Seat Slide Bearings
cmac0703
1960 3000. The ball bearings on the driver side seat slide have come out and the seat is now very loose. We need assistance on how to properly get them back in place.
The car was being detailed and when we got it back yesterday the driver seat was wobbly. When we removed the bottom driver seat we found 4 ball bearings loose on the carpet. We assume someone tried to adjust the seat a bit too much, but we are not entirely sure.
Can anyone assist us with how to properly get the ball bearings back in place?
I did a full 'restoration' of my BJ8's driver's seat rail (actually, I just wanted to replace the studs that hold the seat frame down, but I had to completely disassemble). It may be possible to do this repair 'in seatu' (heh) but it will certainly be easier, with a greater chance of success on the bench. Under the car, there are, IIRC 6 'T-nuts' that have to be taken out to get the rails out, after you remove the seat bottom and frame from the top (6 studs and nuts; the studs are often stripped, bigger job to replace them).
On the bench, you should see what needs to be done. The ball bearings are restrained between the two rails--one 'inside' the other--with pins at each end to keep the bearings in place and limit travel. I can't tell you what happened without seeing the rail, but it would take a lot of force to break those pins. To replace the ball bearings, you'll need to drift out at least one pin, if it isn't gone already, replace the balls, then replace the pin with a suitable roll pin. The bearings, IIRC, are 5/16" dia.
pkmh
Hi Cmac,
Bob beat me to the punch in answering your question.
Maybe to provide an aid in the form of a visual, I did a record sketch when I had my first Healey. I too, was in need of refurbishing both seat slider mechanisms. The ball bearings were complete and fine on mine. And one of my, what I call a, "Tack Weld Threaded Stud," on the driver side had sheared away from the floor pan from perhaps, over tightening at the factory, resulting from having inadequate structural stability of the seat secured to the floor, making it unsafe (Oh, like that really matters in a Healey?).
Anyway, from the sketch enclosed, you can see there is this 1/8" diameter rod (Bob referred to as a pin and I came up with my own concoction term as a, "Bearing Stop"), that was in the way of conveniently removing the one defective stud. Again and as a "ditto" to Bob's answer, that 1/8" diameter rod does help in preventing the bearings from rolling out found in between the top and bottom rail. It was necessary for me to completely cut away the pin/stop to gain convenient access and begin completely removing the defective stud from the bottom rail.
From my notes, you can see I had to purchase a new piece of 1/8" diameter steel rod (stock). Then place bearings back in between the rails, then cut to slide new piece of rod through the existing side holes of the lower slide rail, then solder/weld.
As a word of advice, one should make sure to extend the rod just enough outside the inner rail to prevent the bearings having any opportunity of slipping out. But by the same token, make sure the rod overall length does not come in contact with the outer rail's motion, thus preventing potential binding (overall length of rod as my sketch begins to suggests).
Hope the above helps in some way,
Paul
B Seat Slide Installation Questions Austin Healey 14
S Wanted Rear Seat Slide Bolts, BJ8 Austin Healey Classifieds 0
B TR2/3/3A anyone help me identify the screw attaching seat slide to the floor? Triumph 8
bluemiata90 TR2/3/3A tr3 seat slide rail locations Triumph 3
A BJ8 Rear Seat slide bolts Austin Healey 1
C MGB Re strapping a MGB seat bottom MG 2
T TR4/4A TR4 seat buffer problem Triumph 5
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
A MGB Seat Cover Installation MG 1
tr6nitjulius For Sale 4$ale: 3 Point Seat Belts Red Triumph Classifieds 0
D TR2/3/3A layout for lap type seat belt Triumph 5
R Vixen 2500 Seat Buckets TVR 3
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
Celtic 77 MGB Seat webbing replacement. MG 1
B BJ8 Seat Sliders Austin Healey 4
Got_All_4 For Sale 1969 TR6 Driver Seat Triumph Classifieds 0
D TR2/3/3A tr3a occasional seat padding Triumph 10
TomMull MGA Rumble seat MGA MG 3
T Three-Point Seat Belts Austin Healey 8
B Seat Inserts Austin Healey 6
Michael Oritt Best Seat Trim Adhesive Austin Healey 8
Celtic 77 MGB Seat Diaphragm replacement MG 0
D New seat covers Spridgets 11
Celtic 77 MGB 1977 seat webbing replacement. MG 1
shadowfever Seat runner with lever Spridgets 2
F TR4/4A Seat rail extension Triumph 4
KVH General Tech Seat Upholstered Panel Triumph 2
shadowfever Midget seat nuts and bolts Spridgets 2
shadowfever Moss Motors MG Midget seat covers Spridgets 6
shadowfever 65-69 Spridget seat Diaphragms Spridgets 5
Challenger TR4/4A Seat Retainers Triumph 1
JohnGone Wanted '80 MGB without seat belts? MG Classifieds 3
D Rear Seat Side Panels, BT7 Austin Healey 3
M For Sale vintage 3-point retractable seat belts MG Classifieds 0
Mickey Richaud Wanted Wanted: BJ8 Seat Track Sets (Both Sides) Austin Healey Classifieds 5
A For Sale '74 TR6 original seat frames Triumph Classifieds 0
J For Sale Triumph Tr2/3 seat foams Triumph Classifieds 1
F Wanted TR3A rear seat peg and clip Triumph Classifieds 2
EricJNewman MGB Modern Seat Tracks in MGB Solution MG 8
crispy BJ8 Rear Seat Back Upholstery Hardware Austin Healey 7
Jim_Gruber Bugeye Seat Pans needed Spridgets 1
J BJ8 Rear Seat Changes, 1964 to Later Austin Healey 9
mrv8q TR2/3/3A TR3A TRF vinyl seat reupholstery kit Triumph 7
J TR4/4A TR4A seat retaining clip Triumph 5
R BJ7 Back Seat-Rest Austin Healey 1
A TR2/3/3A Seat position Triumph 2
jlaird Wanted One Bugeye seat Spridgets Classified 0
