1950 Ford Prefect Brake Lining
algot1901
Bronze
I have a problem with my brakes, the linings are riveted (I would never trust bonded) but the rub comes with the dimensions 30mm wide by 5mm in thickness and according to small spares in England the linings are 30mm wide by 4mm in thickness, without a brake machine I would never be able to grind 1mm off the linings and keep them in tolerance over the entire surface here is there responce "
We sent you the 7W-2021 linings which should measure 30mm wide x 4mm thick and have not had any feedback back saying they do not fit.
Please advise"
Here is a set of linings for one axle with the number 7Y-103E see photo. So any ideas how to grind 1mm off the entire lining
We've a shop here that does trucking companies' brake and clutch relining, they've done our Rolls Royce brake work for years. P'raps there's a shop similar in your area? They may laugh at you for the "toy-like" shoes, but I'd bet they could do the job.
algot1901 1950 Ford Prefect Paint Other British Cars 5
algot1901 Rear Seat Bottom/Frame for 1950 Ford Prefect Other British Cars 12
A 1950 Ford Prefect Windows Other British Cars 4
A 1950 Ford Prefect Floor Covering Other British Cars 2
KLUTZ 1950 FORD ANGLIA. in Old Car Trader. Other British Cars 13
algot1901 1950 Prefect E93A-946480 - door bottom rubber Other British Cars 14
algot1901 1950 Prefect starter Other British Cars 1
algot1901 How did people in the 1950's manage to fit in the Prefect???? Other British Cars 16
algot1901 1950 Prefect Ign Switch Other British Cars 1
algot1901 1950 Prefect Speedo Cable Other British Cars 8
algot1901 1950 Prefect Starter Other British Cars 10
algot1901 Electronic Ignition for 1950 Prefect 1172cc Eng Other British Cars 10
algot1901 1950 Prefect Headliner Other British Cars 17
algot1901 1950 Prefect/Anglia Trsnmission Main Bearing Retainer Other British Cars 2
S For Sale MG TD & TF Factory Workshop Manual on CD/ROM. 1950 - 1955 Models. MG Classifieds 0
T For Sale Parting out a 1950 Austin A-90 Atlantic drophead Other British Classifieds 5
J Wanted 1950 Austin sheerline A125 need brakes Other British Classifieds 0
J 1950 Austin a 125 Shoreline need parts FORUM Navigation Questions 2
D 1950 Jaguar Mark V Sunroof Question Jaguar 0
K 1950 Standard Vanguard Other British Cars 2
AUSMHLY 1950 Healey Siverstone Austin Healey 8
B 1950 Rover 75 P4 Cyclops value? Rover / Land Rover 9
L Need help restoring a 1950 Morris Minor FORUM Navigation Questions 0
L Need help restoring a 1950 Morris Minor Other British Cars 2
G Brake fluid recomendations - 1950's JAG XK140 Jaguar 19
A Body Paint Codes for 1950 Prefect E493A Other British Cars 1
A Rubber parts for 1950 Prefect E493A Other British Cars 6
A 1950 Prefect Vacuum Tank Other British Cars 22
Z Austin A70 Hampshire [1950] as a donor car Austin Healey 1
kennypinkerton British Specials... from the 1950's Other British Cars 38
kennypinkerton More specials... 1950's Racing 1
Tullamore 1950 Simca Pinninfarina Sport Huit Other Cars 1
T looking for any info on a 1950 austin A40?? Other British Cars 5
Sherlock TR2/3/3A 1950's Triumph TR2 Francorchamps coupe Triumph 3
Kira Smiths Clocks Pre 1950 Other British Cars 6
B 1950 Healey Silverstone D-Type on E-bay Austin Healey 1
bighly 1950 MG YA [For Sale] MG 2
AngliaGT Saw These Today (This is FORD Country?) Spotted 2
AngliaGT '64 Ford F100 Spotted 2
AngliaGT 1969 Ford Galaxie Spotted 3
algot1901 Window Channel Ford Prefect Other British Cars 5
algot1901 How about an English Ford Folder FORUM Navigation Questions 1
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
JPSmit Ford Taunus - never seen on in the flash before Spotted 4
Sherlock 1982 Ford F150 stepside vs 1975 Triumph TR7 Other Cars 4
AngliaGT New Supra,BaT Ford Bronco Spotted 0
C Wanted Ford Kent Pre-Cross Flow Gasket Other British Classifieds 4
TRMark Ford Anglia/Prefect USA parts supplier Other British Cars 7
Lin Ford Versus Ferrari Question Austin Healey 23
C Ford pre-crossflow valve train Other British Cars 2
