1950 Prefect Vacuum Tank
als
The Prefect I bought came without a vacuum tank, so I bought a used one. The problem is that I can't figure out the right place to mount it. My manuals don't help.
Does anyone know where this usually goes?
Thanks in advance
Al
<THUD!>
umm... David... I think the cold is affecting you. Or th' fumes from all that plumbing repair...
Contact Micheal MacSems (IFHP@aol.com).
He's a contact for the North American English Ford Registry.
He's got lots of info,or can put you in touch with an
expert on Prefects.
- Doug
Nah, maybe it is the chill? I have a large collection of factory lit on Fords, as my Granny is fitted with a 100E motor and a shorrock. Just want to be sure.
Cheers, David.
/bcforum/images/%%GRAEMLIN_URL%%/wink.gif
...just so yer safe 'n warm enuff. I was a'fear'd you were showin' signs of OldTimer's!
Moochas grass in your arse, Doc. No worries. It is to warm up by weeks end...snow in Malibu yesterday! I do have a vacuum tank from a 1959. Al, do you need to know the pipe arrangment as well?
Cheers, David.
The tank is fitted to the left side wheel arch on early cars. Later on the floor pan near the front mudguard apron. The tank has tabs for fitting...should be easy enough to find the holes in the panels?
Cheers, David.
I'm curious. What is the purpose of a vacuum tank?
The theoretical "purpose" is to improve the performance of the windshield wipers, which are vacuum driven. On my car the slightest acceleration increase stops the wipers in their tracks. I don't how much better it will be with a reservuor (sp?) of vacuum, but it couldn't hurt.
The tank is unfilled by the vacuum from the engine and is in turn attached to the wiper motor under the dash.
Thanks for the input everyone... I'll go look for the holes.
Al
David - I think the pipe arrangement will reveal itself, but if not I will post another question.
Thanks
Al
I saw that Malibu "snowstorm".. Holy COW!!!
Just so YOUR leaks and ruptures are resolved. /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
And on a more sobering note: Just learned Art Buchwald has passed.
Thanks for the explanation, Al. I had a '50 Oldsmobile Futuramic years ago that was equipped with vacuum-powered windshield wipers. It could have used a reservoir because the wipers seemed to always quit at the very moment I needed them most!
Vacuum wipers sometimes need a little rejuvenation. If you carefully disassemble and clean the "motor" and then soften the leather with Neatsfoot Oil it may help. I had to do that with my old farm truck.
Have a nice day
Steve
I've seen those vacuum reserve tanks on Prefects do their job very nicely, thank you! Probably 20 years ago now, my then-brother-in-law had a very nice Prefect, in which the wipers did seem to keep going in situations that would've brought the wipers on my '51 Chevrolet to a halt!
I didn't know about the vacuum reserve tank until he showed it to me. At that moment, I was struck by the fact that it (a Trico part as I recall) bore a most striking resemblance to a vacuum tank I remembered on my mom's old '68 Ford LTD Country Squire! On that car, it served as a reserve tank for the vacuum-operated headlight doors.
Bugeye58 said:
Steve, your mystery truck looks like an old Dodge M-37.
Jeff
Very good sir!
That is a '58 M-37 that I bought from a junk yard about 8 years ago. It only had 10,000 miles on it but I had to rebuild the engine because of the mice in the cylinders. I use it on the farm and I just installed a snow plow in an attempt to change the weather.
I also do cross-word puzzles.
Have a nice day
Steve
Not sure if you got an answer Al but the tank mounts in front of the radiator. There should be some nuts welded to the floor panel there for it.
Bayless
algot1901 1950 Prefect E93A-946480 - door bottom rubber Other British Cars 14
algot1901 1950 Prefect starter Other British Cars 1
algot1901 1950 Ford Prefect Brake Lining Other British Cars 1
algot1901 How did people in the 1950's manage to fit in the Prefect???? Other British Cars 16
algot1901 1950 Prefect Ign Switch Other British Cars 1
algot1901 1950 Prefect Speedo Cable Other British Cars 8
algot1901 1950 Prefect Starter Other British Cars 10
algot1901 1950 Ford Prefect Paint Other British Cars 5
algot1901 Electronic Ignition for 1950 Prefect 1172cc Eng Other British Cars 10
algot1901 1950 Prefect Headliner Other British Cars 17
algot1901 1950 Prefect/Anglia Trsnmission Main Bearing Retainer Other British Cars 2
algot1901 Rear Seat Bottom/Frame for 1950 Ford Prefect Other British Cars 12
A Body Paint Codes for 1950 Prefect E493A Other British Cars 1
A Rubber parts for 1950 Prefect E493A Other British Cars 6
A 1950 Ford Prefect Windows Other British Cars 4
A 1950 Ford Prefect Floor Covering Other British Cars 2
S For Sale MG TD & TF Factory Workshop Manual on CD/ROM. 1950 - 1955 Models. MG Classifieds 0
T For Sale Parting out a 1950 Austin A-90 Atlantic drophead Other British Classifieds 5
J Wanted 1950 Austin sheerline A125 need brakes Other British Classifieds 0
J 1950 Austin a 125 Shoreline need parts FORUM Navigation Questions 2
D 1950 Jaguar Mark V Sunroof Question Jaguar 0
K 1950 Standard Vanguard Other British Cars 2
AUSMHLY 1950 Healey Siverstone Austin Healey 8
B 1950 Rover 75 P4 Cyclops value? Rover / Land Rover 9
L Need help restoring a 1950 Morris Minor FORUM Navigation Questions 0
L Need help restoring a 1950 Morris Minor Other British Cars 2
G Brake fluid recomendations - 1950's JAG XK140 Jaguar 19
Z Austin A70 Hampshire [1950] as a donor car Austin Healey 1
kennypinkerton British Specials... from the 1950's Other British Cars 38
kennypinkerton More specials... 1950's Racing 1
Tullamore 1950 Simca Pinninfarina Sport Huit Other Cars 1
T looking for any info on a 1950 austin A40?? Other British Cars 5
Sherlock TR2/3/3A 1950's Triumph TR2 Francorchamps coupe Triumph 3
KLUTZ 1950 FORD ANGLIA. in Old Car Trader. Other British Cars 13
Kira Smiths Clocks Pre 1950 Other British Cars 6
B 1950 Healey Silverstone D-Type on E-bay Austin Healey 1
bighly 1950 MG YA [For Sale] MG 2
Bayless New Prefect progress Other British Cars 7
Bayless The Prefect Grille Other British Cars 0
Bayless More Prefect Progress Other British Cars 2
algot1901 50 Prefect wood roof support / bow Other British Cars 8
algot1901 Window Channel Ford Prefect Other British Cars 5
algot1901 Brakes for Anglia / Prefect Other British Cars 2
Bayless My Prefect update Other British Cars 5
algot1901 My Prefect in her B-Day Suit and playing with rust-Flash! Other British Cars 19
algot1901 Carburator 50 Prefect 1172cc engine 10hp Other British Cars 4
TRMark Ford Anglia/Prefect USA parts supplier Other British Cars 7
Bayless Even more progress - the Prefect Other British Cars 5
L !953 Ford 4 door Prefect Other British Cars 3
KLUTZ Wow.. A Perfect Prefect ....... Other British Cars 2
