TR2/3/3A 1960 tr3 a to gasket or not to gasket
sp53
Some of those rubber pieces on the bottom are a bear to get in because they are either made wrong or just inferior. They can go in a wrong way, so make sure to look it over good. I would lay it on the car and see how the flap sits and how the T shape slides into the frame then compare.
TRF sells one that goes in friendly, but might not lay as flat as some other venders. I use wd40 and pull and stretch on many off them. The last one I got was from TRF and it slid right in the grove. Taking closer pics of the ends and magnifying them on the computer might help see the correct orientation of how they slide.
Steve
CJD
The rubber you are holding in the pic is what is used between the glass and frame. The one from the frame to the scuttle has a lip on one end.
DavidApp
I seem to recall you should install it so it is tilted backwards that way when the windshield is installed the rubber makes a better seal to the body.
David
TR3Acustodian
You have the wrong part. You need a replacement like the one you took off. It looks like the part you received is for surrounding the windshield glass to the metal frame. It is for folding over the edge of the glass and inserting it into the frame. Not what you need.
Charley
You are correct Charley. Appreciate the post. Have already ordered correct piece. Thanks
charleyf
Once you get the correct part, note the advice given above. There is a front and a back side. Some are marked and a lot are not marked as to front or rear. I have not been able to slide the piece in at all well. I get about `1/2 or less and then hit to much friction. I have usually resorted to lining it up and then pushing in the inserted part with a dull puttty knfe or screw driver. Lube helps which ever way you go. A good foaming window cleaner is what I now use. (A tip from a Safelite installer). Easy clean up that way with no residual mess.
Charley
TR3Acustodian
Charley
Wish I would have read this before attempting to install. Used WD40. Not help. Used 4 in 1 oil. helped a little. War of attrition gain 2 " springs back in inch. Took 3 people 45 minutes to accomplish this but it is in and looks amazing.
Donald1107
Question for anyone with experience replacing the windshield glass on a TR3. How do you separate a 64 year old windshield glass from the windshield frame? That is, without breaking the frame? Safelight won’t touch it.
charleyf
The two pieces are held together by very small bolts and two small angle brackets at the bottom corners. If this has not been apart for many years those bolts are likely rusted tight. Try soaking those in rust dissolver. This is not likely to work. You may need to drill the heads off of those bolts. You want to remove the bottom frame piece . Then proceed with the glass removal. There are small replacement pieces available from TRF + others. But you will likely have to deal with some rethreading.
Charley
Donald1107
Thank you, Charley. This is helpful, and I will plan on frozen bolts on the bottom corners. Assuming I can get those off, I am still concerned about how to extract the glass from the side and top frames, given it hasn’t been separated since I purchased the car in 1986, and probably not since built in 1959. The glazing is surely brittle. Any advice on that?
Don
charleyf
Don
If there is any sealer on the edges, I would use a razor blade or X-Acto knife on the edge of the frame. The sides of the frame are a bit flexible. Start at the bottom of each side and try to pull the glass loose. You could also try a long thin screw driver inserted inside the frame and between the frame and glass.
I always try the least forceable method first.
Charley
Donald1107
Good advice! Thank you again. Since the original windshield is irreparably cracked, I’ve thought of just breaking it to pieces that can be easily pried loose. I don’t know if it is tempered glass, but will find out (with eye protection, of course).
charleyf
That is a good plan.
Charley
Graham H
New windscreens aren't that expensive but finding someone to fit it is the hard part. If the frame and all the fittings and seals are in good shape I would look for a screen shop to supply and fit the glass. I did all the restoration on my 3A but when it came to the screen I sent it out to a windscreen shop.
Graham
charleyf
Graham
Donald,
I suggest that if you end up installing the glass yourself that you do a search here and on triumphexperience.com for comments on others experience with not only how to do it but also parts suppliers. They are not all the same parts.
