the top-up was being discharged via the drain tube when the vehicle hit operatng temperature. I then tried topping up when the vehicle was already at temperature (to a level just above top of fins) and it has remained at the correct level since that top-up. It now runs reliably at 170F in an ambient temperature of 50-80F.
My gauge is efficent BUT have the needle a little forward and easy it signed 212°F to control the exactly temperature I have used this BARBECUE digital probe (max T range 300°F), finding that my car never go over 190°F/180°F(80/90°C)
https://picasaweb.google.com/lh/photo/63c4INIddZ6SqP59JwjNTdMTjNZETYmyPJy0liipFm0?feat=directlink
Now, I control with it, the OIL temperature at the entrance of my OIL cooler(80-90°C max- in summer time and after long range trip)
Next summer probably my steaks
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
crya For Sale 1964 Austin Healey 3000 Austin Healey Classifieds 2
H AH 3000 SCCA race photos, Austin 1964 Austin Healey 12
M 1964 3000 MkII Austin Healey 11
R Rack & Pinion Conversion Healey 3000 1964 Austin Healey 11
George Zeck SOLD!! 1964 AH Sprite MKII Spridgets Classified 0
BJ8Healeys Location of VIN tag, 1964 Sprite HAN8L43421 (I know it's stamped on the frame. Looking for the tag.) Spridgets 8
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
J BJ8 Rear Seat Changes, 1964 to Later Austin Healey 9
S 1964 BJ8 Project Valuation Austin Healey 21
Hamish Racing General TR 1964 period racing uk Triumph 1
L For Sale 1964 Austin FX4 London Taxi Other British Classifieds 1
C Wanted WANTED Heater fan motor and housing for 1964 MK3 Sprite Spridgets Classified 2
S For Sale Sunbeam Tiger Factory Workshop Manuals – 260 and 289 Models - 1964 - 1967 Other British Classifieds 0
L For Sale 1964 Austin FX4 Black Cab Other British Classifieds 0
Mick2me For Sale Various MG Midget/Austin Healy Sprite parts for sale [approx 1964] UK only Spridgets Classified 4
Mick2me For Sale Various MG Midget/Austin Healy Sprite parts for sale [approx 1964] UK only MG Classifieds 0
N For Sale 1964 Triumph TR4 street racer Triumph Classifieds 0
FredApplerot For Sale Pace Setter muffler for 1964-74 Spridget - Brand New Spridgets Classified 5
T Rebuild kit for fuel pumps 1955 to 1964 Spridgets 1
H trunk floor pan replacement 1964 BJ8 Austin Healey 2
Marla TR4/4A Just bought a 1964 Triumph 23
4tecdog Fleet of new Morris Minor Vans 1964 Other British Cars 4
Lin Fuse box - new product in my current project, a 1964 jaguar mark tw Austin Healey 10
R New to Forum and Excited to start restoration on my New AH 1964 Sprite Austin Healey 6
AUSMHLY Any 1964 1/2 mustang fans here? Austin Healey 4
Elva164 Mike's 1964 Elva Courier MkIV Build Thread! Racing 56
S 1964 Starter MG 7
apbos TR4/4A 1964 TR4 on BAT Triumph 1
L 1964 BJ 8 Grille Austin Healey 6
J Finding a correct 1964 BJ8 steering wheel Austin Healey 1
JBann Spitfire Do you think it's worth it? - 1964 Spitfire MK1 Triumph 33
J Is the Tach lit on a 1964 BJ8 Austin Healey 3
I 1964 Sprite for Parts or Restore Spridgets 1
walshja $10k for a 1964 sprite Spridgets 5
Tabcon TR4/4A Automotive Review - 1964 TR4...WOW! Triumph 5
thechileman TR4/4A My 1964 TR4 Triumph 23
N Clutch Wanted 1098 motor 1964 Sprite Mkll Spridgets 4
N 1964 sprite engine paint color Spridgets 3
Exotexs 1964 MK-X LHD 4-speed maual Jaguar 6
tony barnhill 1964 MkII Midget Spridgets 41
R 1964 Austin-Healey Austin Healey 5
RickB 1964 Midget on eBay -closing today, nearly 10K nfi Spridgets 10
kurts100 MGB Can you help verify this is a 1964 MGB MG 12
Shinsen774 Painting 1964 MBG Heater MG 2
tiga2 SLO c. 1964 Spridgets 6
Keoke 1964 AH BJ8 Austin Healey 2
D MGB Hi, Restoring a 1964 MGB MG 18
G Lotus super seven 1964 Extra car to buy Lotus 1
Z FS: 1964 Sprite MKII Roadster Spridgets 8
