Onslo the Sprite runs
Bayless
I haven't posted much on my Sprite in a while but I have been busy. Yes, I made the decision to call him Onslo. His stablemate, the Prefect, will be Daisy. They were two of my very favorite characters. The body is complete except for the hood. This being a LBC forum, everyone should know what that is. I have one but not in pristine condition. Since I don't intend to ever raise it except for unexpected emergency, I will probably just patch and install it. I do have a boot to cover it that looks good. But enough. This was supposed to be about running today.
I completely checked the wiring and corrected any found discrepancies a couple of months ago and got all the gauges and switches installed. Next was to check the motor. It was fully overhauled in 2000 and not even turned since. I removed the valve cover and turned the engine by hand to verify all valves actually opened and closed. then I bought a battery and turned it by the starter a few times until I got oil pressure, 40 psi on the starter (plugs out). Then I had to build the exhaust. Local shop wanted way too much. Finally, it was time to try. First the fuel pump didn't run at all. Apparently I had wired it for negative earth. After correcting that, it ran but didn't pump so we rigged a gravity feed system. Still no luck. The points were glazed or something that corrected just by checking the gap. Finally, the carb needles were stuck closed. With that handled, he fired right up. I only ran it for a few seconds since no coolant yet and I really wanted a working fuel pump. More tomorrow, I hope.
Looks fabulous! far too tiny (and neat) for an Onslo - but, great name none the less.
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 8
D For Sale 1958 A-H Bugeye Sprite Austin Healey Classifieds 3
CARSINC Progress On My 1965 Sprite (update) Spridgets 3
F Sprite Gearbox Spridgets 5
CARSINC Sprite bonnet emblems Spridgets 4
George Zeck SOLD!! 1964 AH Sprite MKII Spridgets Classified 0
apbos New long term project. Sprite powered rear engined race car. Spridgets 9
drooartz A disassembled sprite takes up a lot of space! Spridgets 30
CARSINC For Sale Sprite Shift Lever Spridgets Classified 0
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
CARSINC For Sale Sprite Differential Spridgets Classified 0
CARSINC For Sale AH Sprite Axles and Hubs Spridgets Classified 0
Bayless What size battery for my '67 Sprite? Spridgets 5
CARSINC 1965 Sprite Bugeye Spridgets 5
CARSINC Sprite Electrical System Information Spridgets 2
Boink 3D Sprite Model Spridgets 3
A Sprite Tacho Spridgets 2
BJ8Healeys Location of VIN tag, 1964 Sprite HAN8L43421 (I know it's stamped on the frame. Looking for the tag.) Spridgets 8
S Calling All Spridget Owners & Race Fans - Sprite Turns 65 Spridgets 3
Bayless How does '67 Sprite top attach to body? Spridgets 3
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
D Whitworth on 59 Sprite. Spridgets 11
N For Sale Austin Healey Frogeye Sprite Spridgets Classified 0
D Sprite Model Identification Austin Healey 2
S Sprite Fuel Pump Upgrade Austin Healey 1
C For Sale Center wiring harness for a 1959 Sprite Spridgets Classified 0
Bayless My primrose Sprite Spridgets 3
C Removing AH Sprite Mk 1 windscreen washer pump Restoration & Tools 2
Bayless A Sprite gets some paint finally Spridgets 2
N Sprite "Ribcase" Transmission Austin Healey 3
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
T Wanted Bugeye Sprite RHD tonneau cover. Austin Healey Classifieds 0
tr6nitjulius For Sale 1967 Austin Healey Sprite Mark 111 Spridgets Classified 0
johntennyson Anyone Know These Guys? Or Remember Sprite-Midget Owners' Group? Spridgets 29
J Wanted 1960 Sprite Bonnet Spridgets Classified 3
J Wanted Austin Healey Sprite Bonnet Austin Healey Classifieds 4
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
SD Bugeye For Sale 59 sprite Spridgets Classified 9
R Has this ever happened to you? Any odd Sprite story... Spridgets 8
A Early 1967 AH Sprite - installing steering column and new directional switch? Spridgets 0
Pythias Sprite Winged Bonnet Badge.... ANYONE? Spridgets 16
Editor_Reid FIRST Sprite For Sale Spridgets 1
lbcspinners New article today from Hagerty Media: the Austin-Healey Sprite Austin Healey 0
equiprx BUG EYE SPRITE, One of a kind print, Signed by the photographer Austin Healey Classifieds 0
S For Sale Early Sprite & Midget Speedometer/Tachometer/Generator etc. Spridgets Classified 2
BJ8Healeys For Sale Midget/Sprite nose section - used [Moss Motors P/N 455-145] Spridgets Classified 0
Kurtis Bugeye Sprite front frame rail horn replacement Spridgets 5
B Bugeye Sprite Wiring Diagram Spridgets 4
C Seat Cover Bugeye Sprite Mark 1 Spridgets 5