Charley
CJD
If the glass is already damaged, that makes it easier! +1 to using a screw driver on the lower corners between the glass and the frame. Once loosened, you can work it loose around and up. The entire frame is chrome plated brass, so not that strong...don't over-bend it. It can be re-chromed if you have the time.
sp53
I have used a sheet metal tray and filled the tray with gasoline and let it sit until everything turned to goo. I would brush the gas up onto the frame with a paint brush in tight places and pour gas over the tough spots. The windshield I had someone installed with this chalking compound that had hardened. The gasoline worked well, but was messy.
steve
Pool Dad 1960 TR3 engine serial number Triumph 14
O For Sale New Member from NJ 1960 TR3 Triumph Classifieds 1
R TR3 1960 refurbish Triumph 14
B Wanted Wanted: Trailer hitch for 1960 TR3-A Triumph Classifieds 7
T TR2/3/3A Accelerator Say 1960 TR3 Triumph 11
B 1960 TR3 With rust in cylinders Triumph 7
Tinkerman TR2/3/3A 1960 TR3 A More body panel assembly questions. Triumph 5
Tinkerman TR2/3/3A TR3 A 1960 adjusting apron Triumph 4
pbraun TR2/3/3A 1960 TR3 photos Triumph 17
Tinkerman TR2/3/3A Bonnet stay rod 1960 tr3 a Triumph 11
Tinkerman TR2/3/3A Original wind screen 1960 TR3 A [free to a good home] Triumph 2
Tinkerman TR2/3/3A 1960 TR3 A Door Check Assembly Triumph 13
Tinkerman TR2/3/3A 1960 tr3 a petrol tank front millboard question Triumph 6
Tinkerman TR2/3/3A 1960 tr3 a upholstery question Triumph 2
Tinkerman TR2/3/3A DOOR PANEL HELP NEEDED 1960 TR3 A post 60000 car Triumph 5
Tinkerman TR2/3/3A 1960 TR3 A Hood stick mounting point? Triumph 11
Tinkerman TR2/3/3A Apron installation 1960 tr3 a Triumph 11
Tinkerman TR2/3/3A 1960 tr3 a carpeting the floor Triumph 8
Tinkerman TR2/3/3A 1960 TR3 A hood stick color? Triumph 2
Tinkerman TR2/3/3A Windshield glazing TR3 A 1960 Triumph 7
Tinkerman TR2/3/3A Wind scereen support bracket tr3 a 1960 Triumph 3
Tinkerman TR2/3/3A 1960 TR3 A Additional steering question Triumph 4
Tinkerman TR2/3/3A 1960 TR3 A Steering wheel play or Lash Triumph 2
Tinkerman TR2/3/3A Parts help needed 1960 tr3 a Triumph 5
Tinkerman TR2/3/3A 1960 tr3 a seat tack strips Triumph 19
R TR2/3/3A 1960 TR3 Restoration Triumph 8
O TR2/3/3A 1960 TR3 Front Brakes Triumph 2
Tinkerman TR2/3/3A 1960 TR3 Post 60000 elec equipment Triumph 12
boxofparts TR2/3/3A Dads TR3 way back in 1960 Triumph 16
J TR2/3/3A New Member 1960 TR3 Triumph 11
L TR2/3/3A 1960 TR3 cooling???? problem Triumph 9
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
W For Sale 1960 TR3A for sale Triumph Classifieds 0
J Wanted Hood (Bonnet) for a 1960 BT7 Austin Healey Classifieds 0
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
dougie 1960 Austin Healey 3000 Works Lightweight vs. 1962 Ferrari GTO Austin Healey 6
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
5 Sold My 1960 Bugeye Spridgets 10
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
B Fluctuating Fuel Gauge 1960 Bugeye Spridgets 4
J Wanted 1960 Sprite Bonnet Spridgets Classified 3
KellyRob BMC GEARBOX 1960 British Motor Corp 2
Fanch00 My 1960 BT7 History Search Austin Healey 1
poolboy General TR LeMans 1960 Triumph 8
jlaird 1960 AH Sprite Spridgets 96
C 1960 BT7 Thoughts Austin Healey 14
L For Sale 1960 Austin Healey steel oem wheels Austin Healey Classifieds 0
F Installing AC in my 1960 Healey Austin Healey 14
