1950 Prefect Speedo Cable
algot1901
Bronze
Can someone with an Anglia or Prefect tell me where the speedometer is routed, I know it goes from the gear to the right side of the car and passes through the tranny cross member but I can find no way to get it thru the fire wall is it possible that it passes thru the center floor pan?
I'll try to check tomorrow. You are talking about the firewall on the way to the speedo head, right?
Oh, I found a photo. That's the speedo cable about 6 inches below the coil and just at its right edge in this photo. Hope this helps.
Hi
The cable you are talking about is the brake, I heard from a fellow in SC and he showed me where the speedo cable goes, From the attachment on the tube it goes to the passenger side door and goes thru the trans bracket (big Hole) from there it goes to the upper right of the toe board where you will see a notch in the body (very top right) it then goes towards the right vent and up under the dash to the speedo.
Did I confuse you?
Oops, my bad. I bet you are right. I will be at the shop this morning and will get the answer for you.
I managed to get 3 photos. 1) is from the floor, looking up. You can see the cable come in from the top-right and go up between the frame rail and the diagonal brace and pass through a slot actually on the slanted part of the floor against the outer edge. 2) is where it comes through the floor and goes up and through the package shelf. 3) is coming through the shelf and headed to the speedometer.
Thank you it all helps in fact if I do ask for info I do not toss it it is printed and put in a manila envelope for future use
Thank You
Keeping any file on a rare car is very smart.
I have hit a snag, small spares has no listing for a weather gasket on the spare tire cover does anyone have one and a photo would be nice
Thank you
algot1901 1950 Prefect E93A-946480 - door bottom rubber Other British Cars 14
algot1901 1950 Prefect starter Other British Cars 1
algot1901 1950 Ford Prefect Brake Lining Other British Cars 1
algot1901 How did people in the 1950's manage to fit in the Prefect???? Other British Cars 16
algot1901 1950 Prefect Ign Switch Other British Cars 1
algot1901 1950 Prefect Starter Other British Cars 10
algot1901 1950 Ford Prefect Paint Other British Cars 5
algot1901 Electronic Ignition for 1950 Prefect 1172cc Eng Other British Cars 10
algot1901 1950 Prefect Headliner Other British Cars 17
algot1901 1950 Prefect/Anglia Trsnmission Main Bearing Retainer Other British Cars 2
algot1901 Rear Seat Bottom/Frame for 1950 Ford Prefect Other British Cars 12
A Body Paint Codes for 1950 Prefect E493A Other British Cars 1
A Rubber parts for 1950 Prefect E493A Other British Cars 6
A 1950 Ford Prefect Windows Other British Cars 4
A 1950 Prefect Vacuum Tank Other British Cars 22
A 1950 Ford Prefect Floor Covering Other British Cars 2
S For Sale MG TD & TF Factory Workshop Manual on CD/ROM. 1950 - 1955 Models. MG Classifieds 0
T For Sale Parting out a 1950 Austin A-90 Atlantic drophead Other British Classifieds 5
J Wanted 1950 Austin sheerline A125 need brakes Other British Classifieds 0
J 1950 Austin a 125 Shoreline need parts FORUM Navigation Questions 2
D 1950 Jaguar Mark V Sunroof Question Jaguar 0
K 1950 Standard Vanguard Other British Cars 2
AUSMHLY 1950 Healey Siverstone Austin Healey 8
B 1950 Rover 75 P4 Cyclops value? Rover / Land Rover 9
L Need help restoring a 1950 Morris Minor FORUM Navigation Questions 0
L Need help restoring a 1950 Morris Minor Other British Cars 2
G Brake fluid recomendations - 1950's JAG XK140 Jaguar 19
Z Austin A70 Hampshire [1950] as a donor car Austin Healey 1
kennypinkerton British Specials... from the 1950's Other British Cars 38
kennypinkerton More specials... 1950's Racing 1
Tullamore 1950 Simca Pinninfarina Sport Huit Other Cars 1
T looking for any info on a 1950 austin A40?? Other British Cars 5
Sherlock TR2/3/3A 1950's Triumph TR2 Francorchamps coupe Triumph 3
KLUTZ 1950 FORD ANGLIA. in Old Car Trader. Other British Cars 13
Kira Smiths Clocks Pre 1950 Other British Cars 6
B 1950 Healey Silverstone D-Type on E-bay Austin Healey 1
bighly 1950 MG YA [For Sale] MG 2
Bayless New Prefect progress Other British Cars 7
Bayless The Prefect Grille Other British Cars 0
Bayless More Prefect Progress Other British Cars 2
algot1901 50 Prefect wood roof support / bow Other British Cars 8
algot1901 Window Channel Ford Prefect Other British Cars 5
algot1901 Brakes for Anglia / Prefect Other British Cars 2
Bayless My Prefect update Other British Cars 5
algot1901 My Prefect in her B-Day Suit and playing with rust-Flash! Other British Cars 19
algot1901 Carburator 50 Prefect 1172cc engine 10hp Other British Cars 4
TRMark Ford Anglia/Prefect USA parts supplier Other British Cars 7
Bayless Even more progress - the Prefect Other British Cars 5
L !953 Ford 4 door Prefect Other British Cars 3
KLUTZ Wow.. A Perfect Prefect ....... Other British Cars 2
